[ROS Q&A] 141 – How to Modify Logger Level in ROS (C++)
In this video we are going to see how to modify the Logger Level in ROS using C++.
This is a video trying to answer the following question posted at the ROS answers forum: https://answers.ros.org/question/98521/problems-with-logger-levels/
RELATED LINKS
▸ Original question: https://answers.ros.org/question/98521/problems-with-logger-levels/
▸ Robot Ignite Academy
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here.
Step 2. Create package and file
Let’s create a package for testing in RDS by typing the following command.
catkin_create_pkg logs_test roscpp
Then we create a source file under the logs_test/src directory called logs.cpp with the following content.
#include <ros/ros.h>
#include <ros/console.h>
#include <stdlib.h>
int main(int argc, char** argv) {
    if (ros::console::set_logger_level(ROSCONSOLE_DEFAULT_NAME, ros::console::levels::Debug))
        ros::console::notifyLoggerLevelsChanged();
    ros::init(argc,argv,"log_demo");
    ros::NodeHandle nh;
    ros::Rate loop_rate(0.5); // We create a Rate object of 2Hz
    while (ros::ok()) //Endless loop until Ctrl+c
        ROS_DEBUG("This is a DEBUG message");
        ROS_INFO("This is a INFO message");
        ROS_WARN("This is a WARN message");
        ROS_ERROR("This is a ERROR message");
        ROS_FATAL("This is a FATAL message");
        loop_rate.sleep();
        ros::spinOnce();
In the CMakeLists.txt, please change the following content in build part.
## Declare a C++ executable
add_executable(logs_test src/logs.cpp)
add_dependencies(logs_test ${logs_test_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(logs_test
  ${catkin_LIBRARIES}
Then we can compile the code with the following command
While waiting for compilation, let’s create a launch file to launch the code much easier. Please create a launch folder under the logs_test directory and create a file called logs_test.launch under it with the following code.
    <node pkg = "logs_test" type="logs_test" name="log_demo" output="screen" />
Then we can run the following command in shell to launch the node.
roslaunch logs_test logs_test.launch
Since we set the lowest level logger in our code(DEBUG) we’ll see all 5 levels logs are printing. If you change it(e.g. to ERROR) and compile again, you should only see the ERROR and FATAL message.
Edit by: Tony Huang
