RVIZ2 Tutorials Episode1: Learn TF
04/03/2022
  1. How to use RVIZ2 step by step
  2. How to add the TFs of a simulation
  3. How to add the TFs of a real robot
  4. How to connect to a real robot through our robot lab
  5. Start the ros1 bridge to be able to see TF data from ROS1 in ROS2
  1. Use the project: https://app.theconstructsim.com/#/l/47f74f81/
  2. ROS Development Studio (ROSDS) —▸ http://rosds.online
  3. ROS2 Tutorials –▸
Welcome
Hi, and Welcome to this new series of posts.
In this series, we are going to explain how to add elements to RViz2. We will start with TF, then we will continue with Robots Description, then Cameras, PointClouds, Lasers, and so on.
In this first post, we are going to see how to add TFs in RViz2.
In order to learn how to add TFs in RViz2, we need to have ROS installed. We already prepared a rosject ready for that: https://app.theconstructsim.com/#/l/47f74f81/. You can download the rosject on your own computer if you want to work locally, but just by copying the rosject (clicking the link), you will have a setup already prepared for you.
Run rosject: RVIZ2 Tutorials Episode1: TF
Running the rosject
After you have clicked the Run button, the rosject should load and you should see a notebook that is open automatically:
Notebook - Run rosject: RVIZ2 Tutorials Episode1: TF
Notebook – Run rosject: RVIZ2 Tutorials Episode1: TF
The notebook contains the instructions to launch a simulation.
Launching the BOX_BOT simulation
In order to launch the simulation, let’s start by opening a new terminal:
After having the first terminal open, let’s run the following commands to launch a simulation:
cd ~/ros2_ws/
colcon build --packages-select box_bot_description box_bot_gazebo ;
source install/setup.bash ;
ros2 launch box_bot_gazebo start_world_launch.py
The commands we just executed only launch the world, but there is no robot on it yet.
Now, in a second terminal, let’s spawn the robot with the commands below:
cd ~/ros2_ws/
ros2 launch box_bot_gazebo spawn_robot_ros2.launch.py
Now that the robot has been successfully spawned, let’s now open RViz2. For that, let’s run the following commands in a third terminal.
cd ~/ros2_ws/
rviz2
See the simulation
In order to see the simulation, you can click on the Open Gazebo button:
Open Gazebo by clicking Open Gazebo
Click Open Gazebo to view the Gazebo simulation
The final image you get should be similar to the following:
Open Gazebo - RVIZ2 Tutorials Episode1 TF
Open Gazebo – RVIZ2 Tutorials Episode1 TF
See rviz2 in the Graphical Tools
In order to see rviz2 (RViz2), you have to click the Open Graphical Tools button, in case the graphical window did not open automatically:
Open Graphical Tools / rviz
Now that you can see rviz2, let’s set the fixed frame on the top left to /odom (Odometry), then let’s click the Add button on the bottom left and add a TF.
Once TF is added, let’s disable the “All Enabled” option to avoid getting confused with all those TFs that are shown. Let’s shown only specific frames: chassis, left_wheel, odom, right_wheel. In the end, our rviz2 should look similar to the following:
Specific Frames - RVIZ2 Tutorials Episode1_ TF 3
Specific Frames – RVIZ2 Tutorials Episode1_ TF 3
We must also click Show Names to show the frame names in RViz2.
Moving the robot with teleop
In order to see the frames of the robot moving in rviz2, let’s run the Keyboard Teleop in a fourth terminal using the following commands:
cd ~/ros2_ws/
If you now press the keys to move the robot around, you should be able to see the robot moving in the simulation, and you should also see the TFs moving in RViz2.
Moving the robot with teleop - Specific Frames - RVIZ2 Tutorials Episode1 TF
Moving the robot with teleop – Specific Frames – RVIZ2 Tutorials Episode1 TF
Connecting to a real robot
In order to see the TFs of a real robot, let’s click on the Real Robot Lab button that is available when you are not on the “Desktop” page of The Construct. After clicking Real Robot Lab, please select a robot and click Book Now. It’s free.
Real Robot Lab - Make a reservation
Real Robot Lab – Make a reservation
When you have the robot available for you, open the rosject and click on the button to connect to the real robot.
Connecting to the Real Robot Lab
After the connection is successfully established, you should have something similar to the following:
Real Robot Lab connected
Launch ros1_bridge
Before loading ros1_bridge, let’s load the parameters that we want to do the bridge.
Open a terminal and type the following:
roslaunch load_params load_params.launch
The command above loads basically the instructions saying: Hey, ros1, publish these specific topics because I want them to be available on ROS2.
Now, let’s run the parameter_bridge in a second terminal:
cd ~/ros2_ws/
ros2 run ros1_bridge parameter_bridge
Now that ros1_bridge is running, we should be able to easily see ros2 topics in a third terminal:
cd ~/ros2_ws/
ros2 topic list
You should see some topics listed, and the one we are most interested in today is the /tf topic.
If we now just open rviz2:
rviz2
we should now do the same procedure that we did previously, in order to see the TF data in RViz. Please refer to the section See rviz2 in the Graphical Tools already explained above (set /odom as the Fixed frame, and add the TF panel).
Moving the robot with ROS1
Now that we are connected to our robot and we have RViz2 setup ready, we can move the robot either with ROS1 or ROS2.
Let’s move it with ROS1, by running the following commands in a fourth terminal:
If you now move the robot by following the instructions, you should see the reflections in the camera of the Real Robot, and also in the RViz2:
Seeing real robot TFs in RVIZ2
Congratulations. You now know how to see TF data in RViz2.
