[ROS Q&A] 144 – What is the difference between ROS topics and messages?
In this video we are going to explain and show in a practical way the difference between ROS topics and messages.
We show two nodes running, one publishing to a given topic and another subscribing to this same topic. RQT graph is used to see the big picture of the environment.
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it ros_q_a_topics_messages.
Step 1. Difference between ros topic and ros message
We’ll start by creating a package for the code in catkin_ws
cd catkin_ws/src catkin_create_pkg my_pkg rospy std_msgs
Let’s also create a scripts folder for our scripts. Then two script called my_subscriber.py and my_publisher.py file in it with the following content.
#!/usr/bin/env python import rospy from std_msgs.msg import String def main(): pub = rospy.Publisher('my_topic', String, queue_size=10) rospy.init_node('my_publisher') rate = rospy.Rate(1) while not rospy.is_shutdown(): hello_str = 'hello world %s' % rospy.get_time() rospy.loginfo(hello_str) pub.publish(hello_str) rate.sleep() if __name__ == '__main__': try: main() except rospy.ROSInterruptExeception: pass
Basically, a message is data through a channel called topic. In this code, the message is String type and the topic is called my_topic.
#!/usr/bin/env python import rospy from std_msgs import String def main(): pub = rospy.Publisher('my_topic', String, queue_size = 10) rospy.init_node('my_publisher') rate = rospy.Rate(1) while not rospy.is_shutdown(): hello_str = "hello world %s" % rospy.get_time() rospy.loginfo(hello_str) pub.publish(hello_str) rate.sleep() if __name__ == '__main__' : try: main() except rospy.ROSInterruptExeception: pass
This script established a subscriber for the message through the topic my_topic.
To run the code, we have to give the scripts permission to execute with chmod +x my_publisher.py and chmod +x my_subscriber.py
Then we can run it with
cd catkin_ws catkin_make source devel/setup.bash rosrun my_pkg my_publisher.py
You should see the publisher is publishing message into the topic.
Open another shell and run
rosrun my_pkg my_subscriber.py
Open the third shell and type rqt_graph , then go to Tools->graphical tool to open the GUI.
You should see the nodes are marked with circles. You can find the /my_publisher and /my_subscriber nodes in the graph.
The topic is marked with the square. In this example, the topic is called my_topic. The two node is communicating though this topic.
If you are interested in learning ROS, please check our ROS Basics Python course.
RELATED LINKS
▸ Original question: https://answers.ros.org/question/63511/what-is-the-difference-between-a-topic-and-a-message/
▸ Robot Ignite Academy
▸ ROS Basics Python
▸ ROS Basics C++
