Real Time in ROS2 – Intro
In this post, we will see how to implement Real Time in ROS2, using the ROS2 Pendulum Real Time demo.
Step 1: Grab a copy of the ROS Project containing the code
Run ROS project
That done, open the project using the Run button. This might take a few moments, please be patient.
You should now see a notebook with detailed instructions. This post includes a summary of these instructions and some other tips.
Step 2: Start the Simulation
Start a web shell
Start a web shell from the bottom bar of the screen as shown above and run the following command:
source install/local_setup.bash
ros2 launch pendulum_bringup pendulum_bringup.launch.py rviz:=True
See the robot by clicking on the Graphical Tools icon on the bottom bar:
Open Graphical Tools
You should now see something like this (if you cannot see it, please ensure the ros2 launch command is still running and restart it if necessary):
ROS2 Pendulum
You might need to drag the window into focus and then maximize it.
Create new web shell
Move the robot by executing the following in a new terminal:
ros2 topic pub -1 /teleop pendulum2_msgs/msg/PendulumTeleop "cart_position: 5.0"
If you want to run the simulation on your local PC, then you need to run the commands given in the Setup section.
Step 3: Explore the source code using the IDE
Open Code Editor
View source code in the IDE
All the files used in the simulation are in the ros2_ws/src directory. Explore the files. Double-click to open a file in the editor. You will refer back to some of the files later on.
Step 4: Watch the video to understand how the simulation implemented Real Time in ROS2 with the Pendulum
Step 5: Consolidate your learning
  • Do you understand how to implement Real Time in ROS2 after watching the video? If not, have you gone over the video again?
  • Can you try to implement the simulation on your local PC?
Gazebo Joints Control in ROS2
In this post, we will see how to implement Gazebo joints control in ROS2. The way this is done has changed a bit from ROS1.
Run ROS project
Step 2: Start the Simulation and get the robot moving
Start a web shell
ros2 launch box_car_gazebo box_bot_launch.py
Start another tab in the web shell, run the following command:
ros2 run teleop_twist_keyboard teleop_twist_keyboard --ros-args --remap cmd_vel:=/box_bot/cmd_vel
See the robot by clicking on the Gazebo icon on the bottom bar:
Open Gazebo
Gazebo window with box car
Put the Gazebo window and the shell window with the teleop command side by side, focus on the shell and move the robot with the keyboard. You should see the robot run off. PS: use the z key to reduce the speed before moving the robot forward or backward, otherwise it runs off too quickly!
Open the IDE
ROS2 workspace
Step 4: Watch the video to understand how we implemented gazebo joints control in ROS2
  • Do you understand how to implement gazebo joints control in ROS2 after watching the video? If not, have you gone over the video again?
  • If you are familiar with ROS1 control, can you see how it’s different from ROS control?
[ROS Mini Challenge] #7 – make a robot follow another robot
In this post, we will see how to make a robot follow another robot. We’ll make the iRobot follow the big turtle all around the world when it moves, using ROS TF broadcaster and listener nodes.
PS: This ROS project is part of our ROS Mini Challenge series, which gives you an opportunity to win an amazing ROS Developers T-shirt! This challenge is already solved. For updates on future challenges, please stay tuned to our Twitter channel.
Step 1: Grab a copy of the ROS Project containing the code for the challenge
Click here to get your own copy of the project. If you don’t have an account on the ROS Development Studio, you will need to create one. Once you create an account or log in, we will copy the project to your workspace. That done, open your ROSject using the Open button. This might take a few moments, please be patient.
You should now see a notebook with detailed instructions about the challenge. This post includes a summary of these instructions as well as the solution to the challenge.
PS: Please ignore the Claim your Prize! section because…well…you are late the party 🙂
Step 2: Start the Simulation and get the robots moving
  1. Click on the Simulations menu and then Choose launch file… . In the dialog that appears, select rotw7.launch under turtle_tf_3d package. Then click the Launch button. You should see a Gazebo window popup showing the simulation.
  2. Get the robots moving. Pick a Shell from the Tools menu and run the following commands:
user:~$ source ~/catkin_ws/devel/setup.bash
user:~$ roslaunch rotw7_pkg irobot_follow_turtle.launch
At this point, you should already see the iRobot moving towards the big turtle.
Nothing happened? Heck, we gotta fix this! Let’s do that in the next section.
Step 3: Let’s find the problem
So the robots didn’t move as we expected. And we had this error message:
[INFO] [1580892397.791963, 77.216000]: Retrieveing Model indexes
[INFO] [1580892397.860043, 77.241000]: Robot Name=irobot, is NOT in model_state, trying again
The error message above says it cannot find the model name specified in the code, so let’s check that up. Fire up the IDE from the Tools menu and browse to the directory catkin_ws/src/rotw7_pkg/scripts. We have two Python scripts in there:
  • turtle_tf_broadcaster.py
  • turtle_tf_listener.py
The robot model names are specified on line 19 of turtle_tf_broadcaster.py:, in the publisher_of_tf function:
robot_name_list = ["irobot","turtle"]
Let’s check if we can find these robots in the simulation, using a Gazebo service:
user:~$ rosservice call /gazebo/get_world_properties "{}"
sim_time: 424.862
model_names: [ground_plane, coke_can, turtle1, turtle2]
rendering_enabled: True
success: True
status_message: "GetWorldProperties: got properties"
So we see that the names we specified are not in the simulation! The robots we need are turtle2 and turtle1.
Also, on line 19 of turtle_tf_listener.py, the code is publishing the “cmd_vel” (the topic that moves the robot) of the following robot:
turtle_vel = rospy.Publisher('/cmd_vel', geometry_msgs.msg.Twist,queue_size=1)
But, which of the turtles is the follower, and what is the correct topic for its “cmd_vel”? We have a hint from the launch file irobot_follow_turtle.launch:
    <include file="$(find rotw7_pkg)/launch/run_turtle_tf_broadcaster.launch"/>
    <include file="$(find rotw7_pkg)/launch/run_turtle_tf_listener.launch">
        <arg name="model_to_be_followed_name" value="turtle1" />
        <arg name="follower_model_name" value="turtle2" />
So the follower is turtle2. Now, let’s check what it’s “cmd_vel” topic is. It’s specified as /cmd_vel in the code, but is this true? Let’s check the list of topics:
user:~$ rostopic list
/turtle1/cmd_vel
/turtle2/cmd_vel
Probably, it’s /turtle2/cmd_vel. How do we know? Let’s publish to both /cmd_vel and /turtle2/cmd_vel and see which works.
ser:~$ rostopic pub /cmd_vel
Display all 152 possibilities? (y or n)
user:~$ rostopic pub /turtle2/cmd_vel geometry_msgs/Twist "linear:
  x: 0.2
  y: 0.0
  z: 0.0
angular:
  x: 0.0
  y: 0.0
  z: 0.0"
publishing and latching message. Press ctrl-C to terminate
^Cuser:~$ rostopic pub /turtle2/cmd_vel geometry_msgs/Twist "linr:r
  x: 0.0
  y: 0.0
  z: 0.0
angular:
  x: 0.0
  y: 0.0
  z: 0.0"
Publishing to /turtle2/cmd_vel works. /cmd_vel didn’t work.
Step 4: Let’s fix the problem
We saw the problems in Step 3, now let’s implement the fix and test again.
On line 19 of turtle_tf_broadcaster.py, change the list to reflect the real turtle names:
robot_name_list = ["turtle1","turtle2"]
Also, on line 19 of turtle_tf_listener.py, change /cmd_velto /turtle2/cmd_vel:
turtle_vel = rospy.Publisher('/turtle2/cmd_vel', geometry_msgs.msg.Twist,queue_size=1)
Now rerun the commands to move the robots:
You should now see the iRobot moving towards the big turtle. Now you can start moving the Turtle using the keyboard. Pick another Shell from the Tools menu and run the following command:
user:~$ roslaunch turtle_tf_3d turtle_keyboard_move.launch
Move the big turtle around with the keyboard, and you should see that the iRobot follows it. Done, that’s an example of how to make a robot follow another robot.
Extra: Video of this post
We made a video showing how we solved this challenge and made the iRobot follow another robot. If you prefer “sights and sounds” to “black and white”, here you go:
[ROS Mini Challenge] #5 – make a robot detect and avoid an obstacle
In this post, we will see how to make a robot detect and avoid an obstacle in its front. We will move the robot forward until it detects there’s an obstacle (the wall) closer than 1 meter. Then, we will stop the robot so that it does not collide with the wall.
Step 1: Grab a copy of the ROS Project that contains the code for the challenge
  1. Click on the Simulations menu and then Choose launch file… . In the dialog that appears, select rotw5.launch under rosbot_gazebo package. Then click the Launch button. You should see a Gazebo window popup showing the simulation: a ROSbot in front of a wall.
  2. Get the robot moving. Pick a Shell from the Tools menu and run the following commands:
user:~$ rosrun rotw5_pkg detect_wall.py
Yay, the robot moved. But, wait, it didn’t detect and avoid the obstacle – it crashed into the wall! We don’t want that, so let’s fix it in the next section!
Step 3: Identify the problem, man!
So the robot didn’t stop as we expected. As the challenge hinted, something must be wrong with the code, especially the part that should detect the wall and stop the robot. Let’s see.
Fire up the IDE from the Tools menu and browse to catkin_ws/src/rotw5_pkg/src/detect_wall.py
def callback(msg):
  #If the distance to an obstacle in front of the robot is bigger than 1 meter, the robot will move forward
  if msg.ranges[360] > 1:
      move.linear.x = 0.5
      move.angular.z = 0.0
  #If the distance to an obstacle in front of the robot is smaller than 1 meter, the robot will stop
  if msg.ranges[360] < 1:
      move.linear.x = 0.0
  pub.publish(move)
rospy.init_node('rotw5_node')
sub = rospy.Subscriber('/scan', LaserScan, callback) #We subscribe to the laser's topic
pub = rospy.Publisher('/cmd_vel', Twist)
move = Twist()
Now, this is the part that should stop the robot. It says that if there’s an obstacle less than 1 meter away, we should set both linear and angular velocities to zero (stopping the robot)
      move.linear.x = 0.0
This is not being executed obviously because the condition msg.ranges[360] < 1 is never True! Let’s test this assumption:
  • In the IDE, add the following lines to the detect_wall.py, after the comment below. Then save.
  print "Number of readings: ", print len(msg.ranges)
  print "Reading at position 360:", msg.ranges[360]
  • From the Shell: Press Ctrl + C to end the current program. Then stop the robot by publishing zero velocities to the /cmd_vel topic. Press Ctrl + C again and then call the Gazebo service that resets the world.
user:~$ rostopic pub /cmd_vel geometry_msgs/Twist "linear:
  x: 0.0
  y: 0.0
  z: 0.0
angular:
  x: 0.0
  y: 0.0
  z: 0.0"
user:~$ rosservice call /gazebo/reset_world "{}"
  • Run the program again and observe the output:
Number of readings:  720
Reading at position 360: inf
Reading at position 360: 11.7952680588
You should notice that several readings at 360 are printed, and none of them is less than 1. Whew!
Step 4: Now let’s solve the problem
We saw from the previous section that our problem was the condition msg.ranges[360] < 1, but how did we arrive at this condition?
  • We knew the laser sensor has 720 scan points stored in the ranges array, as seen in the output of our print statement in Step 3.
  • We assumed that the laser had a range of 180 degrees, covering the front of the robot only, so that position 360 is at the front-middle of the robot. But this is false, and we can confirm this by running the following command:
user:~$ rostopic echo /scan -n1
header:
  seq: 49846
  stamp:
    secs: 639
    nsecs:  47000000
  frame_id: "laser"
angle_min: -3.14159011841
angle_max: 3.14159011841
angle_increment: 0.00873877573758
time_increment: 0.0
The command prints out a single message from the /scan topic. We can deduce the range from the angle_max and angle_min values: angle_max - angle_min = 2pi = 360 deg!  Buff! So position 360/720 of the scan messages could be somewhere at the back of the robot. No wonder it didn’t detect the wall.
Now, we have to figure out which position is the front-middle of the robot. Depending on how the sensor was installed, this could be any position. For this robot, the sensor was installed with position “0″ at the front-center, so the readings of positions “0″ or 720 could represent the front-center.  Let’s use the position “0″  and test again.
  • In the IDE, change the front-middle position from 360 to “0″:
def callback(msg):
  if msg.ranges[0] > 1:
      move.linear.x = 0.5
  print "Number of ranges: ", len(msg.ranges)
  print "Reading at position 0:", msg.ranges[0]
  if msg.ranges[0] < 1:
      move.linear.x = 0.0
  pub.publish(move)
move = Twist()
  • Run the program again and observe the output and see if the robot detects and avoids the obstacle:
Number of ranges:  720
Reading at position 0: 2.49150013924
Reading at position 0: 1.92249274254
Reading at position 0: 0.991922438145
Yay, finally we are able to make the robot detect and avoid the obstacle!
We made a video showing how this challenge was solved. If you prefer “sights and sounds” to “black and white”, here you go:
Did you like this post? Do you have questions about what was explained? Whatever the case, please leave a comment on the comments section below, so we can interact and learn from each other.
[ROS Mini Challenge] #3 – make a manipulator robot execute a trajectory
In this post, we will see how to configure MoveIt to make a manipulator robot execute a trajectory based on a Position Goal. We send a Position Goal to the manipulator, and the robot computes and executes a trajectory plan in order to reach this goal.
Step 1: Grab a copy of the ROS Project that contains the simulation
You should now see a notebook with detailed instructions about the challenge. Please ignore the Claim your Prize! section because…well…you are late the party 🙂
Step 2: Start the Simulation and run the MoveIt program to configure the manipulator
  1. Click on the Simulations menu and then Choose launch file… . In the dialog that appears, select main.launch from the shadow_gazebo package. Then click the Launch button. You should see a Gazebo window popup showing the simulation: a manipulator robot.
  2. Start the MoveIt package – pick a Shell from the Tools menu and run the following command:
user:~$ roslaunch myrobot_moveit_config myrobot_planning_execution.launch
Once you see the green text that says “You can start planning now”, pick the Graphical Tools app from the Tools menu.
Probably, at first, you will see the window a bit displaced.
In order to center it, just click on the Resize opened app button. At the end, you should get something like this:
In the window that appears, go to the Planning tab and then to the Select Goal State dropdown under Query.
Select “start” and click Update.
Click on the Plan button under Commands in order to calculate a suitable trajectory for reaching the goal position.
Finally, click on the Execute button under Commands in order to execute the position goal (and the plan).
You should see the manipulator on the right moving in order to execute the trajectory, as shown below (in the Graphical Tools and the Gazebo windows).
But this didn’t happen did it? Let’s fix that in the next section!
Step 3: Let’s solve the problem!
What the heck was the problem?! Hmm, I wished I had paid more attention to the Shell…because it left a message for us there, in red letters! Let’s go see it:
[ERROR] [1580760680.575679474]: Unable to identify any set of controllers that can actuate the specified joints: [ elbow_joint shoulder_lift_joint shoulder_pan_joint wrist_1_joint wrist_2_joint wrist_3_joint ]
[ERROR] [1580760680.575917519]: Known controllers and their joints:
[ INFO] [1580760680.671585828]: ABORTED: Solution found but controller failed during execution
We didn’t set up a controller for moving the robot arm. Whew!
We need to examine the package to find the fix, so fire up the IDE from the Tools menu and browse to the catkin_ws/src/myrobot_moveit_config package. In the launch subdirectory, we have a file named smart_grasping_sandbox_moveit_controller_manager.launch.xml:
  <rosparam file="$(find myrobot_moveit_config)/config/my_controllers.yaml"/>
  <param name="use_controller_manager" value="false"/>
  <param name="trajectory_execution/execution_duration_monitoring" value="false"/>
  <param name="moveit_controller_manager" value="moveit_simple_controller_manager/MoveItSimpleControllerManager"/>
The first line of the configuration above refers to a file my_controllers.yamlfile in the config subdirectory let’s open that file up:
controller_list:
    Hi there!
Huh, we expected this file to list the controllers, but all we get here is “Hi there!”! We don’t need that – so this must be the wrong file! We need to find a file containing the controllers we need, so let’s check out some other files there, for example controllers.yaml:
controller_list:
  - name: arm_controller
    action_ns: follow_joint_trajectory
    type: JointTrajectoryController
    joints:
      - shoulder_pan_joint
      - shoulder_lift_joint
      - elbow_joint
      - wrist_1_joint
      - wrist_2_joint
      - wrist_3_joint
  - name: hand_controller
    type: FollowJointTrajectory
    joints:
      - H1_F1J1
      - H1_F1J2
      - H1_F1J3
      - H1_F2J1
      - H1_F2J2
      - H1_F2J3
      - H1_F3J1
      - H1_F3J2
      - H1_F3J3
WOW, this might be what we need (ssh! Top secret: it is!), so let’s copy over the contents of controllers to  my_controllers and save!
Step 4: Test the Fix
Now get back to the Shell. Stop the program we ran in Step 2 using Ctrl + C.
^C[rviz_rosdscomputer_8081_1478977940469499802-4] killing on exit
[move_group-3] killing on exit
[joint_state_publisher-2] killing on exit
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
After this, repeat everything in Step 2. Oops, yeah, it didn’t work yet!! Instead, we got another error:
[ERROR] [1580771100.563075907, 98.692000000]: Unable to identify any set of controllers that can actuate the specified joints: [ elbow_joint shoulder_lift_joint shoulder_pan_joint wrist_1_joint wrist_2_joint wrist_3_joint ]
[ERROR] [1580771100.563656482, 98.692000000]: Known controllersand their joints:
controller 'hand_controller' controls joints:
  H1_F1J1
  H1_F1J2
  H1_F1J3
  H1_F2J1
  H1_F2J2
  H1_F2J3
  H1_F3J1
  H1_F3J2
  H1_F3J3
The controllers again! Now let’s examine the error message again.
  • The controllers for the parts that need to move could not be found. But these controllers are listed in the my_controllers.yaml .
  • Some other controllers listed in the same file were found.
Perhaps there’s some misconfiguration – let’s have a second look at this my_controllers.yaml file:
  • We have two controllers: arm_controller and hand_controller.
  • They both have an action_ns called follow_joint_trajectory.
  • But they have different types! They should be the same since they have the same “action namespace”!
  • The type for arm_controller is probably wrong because it’s the one we couldn’t find!
Now, change the type for arm_controller to FollowJointTrajectory and repeat step 2! Now the manipulator should execute the trajectory successfully – you should see the robot arm moving in both the Graphical Tools and the Gazebo windows.
This is one example of how to make a manipulator robot execute a trajectory based on a Position Goal. I hope you found it useful.
