[ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step Part1
In this new ROS Project you are going to learn Step-by-Step how to create a moving cube and that it learns to move using OpenAI environment.
Part 1
This first video is for learning the creation of the URDF and control systems.
Moving Cube Git: https://bitbucket.org/theconstructcore/moving_cube/src/master/
Step 1. Create a project in ROS Development Studio(ROSDS)
We’ll use ROSDS through this project in order to avoid setting up the environment, manage packages and etc. You can create a free account here if you haven’t had an account yet.
Step 2. Create package
Since this is a simulation, let’s create a package called my_moving_cube_description under the simulation_ws.
cd ~/simulation_ws/src
catkin_create_pkg my_moving_cube_description rospy
We’ll start by building the URDF description of the robot. To do that, we’ll create a new folder called urdf under the my_moving_cube_description directory and create a file called my_moving_cube.urdf inside it with the following initial content. The robot tag indicates the name of the robot – my_moving_cube.
<robot name="my_moving_cube">
</robot>
Then let’s create the first link inside the robot. This includes 3 parts :
  1. inertial: It defines the physical property of the link. You can calculate the inertia of an object by using this tool: rosrun spawn_robot_tools_pkg inertial_calculator.py
  2. collision: It defines the collision property when the object interacts with other objects in the simulation.
  3. visual: It defines the visual property, how the object will visually show in the simulation.
    <link name="cube_body">
        <inertial>
            <mass value="0.5" />
            <inertia ixx="0.00333333333333" ixy="0.0" ixz="0.0" iyy="0.00333333333333" iyz="0.0" izz="0.00333333333333"/>
        </inertial>
        <collision>
                <box size="0.2 0.2 0.2"/>
        </collision>
	    <visual>
You also need to define the material property after the link if you want to use it in gazebo.  (NOTICE: the reference of the material property should have the same name as the link)
    <gazebo reference="cube_body">
        <kp>1000000.0</kp>
        <kd>1000000.0</kd>
        <mu1>1000000.0</mu1>
        <mu2>1000000.0</mu2>
        <material>Gazebo/Black</material>
    </gazebo>
Then we can create a spawn_moving_cube.launch file under the my_moving_cube_description/launch directory with the following content to spawn the cube.
    <include file="$(find spawn_robot_tools_pkg)/launch/spawn_robot_urdf.launch">
        <arg name="x" default="0.0" />
        <arg name="y" default="0.0" />
        <arg name="z" default="0.11" />
        <arg name="roll" default="0"/>
        <arg name="pitch" default="0"/>
        <arg name="yaw" default="0.0" />
        <arg name="urdf_robot_file" default="$(find my_moving_cube_description)/urdf/my_moving_cube.urdf" />
        <arg name="robot_name" default="my_moving_cube" />
Now, go to simulations->–Empty– to launch an empty world. Then go to Tools->shell to run the command
roslaunch my_moving_cube_description spawn_moving_cube.launch
You should see the cube now appears in the empty world like this
Similarly, we can add another link called inertia_whell_roll
    <link name="inertia_wheel_roll">
        <inertial>
            <inertia ixx="0.000804166666667" ixy="0.0" ixz="0.0" iyy="0.000804166666667" iyz="0.0" izz="0.0016"/>
        </inertial>
        <collision>
                <cylinder radius="0.08" length="0.01"/>
        </collision>
	    <visual>
    <gazebo reference="inertia_wheel_roll">
        <kp>1000.0</kp>
        <kd>1000.0</kd>
        <mu1>0.5</mu1>
        <mu2>0.5</mu2>
        <material>Gazebo/Red</material>
    </gazebo>
Then we also need to define the joint type which connects these two links
    <joint name="inertia_wheel_roll_joint" type="continuous">
        <origin xyz="0.1 0.0 0.0" rpy="0 1.57 0"/>
        <parent link="cube_body"/>
        <child  link="inertia_wheel_roll"/>
        <limit effort="200" velocity="1000.0"/>
        <axis xyz="0 0 1"/>
If you launch it again, you should see the red cylinder appear.
Step 3. Make the robot move
We need to include the controller package first in the urdf
    <gazebo>
            <robotNamespace>/my_moving_cube</robotNamespace>
        </plugin>
    </gazebo>
We’ll add the transmission part to actuate the robot.(NOTICE: the joint_name should be the same as the joint)
    <transmission name="inertia_wheel_roll_joint_trans">
      <joint name="inertia_wheel_roll_joint">
      <actuator name="inertia_wheel_roll_jointMotor">
      </actuator>
    </transmission>
Then we create a moving_cube.yaml file under the my_moving_cube_description/config to define parameters for the controller
# .yaml config file
# The PID gains and controller settings must be saved in a yaml file that gets loaded
# to the param server via the roslaunch file (moving_cube_control.launch).
my_moving_cube:
  # Creates the /joint_states topic necessary in ROS
  joint_state_controller:
    publish_rate: 30
  # Effort Controllers ---------------------------------------
  inertia_wheel_roll_joint_velocity_controller:
    type: effort_controllers/JointVelocityController
    joint: inertia_wheel_roll_joint
    pid: {p: 1.0, i: 0.0, d: 0.0}
In the end, you should create one new launch file called moving_cube control.launch under the launch folder to launch the controller
  <rosparam file="$(find my_moving_cube_description)/config/moving_cube.yaml"
            command="load"/>
  <node name="robot_state_publisher_moving_cube" pkg="robot_state_publisher" type="robot_state_publisher"
        respawn="false" output="screen">
            <param name="publish_frequency" type="double" value="30.0" />
            <param name="ignore_timestamp" type="bool" value="true" />
            <param name="tf_prefix" type="string" value="moving_cube" />
            <remap from="/joint_states" to="/moving_cube/joint_states" />
  <node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
        output="screen" args="--namespace=/my_moving_cube
                              inertia_wheel_roll_joint_velocity_controller">
Let’s spawn the cube and launch the controller
roslaunch my_moving_cube_descriptiospawn_moving_cube.launch
roslaunch my_moving_cube_description moving_cube_control.launch
Then we can kick the robot and make it move by publishing one topic like this
rostopic pub /my_moving_cube/inertia_wheel_roll_joint_velocity_controller/command std_msgs/Float64 "data: 80.0"
Congratulations! Your cube robot moved a bit!
[irp posts=”9860″ name=”ROS Projects OpenAI with Moving Cube Robot in Gazebo Step-by-Step Part2″]
[ROS Projects] – My Robotic Manipulator – #Part 5 – ROS Controllers and XACRO
This is a series of posts. If you didn’t follow up, you can find the previous post here. In this 5th video of the robotic manipulator series, we will expand the ROS controllers to all joints of our robot using XACRO. At the end of the video we’ll have a full controlled robot through ROS topics. We are also going to use RQT Publisher and RQT Reconfigure to do some experiments with the robot.
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. We’ll start the project for the previous video – manipulator_video_no4.
Step 1. Configure controller
In order to use controllers for our robot.  The first step is we need to add transmission definitions for each joint in the links_joints.xarco and add limitation for each joint in the mrm.xarco file. The most important thing is to add the gazebo plugin in the mrm.xarco file.
<xacro:macro name="m_joint" params="name type axis_xyz origin_rpy origin_xyz parent child limit_e limit_l limit_u limit_v">
    <joint name="${name}" type="${type}">
      <axis xyz="${axis_xyz}" />
      <limit effort="${limit_e}" lower="${limit_l}" upper="${limit_u}" velocity="${limit_v}" />
      <parent link="${parent}" />
      <child link="${child}" />
    <transmission name="trans_${name}">
      <joint name="${name}">
      <actuator name="motor_${name}">
      </actuator>
    </transmission>
  </xacro:macro>
           axis_xyz="0 1 0"
           parent="link_01" child="link_02"
           limit_e="1000" limit_l="0" limit_u="0.5" limit_v="0.5" />
              mass="57.906"
              ixx="12.679" ixy="0" ixz="0"
              iyy="12.679" iyz="0"
              izz="0.651"
              radius="0.15" length="0.8" />
           axis_xyz="0 1 0"
           parent="link_02" child="link_03"
           limit_e="1000" limit_l="0" limit_u="0.75" limit_v="0.5" />
              mass="57.906"
              izz="0.651"
           axis_xyz="0 1 0"
           parent="link_03" child="link_04"
              mass="57.906"
              izz="0.651"
           axis_xyz="0 0 1"
           parent="link_04" child="link_05"
           limit_e="1000" limit_l="-3.14" limit_u="3.14" limit_v="0.5" />
  <gazebo>
    </plugin>
  </gazebo>
Then we create a file called joints.yaml file in the config folder which defines the parameters for controllers.
  publish_rate: 50
joint1_position_controller:
  joint: base_link__link_01
joint2_position_controller:
  joint: link_01__link_02
joint3_position_controller:
  joint: link_02__link_03
  pid: {p: 20000.0, i: 50, d: 1000.0}
joint4_position_controller:
  joint: link_03__link_04
  pid: {p: 2000.0, i: 50, d: 200.0}
joint5_position_controller:
  joint: link_04__link_05
  pid: {p: 700.0, i: 50, d: 70.0}
This file defines the type of the controller and the pid parameters for each controller.
The last step is to modify the launch file in order to launch the gazebo plugin for the controller in the spawn.launch file.
    <group ns="/mrm">
        <!-- Robot model -->
        <arg name="x" default="0"/>
        <arg name="y" default="0"/>
        <arg name="z" default="0.5"/>
        <!-- Load controllers -->
        <!-- Controllers -->
            args="--namespace=/mrm
            --timeout 60">
        <!-- rqt -->
        <node name="rqt_reconfigure" pkg="rqt_reconfigure" type="rqt_reconfigure" />
        <node name="rqt_publisher" pkg="rqt_publisher" type="rqt_publisher" />
    </group>
Then you can open an empty simulation from Simulations->Empty and launch it with the following command
After you see the robot appear in the simulation, you can open the graphical tool from Tools->graphical tool
By using the rqt tool, you can send parameter to topics control the joint movement(e.g mrm/joint4_position_controller/command/dara) to move the robot.
The PID parameters are not well tuned yet, we’ll do it in the next post. But the robot is moving(with some oscillation) now.
If you want to learn more about how to create manipulator simulation in ROS, please check our Robot Creation with URDF ROS and ROS Control 101 course.
RELATED LINKS & RESOURCES
Did you like the video? If you did please give us a thumbs up and remember to subscribe to our channel and press the bell for a new video every day. Either you like it or not, please share your thoughts and questions in the comments area. See you!
[irp posts=”9549″ name=”My Robotic Manipulator – #Part 4 – ROS + URDF/Transmission + Gazebo Controllers”]
[ROS Projects] OpenAI with Hopper Robot in Gazebo Step-by-Step #Part2
We continue setting up OpenAI-Gym to make a Hopper robot learn in Gazebo simulator, using ROS Development Studio.
If you didn’t follow the previous post, here are the links:
[ROS Projects] Create a Hopper Robot in Gazebo Step-by-Step
Got a suggestion for the next steps to take of this project? We would love to hear them in the comments bellow :).
Part 2
Step 1. Environment setup
We’ll start by explaining how to create the gym environment for training. You can create a file called monoped_env.py under the my_hopper_training/src directory with the following content
    By Miguel Angel Rodriguez <duckfrost@theconstructsim.com>
    Visit our website at ec2-54-246-60-98.eu-west-1.compute.amazonaws.com
import gym
import numpy as np
import time
from gym import utils, spaces
from gym.utils import seeding
from gazebo_connection import GazeboConnection
from joint_publisher import JointPub
from monoped_state import MonopedState
from controllers_connection import ControllersConnection
#register the training environment in the gym as an available one
reg = register(
    id='Monoped-v0',
    entry_point='monoped_env:MonopedEnv',
    timestep_limit=50,
class MonopedEnv(gym.Env):
        # We assume that a ROS node has already been created
        # before initialising the environment
        # gets training parameters from param server
        self.desired_pose = Pose()
        self.desired_pose.position.x = rospy.get_param("/desired_pose/x")
        self.desired_pose.position.y = rospy.get_param("/desired_pose/y")
        self.desired_pose.position.z = rospy.get_param("/desired_pose/z")
        self.running_step = rospy.get_param("/running_step")
        self.max_incl = rospy.get_param("/max_incl")
        self.max_height = rospy.get_param("/max_height")
        self.min_height = rospy.get_param("/min_height")
        self.joint_increment_value = rospy.get_param("/joint_increment_value")
        self.done_reward = rospy.get_param("/done_reward")
        self.alive_reward = rospy.get_param("/alive_reward")
        self.desired_force = rospy.get_param("/desired_force")
        self.desired_yaw = rospy.get_param("/desired_yaw")
        self.weight_r1 = rospy.get_param("/weight_r1")
        self.weight_r2 = rospy.get_param("/weight_r2")
        self.weight_r3 = rospy.get_param("/weight_r3")
        self.weight_r4 = rospy.get_param("/weight_r4")
        self.weight_r5 = rospy.get_param("/weight_r5")
        # stablishes connection with simulator
        self.gazebo = GazeboConnection()
        self.controllers_object = ControllersConnection(namespace="monoped")
        self.monoped_state_object = MonopedState(   max_height=self.max_height,
                                                    min_height=self.min_height,
                                                    abs_max_roll=self.max_incl,
                                                    abs_max_pitch=self.max_incl,
                                                    joint_increment_value=self.joint_increment_value,
                                                    done_reward=self.done_reward,
                                                    alive_reward=self.alive_reward,
                                                    desired_force=self.desired_force,
                                                    desired_yaw=self.desired_yaw,
                                                    weight_r1=self.weight_r1,
                                                    weight_r2=self.weight_r2,
                                                    weight_r3=self.weight_r3,
                                                    weight_r4=self.weight_r4,
                                                    weight_r5=self.weight_r5
        self.monoped_state_object.set_desired_world_point(self.desired_pose.position.x,
                                                          self.desired_pose.position.y,
                                                          self.desired_pose.position.z)
        self.monoped_joint_pubisher_object = JointPub()
        For this version, we consider 6 actions
        1-2) Increment/Decrement haa_joint
        3-4) Increment/Decrement hfe_joint
        5-6) Increment/Decrement kfe_joint
        self.action_space = spaces.Discrete(6)
        self.reward_range = (-np.inf, np.inf)
        self._seed()
    # A function to initialize the random generator
    def _seed(self, seed=None):
        self.np_random, seed = seeding.np_random(seed)
        return [seed]
    # Resets the state of the environment and returns an initial observation.
    def _reset(self):
        # 0st: We pause the Simulator
        rospy.logdebug("Pausing SIM...")
        self.gazebo.pauseSim()
        # 1st: resets the simulation to initial values
        rospy.logdebug("Reset SIM...")
        self.gazebo.resetSim()
        # 2nd: We Set the gravity to 0.0 so that we dont fall when reseting joints
        # It also UNPAUSES the simulation
        rospy.logdebug("Remove Gravity...")
        self.gazebo.change_gravity(0.0, 0.0, 0.0)
        # EXTRA: Reset JoinStateControlers because sim reset doesnt reset TFs, generating time problems
        rospy.logdebug("reset_monoped_joint_controllers...")
        self.controllers_object.reset_monoped_joint_controllers()
        # 3rd: resets the robot to initial conditions
        rospy.logdebug("set_init_pose...")
        self.monoped_joint_pubisher_object.set_init_pose()
        # 5th: Check all subscribers work.
        # Get the state of the Robot defined by its RPY orientation, distance from
        # desired point, contact force and JointState of the three joints
        rospy.logdebug("check_all_systems_ready...")
        self.monoped_state_object.check_all_systems_ready()
        rospy.logdebug("get_observations...")
        observation = self.monoped_state_object.get_observations()
        # 6th: We restore the gravity to original
        rospy.logdebug("Restore Gravity...")
        self.gazebo.change_gravity(0.0, 0.0, -9.81)
        # 7th: pauses simulation
        rospy.logdebug("Pause SIM...")
        # Get the State Discrete Stringuified version of the observations
        state = self.get_state(observation)
        return state
    def _step(self, action):
        # Given the action selected by the learning algorithm,
        # we perform the corresponding movement of the robot
        # 1st, decide which action corresponsd to which joint is incremented
        next_action_position = self.monoped_state_object.get_action_to_position(action)
        # We move it to that pos
        self.gazebo.unpauseSim()
        self.monoped_joint_pubisher_object.move_joints(next_action_position)
        # Then we send the command to the robot and let it go
        # for running_step seconds
        time.sleep(self.running_step)
        # We now process the latest data saved in the class state to calculate
        # the state and the rewards. This way we guarantee that they work
        # with the same exact data.
        # Generate State based on observations
        # finally we get an evaluation based on what happened in the sim
        reward,done = self.monoped_state_object.process_data()
        return state, reward, done, {}
    def get_state(self, observation):
        We retrieve the Stringuified-Discrete version of the given observation
        :return: state
        return self.monoped_state_object.get_state_as_string(observation)
This script creates the gym environment with the following parts:
1.Register the training environment
You will always need to do this step to inform the gym package that a new training environment is created.
2.Load the desired pose
Parameters related to the training is loaded at this step.
3.Connect with the gazebo
In order to connect the gym environment with gazebo simulation, we create a script called gazebo_connection.py in the same directory with the following content
from std_srvs.srv import Empty
from gazebo_msgs.msg import ODEPhysics
from gazebo_msgs.srv import SetPhysicsProperties, SetPhysicsPropertiesRequest
from geometry_msgs.msg import Vector3
class GazeboConnection():
        self.unpause = rospy.ServiceProxy('/gazebo/unpause_physics', Empty)
        self.pause = rospy.ServiceProxy('/gazebo/pause_physics', Empty)
        self.reset_proxy = rospy.ServiceProxy('/gazebo/reset_simulation', Empty)
        # Setup the Gravity Controle system
        service_name = '/gazebo/set_physics_properties'
        rospy.logdebug("Waiting for service " + str(service_name))
        rospy.wait_for_service(service_name)
        rospy.logdebug("Service Found " + str(service_name))
        self.set_physics = rospy.ServiceProxy(service_name, SetPhysicsProperties)
        self.init_values()
        # We always pause the simulation, important for legged robots learning
        self.pauseSim()
    def pauseSim(self):
        rospy.wait_for_service('/gazebo/pause_physics')
            self.pause()
        except rospy.ServiceException, e:
            print ("/gazebo/pause_physics service call failed")
    def unpauseSim(self):
        rospy.wait_for_service('/gazebo/unpause_physics')
            self.unpause()
            print ("/gazebo/unpause_physics service call failed")
    def resetSim(self):
        rospy.wait_for_service('/gazebo/reset_simulation')
            self.reset_proxy()
            print ("/gazebo/reset_simulation service call failed")
    def resetWorld(self):
        rospy.wait_for_service('/gazebo/reset_world')
            self.reset_proxy()
            print ("/gazebo/reset_world service call failed")
    def init_values(self):
            # reset_proxy.call()
            self.reset_proxy()
        self._time_step = Float64(0.001)
        self._max_update_rate = Float64(1000.0)
        self._gravity = Vector3()
        self._gravity.x = 0.0
        self._gravity.y = 0.0
        self._gravity.z = 0.0
        self._ode_config = ODEPhysics()
        self._ode_config.auto_disable_bodies = False
        self._ode_config.sor_pgs_precon_iters = 0
        self._ode_config.sor_pgs_iters = 50
        self._ode_config.sor_pgs_w = 1.3
        self._ode_config.sor_pgs_rms_error_tol = 0.0
        self._ode_config.contact_surface_layer = 0.001
        self._ode_config.contact_max_correcting_vel = 0.0
        self._ode_config.cfm = 0.0
        self._ode_config.erp = 0.2
        self._ode_config.max_contacts = 20
        self.update_gravity_call()
    def update_gravity_call(self):
        self.pauseSim()
        set_physics_request = SetPhysicsPropertiesRequest()
        set_physics_request.time_step = self._time_step.data
        set_physics_request.max_update_rate = self._max_update_rate.data
        set_physics_request.gravity = self._gravity
        set_physics_request.ode_config = self._ode_config
        rospy.logdebug(str(set_physics_request.gravity))
        result = self.set_physics(set_physics_request)
        rospy.logdebug("Gravity Update Result==" + str(result.success) + ",message==" + str(result.status_message))
        self.unpauseSim()
    def change_gravity(self, x, y, z):
        self._gravity.x = x
        self._gravity.y = y
        self._gravity.z = z
This script is responsible to reset, pause and unpause the simulation for the training script.
4.Connect with the controller
Since TF doesn’t like that we reset the environment and it will generate some problems. We have to manually reset the controller with the controller_connection.py script. We won’t go into detail here. If you want to learn more about the controller, please check our controller 101 course.
import gym
import numpy as np
import time
reg = register(
    id='Monoped-v0',
    timestep_limit=50,
        self._seed()
        return [seed]
    def _reset(self):
        return state
        :return: state
5.Generate state object
The state object is then generated with the current state with the following monoped_state.py script
import gym
import numpy as np
import time
reg = register(
    id='Monoped-v0',
    timestep_limit=50,
        self._seed()
        return [seed]
    def _reset(self):
        return state
        :return: state
6.Reset
Setup the environment back to its initial observation. This includes the steps like pause the simulation, reset the controller and etc. as we described before.
7.Step
In this part, an action will be decided based on the current state and then be published with the following joint_publisher.py script. After that, the reward is calculated based on the new observation.
class JointPub(object):
        self.publishers_array = []
        self._haa_joint_pub = rospy.Publisher('/monoped/haa_joint_position_controller/command', Float64, queue_size=1)
        self._hfe_joint_pub = rospy.Publisher('/monoped/hfe_joint_position_controller/command', Float64, queue_size=1)
        self._kfe_joint_pub = rospy.Publisher('/monoped/kfe_joint_position_controller/command', Float64, queue_size=1)
        self.publishers_array.append(self._haa_joint_pub)
        self.publishers_array.append(self._hfe_joint_pub)
        self.publishers_array.append(self._kfe_joint_pub)
        self.init_pos = [0.0,0.0,0.0]
    def set_init_pose(self):
        Sets joints to initial position [0,0,0]
        :return:
        self.move_joints(self.init_pos)
        :return:
        rate = rospy.Rate(10)  # 10hz
        while (self._haa_joint_pub.get_num_connections() == 0):
            rospy.logdebug("No susbribers to _haa_joint_pub yet so we wait and try again")
                pass
        rospy.logdebug("_haa_joint_pub Publisher Connected")
        while (self._hfe_joint_pub.get_num_connections() == 0):
            rospy.logdebug("No susbribers to _hfe_joint_pub yet so we wait and try again")
                pass
        rospy.logdebug("_hfe_joint_pub Publisher Connected")
        while (self._kfe_joint_pub.get_num_connections() == 0):
            rospy.logdebug("No susbribers to _kfe_joint_pub yet so we wait and try again")
                pass
        rospy.logdebug("_kfe_joint_pub Publisher Connected")
        rospy.logdebug("All Publishers READY")
    def joint_mono_des_callback(self, msg):
        rospy.logdebug(str(msg.joint_state.position))
        self.move_joints(msg.joint_state.position)
    def move_joints(self, joints_array):
        i = 0
        for publisher_object in self.publishers_array:
          joint_value = Float64()
          joint_value.data = joints_array[i]
          rospy.logdebug("JointsPos>>"+str(joint_value))
          publisher_object.publish(joint_value)
          i += 1
    def start_loop(self, rate_value = 2.0):
        rospy.logdebug("Start Loop")
        pos1 = [0.0,0.0,1.6]
        pos2 = [0.0,0.0,-1.6]
        position = "pos1"
        rate = rospy.Rate(rate_value)
          if position == "pos1":
            self.move_joints(pos1)
            position = "pos2"
            self.move_joints(pos2)
            position = "pos1"
    def start_sinus_loop(self, rate_value = 2.0):
        w = 0.0
        x = 2.0*math.sin(w)
        #pos_x = [0.0,0.0,x]
        #pos_x = [x, 0.0, 0.0]
        pos_x = [0.0, x, 0.0]
            self.move_joints(pos_x)
            w += 0.05
            x = 2.0 * math.sin(w)
            #pos_x = [0.0, 0.0, x]
if __name__=="__main__":
    rospy.init_node('joint_publisher_node')
    joint_publisher = JointPub()
    rate_value = 50.0
    #joint_publisher.start_loop(rate_value)
    joint_publisher.start_sinus_loop(rate_value)
Step 2. Training
Now you have all the code you need to start training. Let’s run the simulation first. Go to Simulations -> Select launch file -> my_legged_robot_sims->main.launch to launch the hopper robot simulation in Gazebo.
Then you can run the training with
roslaunch my_hopper_training main.launch
The algorithm is working and start to train the robot to perform the task we want, however, it still requires lots of tuning to work properly.
You can have multiple instances and train robots with different parameters in parallel with our paid program in ROSDS. Please check it here if you are interested.
[irp]
Here you will find all the code:
https://bitbucket.org/theconstructcore/hopper/src/master/
Or use directly the project of ROSDevelopementStudio:
https://rds.theconstructsim.com/tc_projects/use_project_share_link/0a40a3bf-e0be-4119-8364-ac443c68545a
Check Out this OpenAI course in RobotIgnite Academy for learning the basics step by step: https://wp.me/P9Rthq-1UZ
open-ai-gym-for-robotics-ros-course-banner
[ROS Projects] – My Robotic Manipulator – #Part 4 – ROS + URDF/Transmission + Gazebo Controllers
In this video we are going to set up in our robotic manipulator a new URDF element: Transmissions. After that, we are able to integrate ROS and gazebo simulation using ROS controllers. We’ll use a simplified model of the robot to see how it works. At the end of the video we’ll be able to send joint position commands to the robot publishing to some ROS topics.
Find a complete course about ROS controllers and URDF
Robot Ignite Academy:
https://goo.gl/93gmxz
ROS Development Studio:
https://goo.gl/jWEZ5c
Project repository:
https://bitbucket.org/theconstructcore/my-robotic-manipulator
URDF Transmission reference:
http://wiki.ros.org/urdf/XML/Transmission
In this series, we are going to show you how to build a hopper robot in ROS and make it learn to hop using reinforcement learning algorithm. The hopper robot simulation has been built in the last post. In case you didn’t follow it, you can find the post here.
Part 1
Use OpenAI to make a Hopper robot learn in Gazebo simulator, using ROS Development Studio. We will use Qlearning and Gym for that.
Step 1. Create a training package
Let’s create a package for training
cd ~/simulation_ws/src/loco_motion
catkin_create_pkg my_hopper_training rospy
Then we create a launch file called main.launch inside the my_hopper_training/launch directory with the following content
    Date of creation: 5/II/2018
    Application created by: Miguel Angel Rodriguez <duckfrost@theconstructsim.com>
    The Construct https://www.theconstruct.ai
    License LGPLV3 << Basically means you can do whatever you want with this!
    <!-- Load the parameters for the algorithm -->
    <rosparam command="load" file="$(find my_hopper_training)/config/qlearn_params.yaml" />
    <node pkg="my_hopper_training" name="monoped_gym" type="start_training_v2.py" output="screen"/>
To implement reinforcement learning, we’ll use an algorithm called q-learn. We’ll save the parameters for the q-learn algorithm as qlearn_params.yaml under the my_hopper_training/config directory with the following content
# Algortihm Parameters
alpha: 0.1
gamma: 0.8
epsilon: 0.9
epsilon_discount: 0.999 # 1098 eps to reach 0.1
nepisodes: 100000
nsteps: 1000
# Environment Parameters
desired_pose:
    x: 0.0
    y: 0.0
    z: 1.0
desired_force: 7.08 # In Newtons, normal contact force when stanting still with 9.81 gravity
desired_yaw: 0.0 # Desired yaw in radians for the hopper to stay
max_height: 3.0   # in meters
min_height: 0.5   # in meters
max_incl: 1.57       # in rads
running_step: 0.001   # in seconds
joint_increment_value: 0.05  # in radians
done_reward: -1000.0 # reward
alive_reward: 100.0 # reward
weight_r1: 1.0 # Weight for joint positions ( joints in the zero is perfect )
weight_r2: 0.0 # Weight for joint efforts ( no efforts is perfect )
weight_r3: 1.0 # Weight for contact force similar to desired ( weight of monoped )
weight_r4: 1.0 # Weight for orientation ( vertical is perfect )
weight_r5: 1.0 # Weight for distance from desired point ( on the point is perfect )
In this post, we’ll focus on explaining the training script. Let’s create it under the my_hopper_training_src directory and call it start_training_v2.py with the following content
    Original Training code made by Ricardo Tellez <rtellez@theconstructsim.com>
    Moded by Miguel Angel Rodriguez <duckfrost@theconstructsim.com>
import gym
import time
import numpy
import random
import qlearn
from gym import wrappers
# ROS packages required
import rospkg
import monoped_env
    rospy.init_node('monoped_gym', anonymous=True, log_level=rospy.INFO)
    # Create the Gym environment
    env = gym.make('Monoped-v0')
    rospy.logdebug ( "Gym environment done")
    reward_pub = rospy.Publisher('/monoped/reward', Float64, queue_size=1)
    episode_reward_pub = rospy.Publisher('/monoped/episode_reward', Float64, queue_size=1)
    # Set the logging system
    rospack = rospkg.RosPack()
    pkg_path = rospack.get_path('my_hopper_training')
    outdir = pkg_path + '/training_results'
    env = wrappers.Monitor(env, outdir, force=True)
    rospy.logdebug("Monitor Wrapper started")
    last_time_steps = numpy.ndarray(0)
    # Loads parameters from the ROS param server
    # Parameters are stored in a yaml file inside the config directory
    # They are loaded at runtime by the launch file
    Alpha = rospy.get_param("/alpha")
    Epsilon = rospy.get_param("/epsilon")
    Gamma = rospy.get_param("/gamma")
    epsilon_discount = rospy.get_param("/epsilon_discount")
    nepisodes = rospy.get_param("/nepisodes")
    nsteps = rospy.get_param("/nsteps")
    # Initialises the algorithm that we are going to use for learning
    qlearn = qlearn.QLearn(actions=range(env.action_space.n),
                    alpha=Alpha, gamma=Gamma, epsilon=Epsilon)
    initial_epsilon = qlearn.epsilon
    start_time = time.time()
    highest_reward = 0
    # Starts the main training loop: the one about the episodes to do
    for x in range(nepisodes):
        rospy.loginfo ("STARTING Episode #"+str(x))
        cumulated_reward = 0
        cumulated_reward_msg = Float64()
        episode_reward_msg = Float64()
        done = False
        if qlearn.epsilon > 0.05:
            qlearn.epsilon *= epsilon_discount
        # Initialize the environment and get first state of the robot
        rospy.logdebug("env.reset...")
        # Now We return directly the stringuified observations called state
        state = env.reset()
        rospy.logdebug("env.get_state...==>"+str(state))
        # for each episode, we test the robot for nsteps
        for i in range(nsteps):
            # Pick an action based on the current state
            # Execute the action in the environment and get feedback
            rospy.logdebug("###################### Start Step...["+str(i)+"]")
            rospy.logdebug("haa+,haa-,hfe+,hfe-,kfe+,kfe- >> [0,1,2,3,4,5]")
            rospy.logdebug("Action to Perform >> "+str(action))
            nextState, reward, done, info = env.step(action)
            rospy.logdebug("END Step...")
            rospy.logdebug("Reward ==> " + str(reward))
            cumulated_reward += reward
            if highest_reward < cumulated_reward:
                highest_reward = cumulated_reward
            rospy.logdebug("env.get_state...[distance_from_desired_point,base_roll,base_pitch,base_yaw,contact_force,joint_states_haa,joint_states_hfe,joint_states_kfe]==>" + str(nextState))
            # Make the algorithm learn based on the results
            # We publish the cumulated reward
            cumulated_reward_msg.data = cumulated_reward
            reward_pub.publish(cumulated_reward_msg)
            if not(done):
                state = nextState
                rospy.logdebug ("DONE")
                last_time_steps = numpy.append(last_time_steps, [int(i + 1)])
                break
            rospy.logdebug("###################### END Step...["+str(i)+"]")
        m, s = divmod(int(time.time() - start_time), 60)
        h, m = divmod(m, 60)
        episode_reward_msg.data = cumulated_reward
        episode_reward_pub.publish(episode_reward_msg)
        rospy.loginfo( ("EP: "+str(x+1)+" - [alpha: "+str(round(qlearn.alpha,2))+" - gamma: "+str(round(qlearn.gamma,2))+" - epsilon: "+str(round(qlearn.epsilon,2))+"] - Reward: "+str(cumulated_reward)+"     Time: %d:%02d:%02d" % (h, m, s)))
    rospy.loginfo ( ("\n|"+str(nepisodes)+"|"+str(qlearn.alpha)+"|"+str(qlearn.gamma)+"|"+str(initial_epsilon)+"*"+str(epsilon_discount)+"|"+str(highest_reward)+"| PICTURE |"))
    l = last_time_steps.tolist()
    l.sort()
    rospy.loginfo("Overall score: {:0.2f}".format(last_time_steps.mean()))
    rospy.loginfo("Best 100 score: {:0.2f}".format(reduce(lambda x, y: x + y, l[-100:]) / len(l[-100:])))
    env.close()
We won’t go into detail to explain the q-learn algorithm. You can find a tutorial here if you are interested. You can simply copy and paste the following code into a file called qlearn.py and put it under the my_hopper_training/src directory
Q-learning approach for different RL problems
as part of the basic series on reinforcement learning @
Inspired by https://gym.openai.com/evaluations/eval_kWknKOkPQ7izrixdhriurA
        @author: Victor Mayoral Vilches <victor@erlerobotics.com>
import random
class QLearn:
    def __init__(self, actions, epsilon, alpha, gamma):
        self.q = {}
        self.epsilon = epsilon  # exploration constant
        self.alpha = alpha      # discount constant
        self.gamma = gamma      # discount factor
        self.actions = actions
    def getQ(self, state, action):
        return self.q.get((state, action), 0.0)
    def learnQ(self, state, action, reward, value):
        Q-learning:
            Q(s, a) += alpha * (reward(s,a) + max(Q(s') - Q(s,a))
        oldv = self.q.get((state, action), None)
        if oldv is None:
            self.q[(state, action)] = reward
            self.q[(state, action)] = oldv + self.alpha * (value - oldv)
    def chooseAction(self, state, return_q=False):
        q = [self.getQ(state, a) for a in self.actions]
        maxQ = max(q)
        if random.random() < self.epsilon:
            minQ = min(q); mag = max(abs(minQ), abs(maxQ))
            # add random values to all the actions, recalculate maxQ
            q = [q[i] + random.random() * mag - .5 * mag for i in range(len(self.actions))]
            maxQ = max(q)
        count = q.count(maxQ)
        # In case there're several state-action max values
        # we select a random one among them
        if count > 1:
            best = [i for i in range(len(self.actions)) if q[i] == maxQ]
            i = random.choice(best)
            i = q.index(maxQ)
        action = self.actions[i]
        if return_q: # if they want it, give it!
            return action, q
        return action
    def learn(self, state1, action1, reward, state2):
        maxqnew = max([self.getQ(state2, a) for a in self.actions])
        self.learnQ(state1, action1, reward, reward + self.gamma*maxqnew)
In the training script, we are basically doing the following step:
  1. create the training environment
  2. read q learn parameters from the parameter server
  3. try to get the highest reward with the q learn algorithm by deciding which action to take based on the current state for each timestep
That’s it for today. For the next post, we are going to explain how to build the gym training environment.
https://rds.theconstructsim.com/tc_projects/use_project_share_link/f162963c-5651-460a-bab0-b1cd45607103
