How to create Gazebo plugins in ROS, Part 2
In this post, you will learn how to create Gazebo plugins by creating a more complex one integrated with ROS subscribers, to make an EarthQuake plugin. This is the second part of the response to the question posted on Gazebo Answers.
Before following this post, please ensure you have read and implemented the previous post, which created a simple plugin that merely printed “Hello World!” This post assumes you have read the first post. Let’s go!
Step 1: Add the source code for the new Gazebo plugin: EarthQuake
Create a new file in the src folder of the example_plugins_gazebo package.
cd ~/catkin_ws/src/example_plugins_gazebo/src
touch earthquake.cc
Now paste the following source code into the earthquake.cc file. Please read the explanations within the code.
#include <functional>
#include <gazebo/gazebo.hh>
#include <gazebo/physics/physics.hh>
#include <gazebo/common/common.hh>
#include <ignition/math/Vector3.hh>
#include <thread>
#include "ros/ros.h"
#include "ros/callback_queue.h"
#include "ros/subscribe_options.h"
#include "std_msgs/Float32.h"
#include <gazebo/transport/transport.hh>
#include <gazebo/msgs/msgs.hh>
namespace gazebo
  class ModelQuake : public ModelPlugin
    public: void Load(physics::ModelPtr _parent, sdf::ElementPtr /*_sdf*/)
      // Store the pointer to the model
      this->model = _parent;
      // Listen to the update event. This event is broadcast every
      // simulation iteration.
      this->updateConnection = event::Events::ConnectWorldUpdateBegin(
          std::bind(&amp;ModelQuake::OnUpdate, this));
      this->old_secs =ros::Time::now().toSec();
      // Create a topic name
      std::string earthquake_freq_topicName = "/earthquake_freq";
      std::string earthquake_magnitud_topicName = "/earthquake_magnitud";
      // Initialize ros, if it has not already bee initialized.
      if (!ros::isInitialized())
        int argc = 0;
        char **argv = NULL;
        ros::init(argc, argv, "earthquake_rosnode",
            ros::init_options::NoSigintHandler);
      // Create our ROS node. This acts in a similar manner to
      // the Gazebo node
      this->rosNode.reset(new ros::NodeHandle("earthquake_rosnode"));
      // Freq
      ros::SubscribeOptions so =
        ros::SubscribeOptions::create<std_msgs::Float32>(
            earthquake_freq_topicName,
            1,
            boost::bind(&amp;ModelQuake::OnRosMsg, this, _1),
            ros::VoidPtr(), &amp;this->rosQueue);
      this->rosSub = this->rosNode->subscribe(so);
      // Spin up the queue helper thread.
      this->rosQueueThread =
        std::thread(std::bind(&amp;ModelQuake::QueueThread, this));
      // Magnitude
      ros::SubscribeOptions so2 =
            earthquake_magnitud_topicName,
            1,
            boost::bind(&amp;ModelQuake::OnRosMsg_Magn, this, _1),
            ros::VoidPtr(), &amp;this->rosQueue2);
      this->rosSub2 = this->rosNode->subscribe(so2);
      this->rosQueueThread2 =
        std::thread(std::bind(&amp;ModelQuake::QueueThread2, this));
      ROS_WARN("Loaded ModelQuake Plugin with parent...%s, only X Axis Freq Supported in this V-1.0", this->model->GetName().c_str());
    // Called by the world update start event
    public: void OnUpdate()
      double new_secs =ros::Time::now().toSec();
      double delta = new_secs - this->old_secs;
      double max_delta = 0.0;
      if (this->x_axis_freq != 0.0)
        max_delta = 1.0 / this->x_axis_freq;
      double magnitude_speed = this->x_axis_magn;
      if (delta > max_delta &amp;&amp; delta != 0.0)
        // We change Direction
        this->direction = this->direction * -1;
        this->old_secs = new_secs;
        ROS_DEBUG("Change Direction...");
      double speed = magnitude_speed * this->direction;
      // Apply a small linear velocity to the model.
      this->model->SetLinearVel(ignition::math::Vector3d(speed, 0, 0));
      this->model->SetAngularVel(ignition::math::Vector3d(0, 0, 0));
    public: void SetFrequency(const double &amp;_freq)
      this->x_axis_freq = _freq;
      ROS_WARN("x_axis_freq >> %f", this->x_axis_freq);
    public: void SetMagnitude(const double &amp;_magn)
      this->x_axis_magn = _magn;
      ROS_WARN("x_axis_magn >> %f", this->x_axis_magn);
    public: void OnRosMsg(const std_msgs::Float32ConstPtr &amp;_msg)
      this->SetFrequency(_msg->data);
    /// \brief ROS helper function that processes messages
    private: void QueueThread()
      static const double timeout = 0.01;
      while (this->rosNode->ok())
        this->rosQueue.callAvailable(ros::WallDuration(timeout));
    public: void OnRosMsg_Magn(const std_msgs::Float32ConstPtr &amp;_msg)
      this->SetMagnitude(_msg->data);
    private: void QueueThread2()
        this->rosQueue2.callAvailable(ros::WallDuration(timeout));
    // Pointer to the model
    private: physics::ModelPtr model;
    // Pointer to the update event connection
    private: event::ConnectionPtr updateConnection;
    // Time Memory
    double old_secs;
    // Direction Value
    int direction = 1;
    // Frequency of earthquake
    double x_axis_freq = 1.0;
    // Magnitude of the Oscilations
    double x_axis_magn = 1.0;
    /// \brief A node use for ROS transport
    private: std::unique_ptr<ros::NodeHandle> rosNode;
    /// \brief A ROS subscriber
    private: ros::Subscriber rosSub;
    /// \brief A ROS callbackqueue that helps process messages
    private: ros::CallbackQueue rosQueue;
    /// \brief A thread the keeps running the rosQueue
    private: std::thread rosQueueThread;
    private: ros::Subscriber rosSub2;
    private: ros::CallbackQueue rosQueue2;
    private: std::thread rosQueueThread2;
  // Register this plugin with the simulator
  GZ_REGISTER_MODEL_PLUGIN(ModelQuake)
Add the new source to your CMakeLists.txt file so that it now looks like this:
project(example_plugins_gazebo)
## Add support for C++11, supported in ROS Kinetic and newer
add_definitions(-std=c++11)
# Load catkin and all dependencies required for this package
  roscpp
  gazebo_ros
# Depend on system install of Gazebo
find_package(gazebo REQUIRED)
link_directories(${GAZEBO_LIBRARY_DIRS})
include_directories(${Boost_INCLUDE_DIR} ${catkin_INCLUDE_DIRS} ${GAZEBO_INCLUDE_DIRS})
# For tc_simple_world_plugin plugin
add_library(simple_world_plugin src/simple_world_plugin.cpp)
target_link_libraries(simple_world_plugin ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES})
# For earthquake_plugin plugin
add_library(earthquake src/earthquake.cc)
target_link_libraries(earthquake ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES})
catkin_package(
  DEPENDS
    roscpp
    gazebo_ros
Step 2: Create a new world that will use the Gazebo plugin file we just created
Open a web shell and run the following commands to create the package. When creating Gazebo plugins, you need, at a minimum, the roscpp and gazebo_ros dependencies.
cd ~/catkin_ws/src/example_plugins_gazebo/worlds
touch earthquake.world
Open earthquake.world and paste in the following:
<sdf version="1.4">
  <world name="default">
    <include>
      <uri>model://sun</uri>
    <include>
    <!-- CUSTOM Ground Plane -->
    <model name="custom_ground_plane_box">
      <pose>0 0 0.1 0 0 0</pose>
      <link name="link">
        <collision name="collision">
            <box>
              <size>20 20 0.1</size>
            </box>
          <surface>
              <friction>
                <ode>
                  <mu>10000000000</mu>
                  <mu2>10000000000</mu2>
                </ode>
              </friction>
            </surface>
        </collision>
        <visual name="visual">
            <box>
            </box>
          <material>
              <script>
                <uri>file://media/materials/scripts/gazebo.material</uri>
                <name>Gazebo/Green</name>
              </script>
            </material>
        <inertial>
          <pose>0 0 0 0 0 0</pose>
          <mass>100</mass>
          <inertia>
            <ixx>3.33341666667e+3</ixx>
            <ixy>0.0</ixy>
            <ixz>0.0</ixz>
            <iyy>3.33341666667e+3</iyy>
            <iyz>0.0</iyz>
            <izz>6.66666666667e+3</izz>
          </inertia>
        </inertial>
      <plugin name="earthquake_plugin" filename="libearthquake.so"/>
    </model>
    <model name="box">
      <pose>0 0 1.5 0 0 0</pose>
      <link name="link">
            <box>
              <size>1 1 1</size>
            </box>
          <surface>
              <friction>
                <ode>
                </ode>
              </friction>
            </surface>
        </collision>
            <box>
              <size>1 1 1</size>
            </box>
    </model>
  </world>
</sdf>
Finally, create a launch file that launches the new world
cd ~/catkin_ws/src/example_plugins_gazebo/launch
touch earthquake.launch
Open earthquake.launch in the code editor and paste the following text:
    <arg name="world_name" value="$(find example_plugins_gazebo)/worlds/earthquake.world"/>
rm -rf build/ devel/
Success! We have now created a new plugin. Next, we will use it!
Step 3: Launch the new world with the Gazebo plugin we just created
Time to see the result of our labor:
roslaunch example_plugins_gazebo earthquake.launch
Now you should see some yellow warning printed in the terminal and a green plane with an ash-colored box on it. What – is the plane moving? Yes, it’s having an earthquake!
Gazebo world with EarthQuake plugin
But that’s not all! Do you remember the two topics defined in the plugin code? We can publish to them and change the “course of history”. Try these on two new terminals and see what happens (keep the roslaunch command running).
rostopic pub /earthquake_freq std_msgs/Float32 "data: 2.0"
rostopic pub /earthquake_magnitud std_msgs/Float32 "data: 3.0"
What happened there? Can you save the situation and stop the earthquake?
Step 4: Check your learning
Do you understand how to create Gazebo plugins? If you don’t know it yet, please go over the post again, more carefully this time.
Here are the links to the resources used in this tutorial:
  • http://gazebosim.org/tutorials/?tut=plugins_hello_world
  • http://gazebosim.org/tutorials?tut=ros_gzplugins
  • http://gazebosim.org/tutorials?tut=guided_i5
  • http://gazebosim.org/tutorials/?tut=ros_advanced
  • http://gazebosim.org/tutorials?tut=plugins_model
(Extra) Step 5: Watch the video to understand how to create Gazebo plugins
Did you like this post? Do you have any questions about how to create Gazebo plugins? Please leave a comment in the comments section below, so we can interact and learn from each other.
How to create Gazebo plugins in ROS, Part 1
In this post, you will learn how to create Gazebo plugins by making the Gazebo plugin tutorial, Hello World, compile and work in a ROS package. This is a response to the question posted on Gazebo Answers.
Create a new Rosject
You might also want to try this on a local PC if you have ROS installed. However, please note that we cannot support local PCs and you will have to fix any errors you run into on your own. The rest of the instruction assumes that you are working on The Construct; please adapt them to your local PC and ROS installation.
PS: We are using ROS Kinetic here, but you should be able to use any ROS 1 distro.
Step 2: Create a new package that we’ll use to demonstrate creating Gazebo plugins
Open Code Editor
Open a web shell
cd catkin_ws/src
catkin_create_pkg example_plugins_gazebo roscpp gazebo_ros
Create a new C++ file in the package you just created:
cd example_plugins_gazebo/src
touch simple_world_plugin.cpp
Now head over to the Code Editor to make changes to the C++ file. Check the image below for how to open the Code Editor.
Open the Code Editor
Locate the C++ file in the code editor: catkin_ws > src > example_plugins_gazebo > src > simple_world_plugin.cpp and paste in the following code.
#include <gazebo/common/Plugin.hh>
#include <ros/ros.h>
namespace gazebo
class WorldPluginTutorial : public WorldPlugin
public:
  WorldPluginTutorial() : WorldPlugin()
  void Load(physics::WorldPtr _world, sdf::ElementPtr _sdf)
    // Make sure the ROS node for Gazebo has already been initialized
      ROS_FATAL_STREAM("A ROS node for Gazebo has not been initialized, unable to load plugin. "
        << "Load the Gazebo system plugin 'libgazebo_ros_api_plugin.so' in the gazebo_ros package)");
      return;
    ROS_WARN("Hello World!");
GZ_REGISTER_WORLD_PLUGIN(WorldPluginTutorial)
Next, replace the package’s CMakeLists.txt with the following:
  roscpp
  gazebo_ros
catkin_package(
  DEPENDS
    roscpp
    gazebo_ros
Also, replace the package.xml file content with the following:
<package>
  <name>example_plugins_gazebo</name>
  <version>0.0.0</version>
  <description>The example_plugins_gazebo package</description>
  <maintainer email="name@email.com">user</maintainer>
  <license>TODO</license>
  <build_depend>gazebo_ros</build_depend>
  <build_depend>roscpp</build_depend>
  <run_depend>gazebo_ros</run_depend>
  <run_depend>roscpp</run_depend>
  <export>
    <gazebo_ros plugin_path="${prefix}/lib" gazebo_media_path="${prefix}" />
  </export>
</package>
Step 3: Use the new Gazebo plugin we just created
Create a new folder in the package. We’ll create Gazebo worlds in it, so it’s so named!
mkdir -p worlds
cd worlds
touch simple_world.world
Open the simple_world.world file in the code editor and paste in the following:
<?xml version="1.0" ?>
<sdf version="1.4">
    <include>
    <include>
    <!-- reference to your plugin -->
    <plugin name="simple_world_plugin" filename="libsimple_world_plugin.so"/>
  </world>
</sdf>
But, wait…how did we know the right filename to use in the line highlighted in the world file? It is by convention named lib{name_of_cpp_executable}.so, and we should find it in ~/catkin_ws/src/devel/lib/
cd ~/catkin_ws/devel/lib/
ls
That covered, we move. Now we’ll create a launch file to launch our world with the Gazebo plugin.
mkdir -p launch
cd launch
touch simple_world.launch
Open the simple_world.launch file in the code editor and paste in the following content.
    <arg name="world_name" value="$(find example_plugins_gazebo)/worlds/simple_world.world"/>
Perfect! Time to launch the package.
roslaunch example_plugins_gazebo simple_world.launch
Now you should see something like this: Hello World! printed on the terminal and an empty Gazebo world. We are done here!
Gazebo world with custom “Hello World” plugin
How to use the Gazebo differential drive plugin in ROS 2
In this post, you will learn how to use the Gazebo differential drive plugin in ros 2. This post answers the following question posted on ROS Answers.
Step 1: Copy a sample project with a ROS 2 Gazebo simulation using the differential drive plugin
Click here to copy the ROS2 TurtleBot3 sandbox project. Once copied, click the red RUN button to launch the project in a virtual machine. Please be patient while the environment loads.
PS: You will need to log in or create an account to copy the packages.
You might also want to try this on a local PC if you have ros2 and some executables installed. However, please note that we cannot support local PCs and you will have to fix any errors you run into on your own. The post assumes that you are working on The Construct; please adapt them to your local PC and ros2 installation.
Step 2: Find and explore the Gazebo model file containing the differential drive plugin
Now, we will find a Gazebo model file with the differential drive plugin. For this post, we’ll use the turtlebot3_ws/src/turtlebot3_simulations/turtlebot3_gazebo/models/turtlebot3_burger/model.sdf file. Sometimes it’s also defined as a .xacro file.
Head over to the Code Editor to explore this file as well as other files.
Gazebo model file
Let’s examine the differential drive section of this plugin file and compare it with the one on the ROS Answers post.
<plugin name="turtlebot3_diff_drive" filename="libgazebo_ros_diff_drive.so">
      <ros>
        <!-- <namespace>/tb3</namespace> -->
      </ros>
      <update_rate>30</update_rate>
      <!-- wheels -->
      <left_joint>wheel_left_joint</left_joint>
      <right_joint>wheel_right_joint</right_joint>
      <!-- kinematics -->
      <wheel_separation>0.160</wheel_separation>
      <wheel_diameter>0.066</wheel_diameter>
      <!-- limits -->
      <max_wheel_torque>20</max_wheel_torque>
      <max_wheel_acceleration>1.0</max_wheel_acceleration>
      <command_topic>cmd_vel</command_topic>
      <!-- output -->
      <publish_odom>true</publish_odom>
      <publish_odom_tf>true</publish_odom_tf>
      <publish_wheel_tf>false</publish_wheel_tf>
      <odometry_topic>odom</odometry_topic>
      <odometry_frame>odom</odometry_frame>
      <robot_base_frame>base_footprint</robot_base_frame>
    </plugin>
On lines 385 and 392, we see entries for the /cmd_vel (<command_topic>cmd_vel</command_topic>) and /odom (<odometry_topic>odom</odometry_topic>) topics respectively. However, these entries are missing in the file on ROS Answers.
Gazebo plugin file: mising command and odometry entries
<robot xmlns:xacro="http://www.ros.org/wiki/xacro"  name="robot">
   <gazebo>
        <plugin name="diff_drive" filename="libgazebo_ros_diff_drive.so">
            <!-- Wheel info-->
            <left_joint>left_wheel_joint</left_joint>
            <right_joint>right_wheel_joint</right_joint>
            <wheel_separation>0.35</wheel_separation>
            <wheel_diameter>0.1</wheel_diameter>
            <!-- Limits-->
            <max_wheel_torque>200</max_wheel_torque>
            <max_wheel_acceleration>10.0</max_wheel_acceleration>
            <!-- Output-->
            <robot_base_frame>base_link</robot_base_frame>
            <publish_wheel_tf>true</publish_wheel_tf>
        </plugin>
     </gazebo>
</robot>
Are these lines really necessary for moving the robot and getting its odometry? Let’s find out!
Step 3: Investigate the impacts of the of the command and odometry topic tags
Let’s comment out those tags in the file, and see if we can find the /cmd_vel and /odom topics, and if they work.
turtlebot3_ws/src/turtlebot3_simulations/turtlebot3_gazebo/models/turtlebot3_burger/model.sdf (modified)
      <ros>
      </ros>
      <!-- wheels -->
      <!-- kinematics -->
      <!-- limits -->
      <!-- <command_topic>cmd_vel</command_topic> -->
      <!-- output -->
      <!-- <odometry_topic>odom</odometry_topic> -->
    </plugin>
Now let’s run the package…in Terminal 1…
cd
source turtlebot3_ws/install/setup.bash
…check the topics in Terminal 2…
ros2 topic list
# output:
/clock
/cmd_vel
/imu
/joint_states
/odom
/parameter_events
/performance_metrics
/robot_description
/scan
/tf
/tf_static
Well, the topics are there, but are they working? Let’s publish to the /cmd_vel topic and see if the robot moves. We also echo the /odom in another terminal. Run the following in Terminal 2:
# Try to move the robot with teleop
Then in Terminal 3:
ros2 topic echo /odom
The robot didn’t move and nothing was echoing from /odom!
Now we need to confirm that it’s not working because of those tags. Let’s modify the launch command in Terminal 1. Press Ctrl + C to stop the simulation and run the following commands instead:
# note that we changed the Turtlebot3 model
Now try to move the robot again and check the /odom eching…Poof, both working! Why? We modified the model file for “burger”; the one for “waffle” was intact!
Final confirmation: uncomment the lines in turtlebot3_ws/src/turtlebot3_simulations/turtlebot3_gazebo/models/turtlebot3_burger/model.sdf , stop the simulation in Terminal 1 and run the following commands.
# note that we changed the Turtlebot3 model back to burger
Done! Now everything should be working!
So we have confirmed that the command and odometry tags are necessary.
Do you understand how to use the Gazebo differential drive plugin in ROS 2? If you don’t know it yet, please go over the post again, more carefully this time.
(Extra) Step 5: Watch the video to understand how to use the Gazebo differential drive plugin in ROS 2
Did you like this post? Do you have any questions about how to use the Gazebo differential drive plugin in ROS 2? Please leave a comment in the comments section below, so we can interact and learn from each other.
