[ROS Q&A] 149 – How to command joint position of a robot in ROS using Python?
This video extends the excellent tutorial on Gazebo-ROS control by demonstrating a Python script that will send the command to move a robot. The robot is used as an example, and a simple Python code sends joint position command to it through the appropriate topic.
This video is a response to a question posted on Gazebo Answers
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it rrbot_control. You can easily run the RRBOT simulation from Simulations->RRBOT in ROSDS.
Step 1. Load controller
If you launch the simulation successfully, you should see the robot is swinging its arm. As an example, the controller for this robot is already developed. You can launch the controller with the following command.
roslaunch rrbot_control rrbot_control.launch
Now if you type rostopic list , you should see several topic like /rrbot/joint1_position_controller/command in the list. We can publish to these topics to control the robot. For example,
rostopic pub /rrbot/joint1_position_controller/command std_msgs/Float64 "data: 0.5"
You should see the rrbot move its joint to a new position. The value here is in radian. Let’s try to control the robot with code instead of sending command.
Step 2. Create a package
We’ll create a ros package for our code first.
catkin_create_pkg rrbot_control rospy
cd rrbot_control
mkdir scripts
Then we create a script called main.py under the scripts folder with the following content.
# license removed for brevity
def talker():
    pub = rospy.Publisher('/rrbot/joint1_position_controller/command', Float64, queue_size=10)
    rospy.init_node('talker', anonymous=True)
    rate = rospy.Rate(10) # 10hz
        hello_str = "hello world %s" % rospy.get_time()
        position = math.pi/2
        rospy.loginfo(position)
        pub.publish(position)
        talker()
        pass
We can use rosrun rrbot_control main.pyto tun our script(remember to give it permission). You should see the robot move to the desired position. You can also try the code with different position function like sin, cos or even publish to more joints if you want.
If you are interested in learning ROS, please check our Robot Ignite Academy.
RELATED LINKS
Gazebo-ROS control tutorial
Official ROS Publisher / Subscriber tutorial
We love feedback!
