[ROS Q&A] 128 – Can’t access messages of the ROS topic Publisher
In this video we are going to see why a user can’t access the message that he is publishing into a topic using a ROS Publisher.
This is a video trying to answer the following question posted at the ROS answers forum: https://answers.ros.org/question/293898/init_node-need-locating-after-publisher/
We can do any ROS development we want easily, without setting up environment locally in ROSDS and that’s the reason why we will use ROSDS for this tutorial. If you haven’t had an account yet. You can create one here for free now. After logging in, let’s begin our journey by clicking on the create new project and call it pub_example.
Step 2. Create a new package for testing
Now, let’s create a new package for testing with the following command
cd ~/catkin_ws/src/
catkin_create_pkg pub_example rospy
Then we create a new file called pub_ex.py under /pub_example/src with copying and pasting the following code.
# license removed for brevity
def talker():
    rospy.init_node('talker')
    pub = rospy.Publisher('chatter', String, queue_size=10)
    hello_str = "hello world %s" % rospy.get_time()
    pub.publish(hello_str)
    rospy.loginfo(hello_str)
    talker()
NOTICE: We no longer run ROS master for you in the backend, please launch it with the command roscore in a new terminal.
Now you can run it with the command rosrun pub_example pub_ex.py
You will get the output hello world, however, if you check with rostopic list , there is no chatter topic.
It turns out the talker function only publish once and was killed. If we want to access it, we have to keep publishing it. Let’s change our code.
def talker():
    rate = rospy.Rate(1) # this defines the publish rate
        # put everything in a while loop to keep publishiing topic
        rate.sleep() # this make sure that the topic is publishing at 1 Hz
When you run it again, you can see that the topic is publishing every 1 second and you can access it from other node.
RELATED LINKS & RESOURCES
▸ Original question: https://answers.ros.org/question/293898/init_node-need-locating-after-publisher/
▸ Robot Ignite Academy
▸ ROS Basics in 5 days Course (Python)
