![[ROS Q&A] 163 – Custom message fails to build: No such file or directory](https://www.theconstruct.ai/wp-content/uploads/2018/11/ROS-QA-163-Custom-message-fails-to-build-No-such-file-or-directory.jpg)
Learn how to solve a common error “No such file or directory” when compiling a package that contains a custom message. This post answered the following question on ROS Answers: https://answers.ros.org/question/306884/custom-message-fails-to-build-no-such-file-or-directory/.
- Use the ROS Development Studio (ROSDS), an online platform for developing for ROS within a PC browser. Easy-peasy. I’m using this option for this post.
- Once you log in, click on the New ROSject button to create a project that will host your code. Then Click on Open ROSject to launch the development/simulation environment.
- To open a “terminal” on ROSDS, pick the
Shell
app from the Tools menu. - You can find the
IDE
app on the Tools menu.
- You have ROS installed on a local PC. Okay, skip to Step 2.
Next step!
Step 2: Create a package as specified in the question to reproduce the problem
1. If you are working on ROSDS, please create a ROSject first, as indicated above.
2. Open a terminal and create a package:
user:~$ cd catkin_ws/src user:~/catkin_ws/src$ catkin_create_pkg custom_msg rospy roscpp Created file custom_msg/CMakeLists.txt Created file custom_msg/package.xml Created folder custom_msg/include/custom_msg Created folder custom_msg/src Successfully created files in /home/user/catkin_ws/src/custom_msg. Please adjust the values in package.xml.
3. Create a custom message
user:~/catkin_ws/src$ cd custom_msg/ user:~/catkin_ws/src/custom_msg$ mkdir -p msg user:~/catkin_ws/src/custom_msg$ cd msg user:~/catkin_ws/src/custom_msg/msg$ touch my_msg.msg user:~/catkin_ws/src/custom_msg/msg$
4. Open the IDE and paste the following into my_msg.msg
int32 my_int float64 my_float
5. Add the following line to package.xml
<build_depend>message_generation</build_depend> <exec_depend>message_runtime</exec_depend>
6. Create a source file.
user:~/catkin_ws/src/custom_msg/msg$ cd ../src user:~/catkin_ws/src/custom_msg/src$ touch custom_msg.cpp user:~/catkin_ws/src/custom_msg/src$
Add the following to custom_msg.cpp
using the IDE: just a reference to the custom message and an empty main
function.
#include <custom_msg/my_msg.h> int main() { return 0; }
7. Edit CMakeLists.txt
as follows
– In find_package
, add std_msgs
and message_generation
find_package(catkin REQUIRED COMPONENTS roscpp rospy std_msgs message_generation )
– Uncomment and replace add_message_files
with the following:
add_message_files( FILES my_msg.msg )
– Uncomment generate_messages
and replace with:
generate_messages(DEPENDENCIES std_msgs )
– Replace catkin_package
with the following:
catkin_package(CATKIN_DEPENDS rospy roscpp message_runtime)
– Add these lines under the build section to register the executable for building:
add_executable(custom_msg src/custom_msg.cpp) target_link_libraries(custom_msg ${catkin_LIBRARIES})
8. Try to build the package
user:~/catkin_ws$ catkin_make
This ends up with the following error
home/user/catkin_ws/src/custom_msg/src/custom_msg.cpp:1:31: fatal error: custom_msg/my_msg.h: No such file or directory compilation terminated.
Done here. We are able to reproduce the error. Now let’s fix it.
Step 3: Fix the problem and rejoice!
The above error says it cannot find the header file while building the C++ source. This is because we have not specified that this header file is a dependency and should be built first.
Add the following line to the build section of CMakeLists.txt
(under the lines added earlier). The format is add_dependencies(source_file_name package_name_generate_messages_cpp).
add_dependencies(custom_msg custom_msg_generate_messages_cpp)
Compile again and it should be, “voila!”:
user:~/catkin_ws$ rm -rf build/ devel/ user:~/catkin_ws$ catkin_make
I’m outta here :).
Extra: Video of the post
Edited by Bayode Aderinola
