[ROS in 5 mins] 049 – How to learn ROS basics using the turtlesim package
In this video, we’ll see how to use the turtlesim package (wiki.ros.org/turtlesim) for learning the basics of ROS. Get set to have some fun as you try out things for yourself!
Commands used:
* rostopic list
* rostopic pub
* rosmsg list
* rosmsg show
* rosservice list
* rosservice call
Robot Ignite Academy, the place to learn to program robots using only a web browser (the environment used in the video for demonstration)
ROS Development Studio (ROSDS), another powerful online tool for pushing your ROS learning in a practical way
[ROS in 5 mins] 047 – What is rqt plot
In this video we’re going to see what is rqt_plot and how it works.
Before we start, if you are new to ROS, I highly recommend you to take any of the following courses on Robot Ignite Academy
ROS Basics In 5 Days (Python)
ROS Basics In 5 Days (C++)
The commands used during the video to create the package were the following:
cd ~/catkin_ws/src/
cd tutorial/src/
touch learning.py
chmod +x learning.py
The content of learning.py is:
from std_msgs.msg import Float32
from random import random
rospy.init_node(‘learning’)
pub = rospy.Publisher(‘reward’, Float32, queue_size=1)
rate = rospy.Rate(1)
pub.publish( random() * 50 )
And to see rqt_plot, the command was:
rqt_plot /reward
Thanks for watching.
[ROS in 5 mins] 046 – What is ROS Namespace
Hello Everyone
In today’s video we’re going to see what is ROS Namespace and how it works.
Step 0. Create a project in Robot Ignite Academy(RIA)
We have the best online ROS course available in RIA. It helps you learn ROS in the easiest way without setting up ROS environment locally. The only thing you need is a browser! Create an account here and start to browse the trial course for free now! We’ll use the ROS Basics in 5 Days course unit0 as an example today.
Step 1. Create a package for the code
At first, let’s create a ROS package with dependencies for our code and a source file called robot.py under the src folder in the pakcage with the following command
catkin_create_pkg tutorial rospy geometry_msgs
cd tutorial/src
touch robot.py
In robot.py, please create the following content
rospy.init_node('robot', anonymous=True)
pub = rospy.Publisher('my_position', Pose, queue_size=1)
rate = rospy.Rate(1) # 1hz
pub.publish(Pose())
You can then give the permission and run the code with the following commands.
chmod +x robot.py
rosrun tutorial robot.py
It will publish the robot pose in my_position topic which you can check with
rostopic list | grep my_pos
Let’s imagine you have two different robot and you want to reuse the code. How can you distinguish between this two topics?
The answer is that you can use the namespace. To specify the different namespace, you can run the following command
rosrun tutorial robot.py __ns:=robot1
rosrun tutorial robot.py __ns:=robot2
Now if you see into the topic list, you should see two different topics called
/robot1/my_position
and
/robot2/my_position
If you are interested in this kind of tutorial, I highly recommend you to take any of the following courses on Robot Ignite Academy:
Edited by: Tony Huang
What is rosbag? How to record and playback ROS topics
Hello ROS Developers! In this video post, we’ll see what rosbag is, what it does, and how to use it to record and playback ROS topics.
Key commands that you will learn: rosbag...
  1. record
  2. play
  3. info
Step 1: Create a project in Robot Ignite Academy (RIA)
We have the best online ROS courses available in RIA. It helps you learn ROS in the easiest way without setting up a ROS environment locally. The only thing you need is a browser! Create an account here and start to browse the trial course for free now! We’ll use the ROS Basics in 5 Days course as an example today.
Step 2: Record Bag file with rosbag
The ROS Bag is a powerful tool for you to record and playback your simulation. To start the recording all topic available, simply type the following command in the terminal.
rosbag record -a
As an example, we’ll move the turtlebot in the simulation with
roslaunch turtlebot_teleop keyboard_teleop.launch
You can now move around to generate the data. To finish recording, simply press CTRL+C to terminate the rosbag.
Step 3: Play the rosbag bag file
In the video, the recorded bag file is saved as 2018-10-06-05-04-57.bag (be sure to use your own name 🙂 ). To playback, type the following command in a terminal
rosbag play 2018-10-06-05-04-57.bag
You should see the robot moving around as how you did.
If you want to see more information about the .bag file. The following command will print all the topic available in the .bag file.
rosbag info 2018-10-06-05-04-57.bag
Video
See it happening live in this video, in case you are stuck or just want to sit back and watch a “movie” instead!
Further resources
We love feedback!
[ROS in 5 mins] 044 – What is ROS tf?
In this video, we’ll see what the ROS tf package is, and what it does, and how to use one of its tools (rqt_tf_tree), in just about 5 minutes!
We have the best online ROS course available in RIA. It helps you learn ROS in the easiest way without setting up ROS environment locally. The only thing you need is a browser! Create an account here and start to browse the trial course for free now! We’ll use the TF ROS 101 as an example today.
Step 1. What is TF?
The TF
  1. It’s a Ros Package
  2. It lets the user keep tracking of multiple coordinate frames over time.
  3. It allows making computations in one frame and then transforming to another.
You can see the available TF in ROS by typing the following command
rosrun rqt_tf_tree rqt_tf_tree
You can see that there are 3 coordinate frames in this simulation world, turtle 1 and turtle 2. The rqt_tf_tree will only show the relationship for a particular timestep.
TF ROS 101
[irp posts=”11242″ name=”[ROS in 5 mins] 043 – What is tf view_frames?”]
