[ROS Q&A] 186 – How to store value from a subscribed topic in ROS in Python
About:
In the video of today, we are going to see how you can easily store a value from a subscribed topic into a variable in order to use it later for further purposes. In this case, we will use a global variable to do so.
? Subscribe for more free ROS learning: https://www.youtube.com/channel/UCt6Lag-vv25fTX3e11mVY1Q?sub_confirmation=1
RELATED ROS RESOURCES&LINKS:
ROS Development Studio (ROSDS) —▸ http://rosds.online
Robot Ignite Academy –▸ https://www.robotigniteacademy.com
If you want to learn about other ROS topics, please let us know on the comments area and we will do a video about it 🙂
#ROS #Robot #rostutorials
[Morpheus Chair] Vector ROSDS CloudConnection | T2.Ep.4
About:
In this video, you are going to learn how to connect to the real Vector ROBOT through ROSDS using the real robot connection tools. You will also use a docker created by betaB0t to connect to VECTOR.
Commands to launch the docker in your local PC:
sudo docker run -e ANKI_USER_EMAIL=(EMAIL) -e ANKI_USER_PASSWORD=(PASSWORD) -e VECTOR_IP=(VECTOR_IP) -e VECTOR_SERIAL=(VECTOR_SERIAL) -e VECTOR_NAME=(VECTOR_NAME) –network host -e ROS_IPV6=on -e ROS_HOSTNAME=(NAME_OF_YOUR_DEVICE) -e ROS_MASTER_URI=http://master:11311 –add-host master:::1 –add-host (NAME_OF_YOUR_DEVICE):::1 -it betab0t/vector-ros-driver
If you don’t know the VECTRO related values, please have a look at the first video where we connected directly to VECTOR:
ROSject with Simulation and code Plug and Play:
http://www.rosject.io/l/908ce19/
Git from BetaB0t for Vector_ROS Package:
Git for the Real Robot Connection Setup:
https://bitbucket.org/theconstructcore/rosds_real_robot_connection/src/master/
Git of Vector and Cozmo Simulation:
https://bitbucket.org/theconstructcore/cozmo_simulation/src/master/
Install SDK in ALL OS:
https://developer.anki.com/vector/docs/initial.html
VECTOR API:
https://developer.anki.com/vector/docs/api.html
Here you can find the list of materials that you will need for this session:
Vector Robot: https://www.amazon.es/Anki-000-0079-Vector/dp/B078T42JCM
Vector Robot Playing Space ( recommended to avoid any problems with flying Vectors :P): https://www.amazon.es/Anki-000-0078-Habitat-Vector-Space/dp/B07G3QSX8G
Music:
Original Track:https://youtu.be/FBv6rm1lY0w
Thanks to NewRetroWave for letting us use their music.
Here more info:
New Retro Wave + Bachelor of Hearts Aurora Borealis
Smooth vibes for you retro soul. Listen and enjoy.
OUT NOW on NRW Records:
https://newretrowave.bandcamp.com/album/a-cosmic-funk-odyssey-ep
iTunes: http://apple.co/2r6N1T7
Support:
https://www.facebook.com/BachelorOfHeartsmusic/
Artwork provided by Murryous, who is our featured artist for May. Please support him:
https://www.instagram.com/murryous/
3D Models:
Orange Robot:
https://www.blendswap.com/blends/view/77718
Sphere Robot:
https://www.blendswap.com/blends/view/80818
Robot Parts:
https://www.blendswap.com/blends/view/78357
Mars Lander:
https://www.blendswap.com/blends/view/81264
#VECTOR #COZMO #ANKI #ROS #Robot #rostutorials #simulation to real
[ROS Q&A] 185 – 2D Drone Navigation (Part 4 Get Odometry from Laser readings)
About:
In the video of today, we are going to see how you can generate Odometry data from the Drone’s laser readings (using the rf2o_laser_odometry package). Then, we will use this Odometry data in order to perform Navigation.
Get the full code of this video with this ROSject Link –▸ http://www.rosject.io/l/913ce36/
Quadrotor simulation –▸ https://bitbucket.org/theconstructcor…
rf2o_laser_odometry –▸ https://github.com/MAPIRlab/rf2o_laser_odometry
[Morpheus Chair] Vector ROS Simulation | T2.Ep.3
  • Learn how to launch the Vector simulation and how to launch a Red Ball tracking node using ROS and the
    package created by BetaB0t Vector_ROS
More resources (for real robot)
Launching COZMO and VECTOR simulations
If you click in the ROSject provided above (http://www.rosject.io/l/908ce19/), you will get a copy of it on ROSDS (ROS Development Studio)
To launch it, you first need to open the ROSject clicking on the Open button.
Open Cozmo and Vector robots in ROSDS
Once the ROSject open, you just launch the simulation by clicking  Simulations–>Select Launch File, then you select  cozmo_gazebo main_cozmo.launch
Launch cozmo_gazebo main_vector.launch in ROSDS
If everything went ok, now you should have the simulation up and running:
cozmo vector running in ROSDS
You can launch cozmo and vector just by choosing between the main_vector.launch and main_cozmo.launch
You can access the camera, the forklift, the wheels (through the /cmd_vel ROS Topic), imu and the Infra-Red sensors form their corresponding topics. All the topics have the exact same name in the two different robots, except that you have to change the word vector for cozmo.
Launching the Simple Red Ball tracking
To do so you have to launch the simulation you want, in this case, we will launch the Vector simulation as described in the previous section.
Then open a Webshell from the Tools Bar (Tools -> Shell), and execute the following commands:
roslaunch vector_ros simple_ball_tracker.launch is_simulation:=true
You should then Open the Graphical Tools from the Tools menu to see the RedBall detection Gui:
Launching Graphical Tools in ROSDS
You should then be able to see the robot camera:
redball seen by cozmo and vector in ROSDS
If you now move the ball around with the move object icon of the 3D view, you can see how Vector follows the ball. You can also move the ball with the keyboard, which will send absolute position commands to the ball. You first need to run the launch file below:
roslaunch cozmo_gazebo move_redball.launch
Then use the Keys below:
i“=+X Axis,
k“=STOP,
j“=-Y Axis,
l“=+Y Axis,
,“=-X Axis:
Moving the robot around
With the ball tracking enabled, you can move the robot around using the command below in the web shell:
Reccomended values:
    turn = 5.55991731349
    speed = 0.1937102445
Seeing the camera
In order to see the camera in the Graphical Tools, you can run rqt_image_view through the webshell using the command below:
rosrun rqt_image_view rqt_image_view
Now open the Graphical Interface as explained earlier by clicking Tools -> Graphical Tools.
Moving FORK and Head
Before publishing the positions of the fork, it is worth mentioning that the fork range is [0.0,-0.8]
Now, let’s go ahead and move it with the command below:
rostopic pub /vector/lift_height/command std_msgs/Floa4 "data: -0.8"
Now, to move the head we use the commands below. Also, important to note that the range of the head is [0.1,-0.57]
Let’s then move the head:
rostopic pub /vector/head_angle/command std_msgs/Float64 "data: -0.57"
Where is the IMU
To see the IMU of the robot, you can see the /imu topic using the command below:
rostopic echo /imu
Current known issues
We noticed that there is a drift that occurs when Vector or Cozmo is still.
SPECIAL THANKS:
Our special thanks to beat_b0t for creating the Vector_ROS package.
Also, thanks to TheConstructSim For creating the COZMO and Vector simulation package. and thanks to ANKI for creating COZMO and VECTOR real robots that we can use to play around and learn more about robotics.
Youtube Video
We hope you like the post. If you prefer, we also have a live version of this post in YouTube. You can find it in the link below. If you like it, please consider subscribing to our channel on youTube. We are constantly adding new ROS-related content.
Music:
Here more info:
Support:
3D Models:
Orange Robot:
Sphere Robot:
Robot Parts:
Mars Lander:
#Vector #COZMO #ANKI #ROS
[ROS Q&A] 183 – 2D Drone Navigation with ROS (Part 3 Path Planning)
About:
In the video of today, we are going to see how to easily navigate your robot autonomously, with Path Planning, in an indoor environment using a drone and the ROS move_base node from the Navigation Stack.
Get the full code of this video with this ROSject Link –▸ http://www.rosject.io/l/8797919/
depthimage_to_laserscan –▸ http://wiki.ros.org/depthimage_to_las…
Turtlebot Navigation –▸ http://wiki.ros.org/turtlebot_navigation
