[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part 4
In this video, you will learn how to use the Face Landmarks published in Part2 to make the MagicMirror Face move in simulation.
Want to start developing for ROS now? Check out RDS:
https://goo.gl/Lud9hQ
Want to learn more about how to move a robot in ROS? Check out the RobotIgniteCourse on URDF robot generation:
https://goo.gl/9kUsS9
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part3
In this video you will learn how to use the sound_play package for working with sound in ROS. You can use it for playing sounds from sound files or to make Text to Speech. Here you will also learn how to play sounds in a python notebook in ROS Development Studio. At the end you will learn how to apply all this to your Raspberry Pi.
Thank you very much to:
Play Sound in Python Notebooks:
https://gist.github.com/aisipos/8640905
ROS sound play package:
http://wiki.ros.org/sound_play
Work with pyaudio sound streams:
https://www.swharden.com/wp/2016-07-19-realtime-audio-visualization-in-python/
