[ROS Q&A] 196  – How to Output Odometry Data
In this post, you will learn how to access and output odometry data programmatically. More specifically, you will learn how to create a C++ program for subscribing to and printing different parts of the odometry message. This is useful for cases where you need to make a decision based on the robot’s current position.
This post is an answer to the following question found on ROS Answers: https://answers.ros.org/question/333391/way-to-output-odometry-info/.
Let’s get started!
Step 1: Grab the ROS Project (ROSject) on ROSDS
Click here to get a copy of the ROS project used in this post. Next, click open to load the project. Please be patient while the project loads.
Step 2: Launch the necessary tools
  1. Launch a simulation from the Simulations menu.
    • Click on the Simulations menu. A dropdown menu opens.
    • In the section “Launch a provided simulation”, leave the empty world selected and choose the Turtlebot 2 robot.
    • Click “Start simulation”.
  2. Pick a Shell tool from the Tools menu. We’re be firing some commands soon.
  3. Pick the IDE tool from the Tools menu. We’ll use this to examine the code used for solving this problem.
Step 3: Examine the structure of the Odometry message using the command line
Run the following command on the Shell tool to print the current odometry of the robot:
# The -n1 switch to the command to ensure it prints one command and exits.
# Otherwise, it would print continuously until you press Ctrl + C.
user:~$ rostopic echo /odom -n1
header:
  seq: 4732
  stamp:
    secs: 236
    nsecs: 935000000
  frame_id: "odom"
child_frame_id: "base_footprint"
pose:
  pose:
    position:
      x: 0.00211759816401
      y: 4.81456536954e-05
      z: -0.000247189070632
    orientation:
      x: 0.000385225477218
      y: -0.00721104301471
      z: 0.000107238788561
      w: 0.99997392014
  covariance: [1e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-05, 0.0,0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.001]
twist:
  twist:
    linear:
      x: -0.000279472699265
      y: -4.17203978095e-05
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: -7.05905617719e-06
  covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
The command line output above shows the parts the make up an odometry message. The hottest part is pose, which tells us the current position of the robot. twist is also important, because it tells us the current message being published to move the robot.
Now let’s see how to access and output odometry data, considering the hottest part.
Step 4: See how to access and output odometry data in code
Switch to the IDE tool and locate the catkin_ws directory. You should find a C++ file in a package odom_subscriber. The full path to the file is catkin_ws/src/odom_subscriber/src/odom_sub.cpp.
Let’s see the content of this file:
#include <nav_msgs/Odometry.h> // Needed for accessing Odometry data
#include <ros/ros.h>           // Needed for creating the node, etc
// This functions get called when a new odometry message gets to the subscriber
// It automatically gets the odometry message as a parameter
// It prints out various parts of the message
void counterCallback(const nav_msgs::Odometry::ConstPtr &msg) {
  // ROS_INFO("%s", msg->header.frame_id.c_str());
  // ROS_INFO("%f", msg->twist.twist.linear.x);
  ROS_INFO("%f", msg->pose.pose.position.x);
  // Create a node to run the code
  ros::init(argc, argv, "odom_sub_node");
  ros::NodeHandle nh;
  // create a subscriber to the "/odom" topic so we can get the odometry message
  ros::Subscriber sub = nh.subscribe("odom", 1000, counterCallback);
  // Run program until manually stopped
  ros::spin();
I have added comments to the code to explain what each line or code block does, for better clarity.
The `counterCallback` function prints out the current x position of the robot. Observe how parts of the message are accessed in hierarchical format; using the structure in Step 3 as a guide, you can access and output any part of the Odometry message.
You can uncomment the commented parts to print out parts of the header and twist messages or even write other statements that print out other parts of the message!
Step 5: Move the robot and see the odometry data printed in real-time!
Run the C++ program in the shell, to print out the current x position of the robot. We can see the robot is basically at the “origin” and is stationary. Leave this program running.
user:~$ rosrun odom_subscriber odom_sub_node
[ INFO] [1575339924.601377783, 49.183000000]: 0.000240
[ INFO] [1575339924.651682994, 49.233000000]: 0.000240
Pick another Shell tool from the tools menu and run a command to move the robot:
user:~$ rostopic pub /cmd_vel geometry_msgs/Twist "linear:
  x: 0.2
  y: 0.0
  z: 0.0
angular:
  x: 0.0
  y: 0.0
  z: 0.0"
publishing and latching message. Press ctrl-C to terminate
Now you should see the robot moving. You should also see that the Odometry data being output in the other shell is changing.
In the second Shell, press Ctrl + C to stop the current program. Then publish the following message to stop the robot. After this, you should see the odometry position data become static again.
  x: 0.0
  y: 0.0
  z: 0.0
angular:
  x: 0.0
  y: 0.0
  z: 0.0"
Ant that was it!
Related Resources and Further Learning
If you are a ROS beginner and want to learn ROS basics fast, we recommend you take any of the following courses on Robot Ignite Academy:
Edited by Bayode Aderinola
#ROStutorials #Odometry #ROSsubscriber #ROS #Robot #C++
What is ROS?
What is ROS?
INTRODUCTION TO ROBOT OPERATING SYSTEM (ROS)
If you are reading this, it is because you either are or you want to become a ROS developer. Basically a ROS developer is somebody who wants to build programs for robots based on ROS. Yeah, but what is ROS? How can I learn ROS? How can I start developing with it? What is the most optimal development environment for it? All those questions will be answered in the following pages. But before we start with the practical things, let’s answer some basic questions about what ROS is and why it can be the door through which you can become a developer for robots.
WHY ARE THERE NOT ENOUGH DEVELOPERS FOR ROBOTICS?
In general, software developers do not like to deal with hardware. It is very likely that you are a developer and never thought about entering the robotics realm. You probably think that by programming for robots, you would need to know about electronics and maybe even mechanics. You probably think that hardware and software are too coupled in robots, and that you cannot touch one thing without touching the other. For example, some years ago, I had to make the navigation system for a robot. However, our navigation program was not working at all. We thought that it was something wrong with the program, but after extensive review, we found that it actually was a problem with the electronics of the laser scanner that we used to localize the robot. There were some micro-interruptions in the voltage level that made the laser reboot. In order to find that error, we had to go to the basics and find where the problem within the physical laser was. For that, you need to mess with the electronics. You have to take the laser out of the robot, put it on your table, and start experimenting. Different voltages, different interruptions to the power, all in order to try to reproduce the effect in a controlled environment. That is a lot of interaction with the hardware.
Interaction with hardware is something that many software developers don’t like. After all, they decided to become developers of software, not hardware!!
ROBOTICISTS PROGRAMMING ROBOTS
Due to that, the programming of robots has been done by roboticists, who are the people that build the robots. Maybe some of them are not directly involved in the creation of the robot, but definitely they have no problem getting into the hardware and trying to fix some hardware problems, in order to make their program work. But let’s face it, most roboticists are better developers than programmers. That is why robotics could benefit so much from having lots of expert programmers coming to the field. The good news is that getting developers into the field is more possible than ever. Thanks to the Robot Operating System, ROS, you can completely abstract the hardware from the software, so you can program a robot just by knowing the robot ROS API. By using the ROS API, you can forget about the hardware and just concentrate on the software that makes the robot do what you want.
WHAT IS THE ROBOT ROS API?
The ROS API is the list of ROS topics, services, action servers, and messages that a given robot is providing to give access to its hardware, that is, sensors and actuators. If you are not familiar with ROS, you may not understand what those terms mean. But simply put in the developers’ language, topics/services/messages are like the software functions you can call on a robot to get data from the sensors or make the robot take action. It also includes the parameters you can pass on to those functions. Most modern robot builders are providing off-the-shelf ROS APIs, like for example, ROS- Components shop that provides all its hardware running with a ROS API. If the robot you want to work with does not run ROS, you can still make the robot work with ROS by ROSifying it. To ROSify means to adapt your robot to work with ROS. To ROSify a robot usually requires knowledge to access the hardware. You need to learn how to communicate with the electronics that provide the sensor data or access the motors of the robot. In this series of ROS tutorials, we are not dealing with that subject because it gets out of scope for developers. But if you are interested in this topic, you can learn more about it in this Robot Creation Course.
So for the rest of the tutorials, we will assume that you have access (or are willing to have access) to a robot that is ROSified.
WHAT IS ROS ANYWAY?
ROS stands for Robot Operating System. Even if it says so, ROS is not a real operating system since it goes on top of Linux Ubuntu. ROS is a framework on top of the O.S. that allows it to abstract the hardware from the software. This means you can think in terms of software for all the hardware of the robot. And that’s good news for you because this implies that you can actually create programs for robots without having to deal with the hardware. Yeah!
ROS FOR SERVICE ROBOTS
ROS is becoming the standard in robotics programming, at least in the service robots sector. Initially, ROS started at universities, but quickly spread into the business world. Every day, more and more companies and startups are basing their businesses in ROS. Before ROS, every robot had to be programmed using the manufacturer’s own API. This means that if you changed robots, you had to start the entire software again, apart from having to learn the new API. Furthermore, you had to know a lot about how to interact with the electronics of the robot in order to understand how your program was doing. The situation was similar to that of computers in the 80s, when every computer had its own operating system and you had to create the same program for every type of computer. ROS is for robots like Windows is for PCs, or Android for phones. By having a ROSified robot, that is, a robot that runs on ROS, you can create programs that can be shared among different robots. You can build a navigation program, that is a program to make a robot move around without colliding, for a four-wheeled robot built by company A and then use the same exact code to move a two-wheeled robot built by company B… or even use it on a drone from company C.
SOME COMMONLY ASKED QUESTIONS
Which operating system should be used with ROS?
ROS works on Linux Ubuntu or Linux Debian. Experimental support already exists for OSX and Gentoo, and a version for Windows in underway, but we really don’t recommend for you to use them yet, unless you are an expert. Check this page for more information about how to use ROS on those systems. If you don’t know how to work with Linux, I recommend you start with this free Linux for Robotics course.
HOW TO DEVELOP FOR ROBOTS WITH ROS
Now, if you are convinced you want to become a robotics developer, in this series of ROS tutorials, you are going to find the steps that you can take to become a ROS developer. We have divided the tutorial series into the following sections that should cover the whole development process: • Setting Up • Learning • Coding • Testing Let’s go, one by one. [irp posts=”14751″ name=”ROS for Beginners: How to Learn ROS”] To access the full guide, click the orange button below, or go to RobotIgniteAcademy.com.
Download ROS Developers Guide
