[ROS Q&A] 188 – How do you extract multiple variables from a ROS message
Learn how to extract multiple variables from a ROS message, through a very simple example. This video answers the following question found on the ROS Answers forum: https://answers.ros.org/question/322896/how-do-you-extract-multiple-variables-from-a-message/. Let’s go!
  1. Use the ROS Development Studio (ROSDS), an online platform for developing for ROS within a PC browser. Easy-peasy. I’m using this option for this post.
    1. Once you log in, click on the New ROSject button to create a project that will host your code. Then Click on Open ROSject to launch the development/simulation environment.
    2. To open a “terminal” on ROSDS, pick the Shell app from the Tools menu.
    3. You can find the IDE app on the Tools menu.
  2. You have ROS installed on a local PC. Okay, skip to Step 2.
Next step!
Step 2: Launch a simulation
We are going to use a topic from a simulation of a robot. You may use any robot that has Odometry (/odom topic). For this post, we are using Turtlebot 2.
On ROSDS, start a Turtlebot 2 simulation from the simulations menu:
  • Simulations -> Use a provided simulation -> (Empty world) + Select a robot -> Turtlebot 2 > Start simulation.
Step 3: Find out the kind and structure of the message the Odometry topic uses
Open a terminal and run the following:
user:~$ rostopic info /odom
Type: nav_msgs/Odometry
Publishers:
 * /gazebo (http://rosdscomputer:37377/)
Subscribers: None
user:~$ rosmsg show nav_msgs/Odometry
std_msgs/Header header
  uint32 seq
  time stamp
  string frame_id
string child_frame_id
geometry_msgs/PoseWithCovariance pose
  geometry_msgs/Pose pose
    geometry_msgs/Point position
      float64 x
      float64 y
      float64 z
    geometry_msgs/Quaternion orientation
      float64 x
      float64 y
      float64 z
      float64 w
  float64[36] covariance
geometry_msgs/TwistWithCovariance twist
  geometry_msgs/Twist twist
    geometry_msgs/Vector3 linear
      float64 x
      float64 y
      float64 z
    geometry_msgs/Vector3 angular
      float64 x
      float64 y
      float64 z
  • First command (rostopic info): we found out the kind of message  – nav_msgs/Odometry.
  • Second command (rosmsg show): we found out the structure of the message.
Next, let’s examine the structure of the ROS message nav_msgs/Odometry:
  • It’s a fairly complex message as it contains a lot of nested variables.
  • The variables are arranged in hierarchical or tree form, with parent variable appearing without indentation. “Parent variables” here include
    • header
    • child_frame_id
    • pose
    • twist.
  • Some of the parent variables have children, grandchildren, and so on, which are also variables. These are indicated by the visual indents. For example,
    • header has three children.
    • pose has two children.
      • pose, which also has children position and orientation, which both have children too.
      • covariance, which has no children.
  • Every variable has a type, indicated just before the variable name. Type for …
    • header is std_msgs/Header.
    • pose -> pose -> position -> x is float64.
    • child_frame_id is string.
Next, let create a Python package and see how to access these variables in code.
Step 4: Create a package and extract these multiple variables from the message std_msgs/Odometry
Create a package and create a Python file. Please note that we are making the Python file executable with chmod +x, otherwise it won’t run!
user:~$ cd catkin_ws/src/
user:~/catkin_ws/src$ catkin_create_pkg extract_msg rospy
Created file extract_msg/CMakeLists.txt
Created file extract_msg/package.xml
Created folder extract_msg/src
Successfully created files in /home/user/catkin_ws/src/extract_msg. Please adjust the values in package.xml.
user:~/catkin_ws/src$ cd extract_msg/src/
user:~/catkin_ws/src/extract_msg/src$ touch extract_msg_node.py
user:~/catkin_ws/src/extract_msg/src$ chmod +x extract_msg_node.py
Open the extract_msg_node.py using the IDE and paste in the following code that extracts some of the multiple variables from the ROS message.
import rospy # the ROS api for python. We need it to create a node,
             # a subscriber and access other ROS-specific program control
from nav_msgs.msg import Odometry # Python message class for Odometry
rospy.init_node("extra_message_node")
msg = rospy.wait_for_message("/odom", Odometry)
print "Full message: \n"
print msg # that's the whole Odometry message. It should be something like
            # what was printed out by `rosmsg show nav_msgs/Odometry`
# print out each of the parent variables
print "\n Parent variables: \n"
print msg.header
print msg.child_frame_id
print msg.pose
print msg.twist
# print some children
print "\nSome children: \n"
print msg.header.frame_id
print msg.pose.pose
print msg.twist.twist
# print out some grandchildren
print "\nSome grandchildren: \n"
print msg.pose.pose.position
print msg.twist.twist.linear
# print out some great grandchildren :)
print "\nSome great grandchildren: \n"
print msg.pose.pose.orientation.w
print msg.twist.twist.angular.z
# print other (great grand) children below this line
print "\nOther ones you have specified: \n"
Run the program:
user:~$ rosrun extract_msg extract_msg_node.py
The program should run once and print out the extracted variables. Try adding your own variables.
And so that was it! I hope you were able to learn a thing or two from this post.
Extra: Video of the post
Edited by Bayode Aderinola
Pan & Tilt Gazebo Simulation
About
In this video you will learn:
  • How to create a Pan & Tilt Gazebo simulation
  • How to connect it to previous real robot server
List of materials
Related courses & tutorials
3D Models
#PanAndTilt #Pan&Tilt #Simulation #Gazebo #Robot #rostutorials #Ubuntu
[irp posts=”13154″ name=”Create ROS Server to Access Pan & Tilt”]
About
Learn how to create a ROS node server and some custom messages to access the real Pan & Tilt. This way any ROS program will be able to access the Pan & Tilt and will serve as the base for creating a simulation in the next video.
Git of Pan And Tilt Project
List of materials
3D Models
[ROS Q&A] 187 – Unable to use data received in callback function
Learn the proper use of ROS spin for a ROS subscriber so that the data received in the callback function can be accessed.  This is an answer to a question on the ROS Answers forum. Let’s go!
Next step!
Step 2: Create a ROS project containing the C++ code
Create a ROS project in your workspace
user:~$ cd ~/catkin_ws/src
user:~/catkin_ws/src$ catkin_create_pkg callback_fix roscpp
Created file callback_fix/package.xml
Created file callback_fix/CMakeLists.txt
Created folder callback_fix/include/callback_fix
Created folder callback_fix/src
Successfully created files in /home/user/catkin_ws/src/callback_fix. Please adjust the values in package.xml.
Create a C++ file in the project’s src folder and paste in the code specified below.
user:~/catkin_ws/src$ cd callback_fix/src
user:~/catkin_ws/src/callback_fix/src$ touch callback_fix_node.cpp
We are using a slightly modified version of the code here, using simpler message types since the driving_msg is not available.
#include "ros/ros.h"
#include "std_msgs/Int32.h"
#include <iostream>
using namespace std;
class server {
public:
  int totalobjects;
  void chatterCallback(const std_msgs::Int32 &msg);
void server::chatterCallback(const std_msgs::Int32 &msg) {
  totalobjects = msg.data;
  server objserver;
  ros::init(argc, argv, "listener");
  ros::NodeHandle n;
  ros::Subscriber sub =
      n.subscribe("/ground_truth", 1000, &server::chatterCallback, &objserver);
  ros::spin();
  cout << objserver.totalobjects;
  cout << "\n";
On ROSDS, pick the IDE from the Tools menu, locate the callback_code.cpp file and paste in the code.
Step 3: Prepare your C++ code for compilation and compile it
To ensure that our C++ code is runnable, we need to make some modifications to the CMakeLists.txt file. Please edit the following Build section of the file as follows.
We have simply uncommented the add_executable, add_dependencies and target_link_libraries directives.
PS: If your C++ file is named differently, you need to adjust the values accordingly. I have used the default name for the C++ file and its, which is ${PROJECT_NAME}_node.cpp (callback_fix_node.cpp). It’s executable will be generated without the .cpp suffix.
## Build ##
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/callback_fix.cpp
## Add cmake target dependencies of the library
## as an example, code may need to be generated before libraries
## either from message generation or dynamic reconfigure
# add_dependencies(${PROJECT_NAME} ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
## Declare a C++ executable
add_executable(${PROJECT_NAME}_node src/callback_fix_node.cpp)
add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(${PROJECT_NAME}_node
   ${catkin_LIBRARIES}
Compile the package. Go back to the Terminal and…
user:~/catkin_ws/src/callback_fix/src$ cd ~/catkin_ws/
user:~/catkin_ws$ catkin_make
Step 4: Run your package and experience the elusive output!
user:~/catkin_ws$ rosrun callback_fix callback_fix_node
PS: If you get a message indicating a connection cannot be made to the master, please stop the program, run nohup roscore & to start the master node in the background and then start your program again.
Open another terminal and publish to the ground_truth topic. You should see the published data in the terminal where you started in the callback_fix_node.
user:~$ rostopic pub /ground_truth std_msgs/Int32 "data: 55"
publishing and latching message. Press ctrl-C to terminate
Did something happen? I’d bet it didn’t, whew!
Now stop the callback_fix_node:
^C55
user:~/catkin_ws$
Huh, did you see that? The moment we stopped the node, the data we published appeared. That’s baloney, isn’t it? Let’s find out the fix in the next section.
Step 5: Fix the baloney (by implementing a proper use of ROS spin) and run the program again
In the callback_fix_node.cpp file, we can see that the print statements appear right after then ros::spin() statement! The problem is, anything after ros::spin() will not run until the program exits, because ros::spin() creates a loop that won’t exit until the program is interrupted!
In the v2 of the code below, use ros::spinOnce(), instead of ros::spin() to solve the problem:
1. Replace the int main() function with this snippet:
  server objserver;
  ros::NodeHandle n;
  ros::Rate loop_rate(1);
  while (ros::ok()) {
    ros::spinOnce();
    loop_rate.sleep();
    cout << "\n";
2. Compile the workspace again:
3.  Run the callback_fix_node again:
4. In the other terminal, publish to the ground_truth topic again and watch the output of the first terminal:
user:~$ rostopic pub /ground_truth std_msgs/Int32 "data: 67"
Now you should see the published data printed in the first terminal, in real-time. Try publishing other integers:
67
67
999
999
999
And that was it! I hope you have learned something about the proper use of ROS spin. See you in another post!
Extra: Video of this post
We made a video showing how we solved this challenge. If you prefer “sights and sounds” to “black and white”, here you go:
? Subscribe for more free ROS learning
[Morpheus Chair] Pan & Tilt with Raspberry Pi and ROS | S3.Ep.1
About
In this video, you are going to learn how to set up your raspberry pi to use the Pan & Tilt Hat created by WaveShare.
We will create a python class to move the two servos and test all its functionality.
Remember to leave a message of love to ANKI 😉 with the Hashtag #WeLoveYouANKI
List of materials
3D Models
