This is an extra short video updating what it has been done new on OpenAI_ROS package. You can find the link to the package wiki down below.
This is important for the people that saw the other two videos, because the structure of the package has changed and it might lead to some confusion and errors.
[irp posts=”10259″ name=”ROS Projects – Use OpenAI_ROS with Turtlebot2 Step by Step #Part 1″]
[irp posts=”10441″ name=”ROS Projects – Use OpenAI_ROS with TurtleBot2 Step-by-Step #Part 2″]
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it rrbot_control. You can easily clone the project with this link.
Step 1. Train Turtlebot 2 with OpenAI ROS
In the ROSject, we already clone the openai ros package for you. You can run the turtlebot 2 simulation from Simulations->Select launch file->main.launch. You should see the simulation is up and running.
Then you can run the training script with
cd catkin_ws
roslaunch turtle2_openai_ros_example start_training.launch
The robot starts moving and learning how to move in a maze.
In this video you will learn how to use openai_ros package to make learn the WAM-V sea robot of the RobotX Challenge to pass the first Navigation Control. The only thing you need to code is the AI algorithm if you want to use a different one to the one provided Q-Learn.
You can run the ROSject containing all the ROS code and simulation of the robot and sea by clicking on the next button:
In this second part, you will continue by creating your own TaskEnvironment for a different TurtleBot simulation environment with a wall.
You will create this Task Env that allows the robot to learn how to reach a certain position in the map without running into the wall.
In this new video series, we are going to learn how to use the openai_ros package created by TheConstruct. You will learn to use it with all the robots that we give suport to. You will learn in this video divided into two parts, how to use openai_ros with Turtlebot2. You will learn how to setup everything to use our package and make it learn how to move around a maze with very little coding.
Step 2. Clone the repository and create a package for the project
At first, we have to clone the repositories that we need for this project
cd ~/simulation_ws/src
git clone https://bitbucket.org/theconstructcore/open_ai_gym_construct.git
git clone https://bitbucket.org/theconstructcore/openai_ros.git
You can launch the simulation environment from simulations->Select launch file->gym_construct-main.launch
Inside the open_ai ROS package, we need to specify turtlebot2_maze.py as our task.
We’ll start by creating the folders for the project
mkdir openai_examples_projects/turtle2_open_ai_ros_example
Then create three folder config, launch, and scripts under the directory. Inside the launch folder, let’s create a script called start_training.launch with the following content
<!-- This version uses the openai_ros environments -->
<rosparam command="load" file="$(find turtle2_openai_ros_example)/config/turtlebot2_openai_qlearn_params.yaml" />
<node pkg="turtle2_openai_ros_example" name="turtlebot2_maze" type="start_qlearning.py" output="screen"/>
This launch file will load the parameters first for the algorithm, you can define the parameter in a file called turtlebot2_openai_qlearn_params.yaml in the config folder with the following content
turtlebot2: #namespace
pos_step: 0.016 # increment in position for each command
#qlearn parameters
alpha: 0.1
gamma: 0.7
epsilon: 0.9
epsilon_discount: 0.999
nepisodes: 500
nsteps: 10000
number_splits: 10 #set to change the number of state splits for the continuous problem and also the number of env_variable splits
running_step: 0.06 # Time for each step
n_actions: 4 # We have 3 actions, Forwards,TurnLeft,TurnRight,Backwards
n_observations: 6 # We have 6 different observations
speed_step: 1.0 # Time to wait in the reset phases
linear_forward_speed: 0.5 # Spwwed for ging fowards
linear_turn_speed: 0.05 # Lienare speed when turning
angular_speed: 0.3 # Angular speed when turning Left or Right
init_linear_forward_speed: 0.0 # Initial linear speed in which we start each episode
init_linear_turn_speed: 0.0 # Initial angular speed in shich we start each episode
new_ranges: 5 # How many laser readings we jump in each observation reading, the bigger the less laser resolution
min_range: 0.5 # Minimum meters below wich we consider we have crashed
max_laser_value: 6 # Value considered Ok, no wall
min_laser_value: 0 # Value considered there is an obstacle or crashed
desired_pose:
x: 5.0
y: 0.0
z: 0.0
forwards_reward: 5 # Points Given to go forwards
turn_reward: 1 # Points Given to turn as action
end_episode_points: 200 # Points given when ending an episode
Then it will launch the node for qlearning, let’s create two files under the scripts folder. The first one called qlearn.py with the following content which is implemented by Victor Mayoral Vilches. We won’t go into detail here.
Q-learning approach for different RL problems
as part of the basic series on reinforcement learning @
Inspired by https://gym.openai.com/evaluations/eval_kWknKOkPQ7izrixdhriurA
@author: Victor Mayoral Vilches <victor@erlerobotics.com>
import random
class QLearn:
def __init__(self, actions, epsilon, alpha, gamma):
self.q = {}
self.epsilon = epsilon # exploration constant
self.alpha = alpha # discount constant
self.gamma = gamma # discount factor
self.actions = actions
def getQ(self, state, action):
return self.q.get((state, action), 0.0)
def learnQ(self, state, action, reward, value):
Q-learning:
Q(s, a) += alpha * (reward(s,a) + max(Q(s') - Q(s,a))
oldv = self.q.get((state, action), None)
if oldv is None:
self.q[(state, action)] = reward
self.q[(state, action)] = oldv + self.alpha * (value - oldv)
def chooseAction(self, state, return_q=False):
q = [self.getQ(state, a) for a in self.actions]
maxQ = max(q)
if random.random() < self.epsilon:
minQ = min(q); mag = max(abs(minQ), abs(maxQ))
# add random values to all the actions, recalculate maxQ
q = [q[i] + random.random() * mag - .5 * mag for i in range(len(self.actions))]
maxQ = max(q)
count = q.count(maxQ)
# In case there're several state-action max values
# we select a random one among them
if count > 1:
best = [i for i in range(len(self.actions)) if q[i] == maxQ]
i = random.choice(best)
i = q.index(maxQ)
action = self.actions[i]
if return_q: # if they want it, give it!
return action, q
return action
def learn(self, state1, action1, reward, state2):
maxqnew = max([self.getQ(state2, a) for a in self.actions])
self.learnQ(state1, action1, reward, reward + self.gamma*maxqnew)
The next one is the training script called start_qlearning.py with the following content
import gym
import numpy
import time
import qlearn
from gym import wrappers
# ROS packages required
import rospkg
from openai_ros.turtlebot2 import turtlebot2_maze
rospy.init_node('turtlebot2_maze_qlearn', anonymous=True, log_level=rospy.WARN)
# Create the Gym environment
env = gym.make('TurtleBot2Maze-v0')
rospy.loginfo("Gym environment done")
# Set the logging system
rospack = rospkg.RosPack()
pkg_path = rospack.get_path('my_turtlebot2_maze')
outdir = pkg_path + '/training_results'
env = wrappers.Monitor(env, outdir, force=True)
rospy.loginfo("Monitor Wrapper started")
last_time_steps = numpy.ndarray(0)
# Loads parameters from the ROS param server
# Parameters are stored in a yaml file inside the config directory
# They are loaded at runtime by the launch file
Alpha = rospy.get_param("/turtlebot2/alpha")
Epsilon = rospy.get_param("/turtlebot2/epsilon")
Gamma = rospy.get_param("/turtlebot2/gamma")
epsilon_discount = rospy.get_param("/turtlebot2/epsilon_discount")
nepisodes = rospy.get_param("/turtlebot2/nepisodes")
nsteps = rospy.get_param("/turtlebot2/nsteps")
running_step = rospy.get_param("/turtlebot2/running_step")
# Initialises the algorithm that we are going to use for learning
qlearn = qlearn.QLearn(actions=range(env.action_space.n),
alpha=Alpha, gamma=Gamma, epsilon=Epsilon)
initial_epsilon = qlearn.epsilon
start_time = time.time()
highest_reward = 0
# Starts the main training loop: the one about the episodes to do
for x in range(nepisodes):
rospy.logdebug("############### START EPISODE=>" + str(x))
cumulated_reward = 0
done = False
if qlearn.epsilon > 0.05:
qlearn.epsilon *= epsilon_discount
# Initialize the environment and get first state of the robot
observation = env.reset()
state = ''.join(map(str, observation))
# Show on screen the actual situation of the robot
# env.render()
# for each episode, we test the robot for nsteps
for i in range(nsteps):
rospy.logwarn("############### Start Step=>" + str(i))
# Pick an action based on the current state
rospy.logwarn("Next action is:%d", action)
# Execute the action in the environment and get feedback
rospy.logwarn(str(observation) + " " + str(reward))
cumulated_reward += reward
if highest_reward < cumulated_reward:
highest_reward = cumulated_reward
# Make the algorithm learn based on the results
rospy.logwarn("# state we were=>" + str(state))
rospy.logwarn("# action that we took=>" + str(action))
rospy.logwarn("# reward that action gave=>" + str(reward))
rospy.logwarn("# episode cumulated_reward=>" + str(cumulated_reward))
rospy.logwarn("# State in which we will start next step=>" + str(nextState))
if not (done):
rospy.logwarn("NOT DONE")
state = nextState
rospy.logwarn("DONE")
last_time_steps = numpy.append(last_time_steps, [int(i + 1)])
break
rospy.logwarn("############### END Step=>" + str(i))
#raw_input("Next Step...PRESS KEY")
# rospy.sleep(2.0)
m, s = divmod(int(time.time() - start_time), 60)
h, m = divmod(m, 60)
rospy.logerr(("EP: " + str(x + 1) + " - [alpha: " + str(round(qlearn.alpha, 2)) + " - gamma: " + str(
round(qlearn.gamma, 2)) + " - epsilon: " + str(round(qlearn.epsilon, 2)) + "] - Reward: " + str(
cumulated_reward) + " Time: %d:%02d:%02d" % (h, m, s)))
rospy.loginfo(("\n|" + str(nepisodes) + "|" + str(qlearn.alpha) + "|" + str(qlearn.gamma) + "|" + str(
initial_epsilon) + "*" + str(epsilon_discount) + "|" + str(highest_reward) + "| PICTURE |"))
l = last_time_steps.tolist()
l.sort()
# print("Parameters: a="+str)
rospy.loginfo("Overall score: {:0.2f}".format(last_time_steps.mean()))
rospy.loginfo("Best 100 score: {:0.2f}".format(reduce(lambda x, y: x + y, l[-100:]) / len(l[-100:])))
env.close()
Line 20 is the most important part of this script. It will register the training environment.
From line 52 to line 102 is the training process of the algorithm. For each timestep, the algorithm will decide the action to take based on the current state. After an action is taken. The observation is measured and the reward is calculated. The algorithm will keep learning to get the highest possible reward.
After that, you can compile the package and launch the training with the following command.
You should see the turtlebot start to moving and reset if it touches the wall.
In this example, we use the environment defined by openai_ros package, but what if I want to do some different tasks? e.g. change the actions the robot can take?
Let’s create our own environment called my_turtlebot2_maze.py under the script folder with the following content
import numpy
from gym import spaces
from openai_ros import turtlebot2_env
timestep_limit_per_episode = 10000 # Can be any Value
register(
id='MyTurtleBot2Maze-v0',
entry_point='my_turtlebot2_maze:MyTurtleBot2MazeEnv',
timestep_limit=timestep_limit_per_episode,
class MyTurtleBot2MazeEnv(turtlebot2_env.TurtleBot2Env):
This Task Env is designed for having the TurtleBot2 in some kind of maze.
It will learn how to move around the maze without crashing.
# Only variable needed to be set here
number_actions = rospy.get_param('/turtlebot2/n_actions')
self.action_space = spaces.Discrete(number_actions)
# We set the reward range, which is not compulsory but here we do it.
self.reward_range = (-numpy.inf, numpy.inf)
#number_observations = rospy.get_param('/turtlebot2/n_observations')
We set the Observation space for the 6 observations
cube_observations = [
round(current_disk_roll_vel, 0),
round(y_distance, 1),
round(roll, 1),
round(pitch, 1),
round(y_linear_speed,1),
round(yaw, 1),
# Actions and Observations
self.linear_forward_speed = rospy.get_param('/turtlebot2/linear_forward_speed')
self.linear_turn_speed = rospy.get_param('/turtlebot2/linear_turn_speed')
self.angular_speed = rospy.get_param('/turtlebot2/angular_speed')
self.init_linear_forward_speed = rospy.get_param('/turtlebot2/init_linear_forward_speed')
self.init_linear_turn_speed = rospy.get_param('/turtlebot2/init_linear_turn_speed')
self.new_ranges = rospy.get_param('/turtlebot2/new_ranges')
self.min_range = rospy.get_param('/turtlebot2/min_range')
self.max_laser_value = rospy.get_param('/turtlebot2/max_laser_value')
self.min_laser_value = rospy.get_param('/turtlebot2/min_laser_value')
# We create two arrays based on the binary values that will be assigned
# In the discretization method.
laser_scan = self._check_laser_scan_ready()
num_laser_readings = len(laser_scan.ranges)/self.new_ranges
high = numpy.full((num_laser_readings), self.max_laser_value)
low = numpy.full((num_laser_readings), self.min_laser_value)
# We only use two integers
self.observation_space = spaces.Box(low, high)
rospy.logdebug("ACTION SPACES TYPE===>"+str(self.action_space))
rospy.logdebug("OBSERVATION SPACES TYPE===>"+str(self.observation_space))
# Rewards
self.forwards_reward = rospy.get_param("/turtlebot2/forwards_reward")
self.turn_reward = rospy.get_param("/turtlebot2/turn_reward")
self.end_episode_points = rospy.get_param("/turtlebot2/end_episode_points")
self.cumulated_steps = 0.0
# Here we will add any init functions prior to starting the MyRobotEnv
super(MyTurtleBot2MazeEnv, self).__init__()
def _set_init_pose(self):
"""Sets the Robot in its init pose
self.move_base( self.init_linear_forward_speed,
self.init_linear_turn_speed,
epsilon=0.05,
update_rate=10)
return True
def _init_env_variables(self):
Inits variables needed to be initialised each time we reset at the start
of an episode.
:return:
# For Info Purposes
self.cumulated_reward = 0.0
# Set to false Done, because its calculated asyncronously
self._episode_done = False
def _set_action(self, action):
This set action will Set the linear and angular speed of the turtlebot2
based on the action number given.
:param action: The action integer that set s what movement to do next.
rospy.logdebug("Start Set Action ==>"+str(action))
# We convert the actions to speed movements to send to the parent class CubeSingleDiskEnv
if action == 0: #FORWARD
linear_speed = self.linear_forward_speed
angular_speed = 0.0
self.last_action = "FORWARDS"
elif action == 1: #LEFT
linear_speed = self.linear_turn_speed
angular_speed = self.angular_speed
self.last_action = "TURN_LEFT"
elif action == 2: #RIGHT
angular_speed = -1*self.angular_speed
self.last_action = "TURN_RIGHT"
elif action == 3: #RIGHT
linear_speed = -self.linear_turn_speed
angular_speed = 0.0
self.last_action = "BACKWARDS"
# We tell TurtleBot2 the linear and angular speed to set to execute
self.move_base(linear_speed, angular_speed, epsilon=0.05, update_rate=10)
rospy.logdebug("END Set Action ==>"+str(action))
def _get_obs(self):
Here we define what sensor data defines our robots observations
To know which Variables we have acces to, we need to read the
TurtleBot2Env API DOCS
:return:
rospy.logdebug("Start Get Observation ==>")
# We get the laser scan data
laser_scan = self.get_laser_scan()
discretized_observations = self.discretize_observation( laser_scan,
self.new_ranges
rospy.logdebug("Observations==>"+str(discretized_observations))
rospy.logdebug("END Get Observation ==>")
return discretized_observations
def _is_done(self, observations):
if self._episode_done:
rospy.logerr("TurtleBot2 is Too Close to wall==>")
rospy.logerr("TurtleBot2 is Ok ==>")
return self._episode_done
def _compute_reward(self, observations, done):
if not done:
if self.last_action == "FORWARDS":
reward = self.forwards_reward
elif self.last_action == "BACKWARDS":
reward = -1*self.forwards_reward
reward = self.turn_reward
reward = -1*self.end_episode_points
rospy.logdebug("reward=" + str(reward))
self.cumulated_reward += reward
rospy.logdebug("Cumulated_reward=" + str(self.cumulated_reward))
self.cumulated_steps += 1
rospy.logdebug("Cumulated_steps=" + str(self.cumulated_steps))
return reward
# Internal TaskEnv Methods
def discretize_observation(self,data,new_ranges):
Discards all the laser readings that are not multiple in index of new_ranges
value.
discretized_ranges = []
mod = len(data.ranges)/new_ranges
rospy.logdebug("data=" + str(data))
rospy.logwarn("new_ranges=" + str(new_ranges))
rospy.logwarn("mod=" + str(mod))
for i, item in enumerate(data.ranges):
if (i%mod==0):
if item == float ('Inf') or numpy.isinf(item):
discretized_ranges.append(self.max_laser_value)
elif numpy.isnan(item):
discretized_ranges.append(self.min_laser_value)
discretized_ranges.append(int(item))
if (self.min_range > item > 0):
rospy.logerr("done Validation >>> item=" + str(item)+"< "+str(self.min_range))
self._episode_done = True
rospy.logwarn("NOT done Validation >>> item=" + str(item)+"< "+str(self.min_range))
return discretized_ranges
Please notice the ID defined in line 10 is the one we are going to use
In line 15, you can see that the environment is inherited from the turtlebot2_env from the openai_ros package. By doing that, you don’t need to define how to move the robot or get the sensor data since the openai_ros package already defined it for you.
Then let’s set up a new training script and launch file. We’ll call the new training script my_start_qlearning_maze.py with same same content as start_qlearning.py but with the following changes
import rospkg
import my_turtlebot2_maze
rospy.init_node('example_turtlebot2_maze_qlearn', anonymous=True, log_level=rospy.WARN)
# Create our own Gym environment
env = gym.make('MyTurtleBot2Maze-v0')
Here we directly import the environment from the previous script and use the ID it defined. The last step is to create the start_training_maze.launch file under the launch folder with the following content.
<node pkg="turtle2_openai_ros_example" name="example_turtlebot2_maze_qlearn" type="my_start_qlearning_maze.py" output="screen"/>
This launch file will launch the node which uses the last script for training.
You can define different action or reward as you want, but remember to also change the n_actions parameter in the turtlebot2_openai_qlearn_params.yaml because it is used by the openai gym.
Have fun!
If you want to learn more about OpenAI gym, please check our OpenAI Gym for Robotics 101 course. You’ll learn how to create environments and train robot for different task in detail.
