How to integrate OpenCV with a ROS2 C++ node
In this post, you will learn how to integrate the OpenCV library with a ROS2 C++ node. The example shown builds into a “hello-world” binary for ROS2 integration with OpenCV that publishes an image to the ROS network.
After going through this post, you would be able to use OpenCV to do things related to image processing and computer vision and make the results available to other ROS2 nodes. The example uses ROS2 Humble.
“Hey, do I have to install ros2 first?” Absolutely not! Just log in to The Construct to get access to virtual machines pre-installed with ROS.
Create a new Rosject
Step 2: Verify that OpenCV is installed
All ROS installs include OpenCV, so verify whether OpenCV has been installed.
Open Code Editor
Open a web shell
Open a web shell and run the following command:
pkg-config --modversion opencv4
You should get a version number similar to this:
4.5.4
If the above output is similar to what you see, you are set and ready, everything should work. Otherwise, please install OpenCV using the following command:
sudo apt install libopencv-dev python3-opencv
Step 3: Create a ROS2 C++ node integrating the OpenCV library
First, we need to create a package. We need the following dependencies for the package:
  • rclcpp – this is the ros2 C++ API we’ll use to create the ros2 node
  • std_msgs – needed for sending message header while sending the image
  • sensor_msgs – needed for sending the image itself
  • cv_bridge – converts from the OpenCV image format to the ros2 image format
  • image_transport – compresses the image for transport within the ros2 network
  • OpenCV – generates the image we want to send
Run the following command in the terminal you used in Step 2, to create the package:
cd ~/ros2_ws/src
ros2 pkg create my_opencv_demo --dependencies rclcpp std_msgs sensor_msgs cv_bridge image_transport OpenCV
Now go to the src folder of the package you just created and create the C++ file that will define the node:
cd ~/ros2_ws/src/my_opencv_demo/src
touch minimal_opencv_ros2_node.cpp
Open the Code Editor, locate the C++ file you just created, and paste the code indicated below. Explanations are given as comments within the code.
#include "rclcpp/rclcpp.hpp"
#include "sensor_msgs/msg/image.hpp"
#include "std_msgs/msg/header.hpp"
#include <chrono&gt;
#include <cv_bridge/cv_bridge.h&gt; // cv_bridge converts between ROS 2 image messages and OpenCV image representations.
#include <image_transport/image_transport.hpp&gt; // Using image_transport allows us to publish and subscribe to compressed image streams in ROS2
#include <opencv2/opencv.hpp&gt; // We include everything about OpenCV as we don't care much about compilation time at the moment.
using namespace std::chrono_literals;
class MinimalImagePublisher : public rclcpp::Node {
public:
  MinimalImagePublisher() : Node("opencv_image_publisher"), count_(0) {
    publisher_ =
        this-&gt;create_publisher<sensor_msgs::msg::Image&gt;("random_image", 10);
    timer_ = this-&gt;create_wall_timer(
        500ms, std::bind(&amp;MinimalImagePublisher::timer_callback, this));
private:
  void timer_callback() {
    // Create a new 640x480 image
    cv::Mat my_image(cv::Size(640, 480), CV_8UC3);
    // Generate an image where each pixel is a random color
    cv::randu(my_image, cv::Scalar(0, 0, 0), cv::Scalar(255, 255, 255));
    // Write message to be sent. Member function toImageMsg() converts a CvImage
    // into a ROS image message
    msg_ = cv_bridge::CvImage(std_msgs::msg::Header(), "bgr8", my_image)
               .toImageMsg();
    // Publish the image to the topic defined in the publisher
    publisher_-&gt;publish(*msg_.get());
    RCLCPP_INFO(this-&gt;get_logger(), "Image %ld published", count_);
    count_++;
  rclcpp::TimerBase::SharedPtr timer_;
  sensor_msgs::msg::Image::SharedPtr msg_;
  rclcpp::Publisher<sensor_msgs::msg::Image&gt;::SharedPtr publisher_;
  size_t count_;
  rclcpp::init(argc, argv);
  // create a ros2 node
  auto node = std::make_shared<MinimalImagePublisher&gt;();
  // process ros2 callbacks until receiving a SIGINT (ctrl-c)
  rclcpp::spin(node);
  rclcpp::shutdown();
Finally, edit the package’s CMakeLists.txt (~/ros2_ws/src/my_opencv_demo/CMakeLists.txt) file to recognize the node. Copy the lines of code shown below and paste them before the invocation of ament_package():
add_executable(minimal_opencv_ros2_node src/minimal_opencv_ros2_node.cpp)
ament_target_dependencies(minimal_opencv_ros2_node rclcpp std_msgs sensor_msgs cv_bridge image_transport OpenCV)
install(TARGETS
The CMakeLists.txt file should now look like this:
project(my_opencv_demo)
endif()
# find dependencies
find_package(rclcpp REQUIRED)
find_package(std_msgs REQUIRED)
find_package(sensor_msgs REQUIRED)
find_package(cv_bridge REQUIRED)
find_package(image_transport REQUIRED)
find_package(OpenCV REQUIRED)
if(BUILD_TESTING)
  # comment the line when a copyright and license is added to all source files
  # comment the line when this package is in a git repo and when
  # a copyright and license is added to all source files
endif()
install(TARGETS
ament_package()
Congratulations! You have created a ros2 C++ node integrating OpenCV. Now, we need to see if it works!
Step 4: Compile and test ROS2 C++ node integrating the OpenCV library
Generate the ros2 executable by compiling and sourcing the package:
colcon build --packages-select my_opencv_demo
If you got to this point, great! Now we will run the node:
ros2 run my_opencv_demo minimal_opencv_ros2_node
You should see some output similar to this:
[INFO] [1677071986.446315963] [opencv_image_publisher]: Image 0 published
[INFO] [1677071986.941745471] [opencv_image_publisher]: Image 1 published
[INFO] [1677071987.442009334] [opencv_image_publisher]: Image 2 published
[INFO] [1677071987.941677164] [opencv_image_publisher]: Image 3 published
[INFO] [1677071988.441115565] [opencv_image_publisher]: Image 4 published
[INFO] [1677071988.940492910] [opencv_image_publisher]: Image 5 published
[INFO] [1677071989.441007118] [opencv_image_publisher]: Image 6 published
Now let’s run ros2 topic list to confirm the existence of the image topic. Leave the node running in the current terminal and run the following command in a new terminal:
ros2 topic list
The output should inclide the /random_image topic:
/parameter_events
/random_image
Finally lets us see what the image produced by OpenCV looks like. Run the following in the same terminal where you ran ros2 topic list. If you get the error, (image_view:8839): Gdk-ERROR **: 13:30:34.498: The program 'image_view' received an X Window System error, just run the command again.
ros2 run image_view image_view --ros-args --remap image:=/random_image
You should now see something like this pop up on your screen. Yahoo!
Random image output from the OpenCV node
Great job! You have successfully created a ros2 C++ node integrating OpenCV!
Step 5: Extra: add text to the Image
Copy the lines of code shown below and paste them inside the timer callback function just before writing the message to be sent:
    // Declare the text position
    cv::Point text_position(15, 40);
    // Declare the size and color of the font
    int font_size = 1;
    cv::Scalar font_color(255, 255, 255);
    // Declare the font weight
    int font_weight = 2;
    // Put the text in the image
    cv::putText(my_image, "ROS2 + OpenCV", text_position, cv::FONT_HERSHEY_COMPLEX, font_size, font_color, font_weight);
Stop the currently running node, recompile and source the package, and re-run the node. You should now see something like this:
Random image with text from the OpenCV node
Step 6: Check your learning
Do you understand how to create a ros2 C++ node integrating OpenCV? If you don’t know it yet, please go over the post again, more carefully this time.
(Extra) Step 7: Watch the video to understand how to integrate the OpenCV library with a ROS2 C++ node
If you want to learn more about ROS 2 and dive deeper into robotics, check out the Robotics Developer Masterclass, where you’ll master robotics development from scratch and get 100% job-ready to work at robotics companies.
Did you like this post? Do you have any questions about how to integrate the OpenCV library with a ROS2 C++ node? Please leave a comment in the comments section below, so we can interact and learn from each other.
How to introspect ROS 2 executables
In this post, you will learn how to introspect ROS 2 executables by identifying publishers and subscribers in the executables. This answers this question posted on ROS Answers.
Step 1: Copy sample packages containing ROS 2 executables
Click here to copy the ROS2 TurtleBot3 sandbox packages. Once copied, click the red RUN button to launch the packages in a virtual machine. Please be patient while the environment loads.
PS: You will need to login or create an account to copy the packages.
You might also want to try this on a local PC if you have ros2 and some executables installed. However, please note that we cannot support local PCs and you will have to fix any errors you run into on your own. The rest of the instruction assumes that you are working on The Construct; please adapt them to your local PC and ros2 installation.
Step 2: Explore the source code of an ament_python package
You can know what topics are being used by an executable (that is, introspect it) without running it by checking its source code, looking for publishers and subscribers.
Now head over to the Code Editor to make to explore the source code of the packages you just copied.
First, we look at the turtlebot3_teleop package.
Turtblebot3 Teleop package
Let’s look for the executable file for this package. We can find that in the setup.py file.
turtlebot3_teleop/setup.py
from setuptools import find_packages
from setuptools import setup
package_name = 'turtlebot3_teleop'
setup(
    name=package_name,
    version='2.1.2',
    packages=find_packages(exclude=[]),
    data_files=[
        ('share/ament_index/resource_index/packages', ['resource/' + package_name]),
    install_requires=[
        'setuptools',
    zip_safe=True,
    author='Darby Lim',
    author_email='thlim@robotis.com',
    maintainer='Will Son',
    maintainer_email='willson@robotis.com',
    keywords=['ROS'],
    classifiers=[
        'Intended Audience :: Developers',
        'License :: OSI Approved :: Apache Software License',
        'Programming Language :: Python',
        'Topic :: Software Development',
    description=(
        'Teleoperation node using keyboard for TurtleBot3.'
    license='Apache License, Version 2.0',
    tests_require=['pytest'],
    entry_points={
        'console_scripts': [
            'teleop_keyboard = turtlebot3_teleop.script.teleop_keyboard:main'
Looking at the entry_points part of the file, and then the console_scripts, we find the executable file is in the turtlebot3_teleop/script/teleop_keyboard.py file. Let’s find the publishers and/subscribers for this executable.
def main():
    settings = None
    if os.name != 'nt':
        settings = termios.tcgetattr(sys.stdin)
    rclpy.init()
    qos = QoSProfile(depth=10)
    node = rclpy.create_node('teleop_keyboard')
    pub = node.create_publisher(Twist, 'cmd_vel', qos)
    status = 0
    target_linear_velocity = 0.0
    target_angular_velocity = 0.0
    control_linear_velocity = 0.0
    control_angular_velocity = 0.0
        print(msg)
        while(1):
            key = get_key(settings)
            if key == 'w':
                target_linear_velocity =\
                    check_linear_limit_velocity(target_linear_velocity + LIN_VEL_STEP_SIZE)
                status = status + 1
                print_vels(target_linear_velocity, target_angular_velocity)
            elif key == 'x':
                    check_linear_limit_velocity(target_linear_velocity - LIN_VEL_STEP_SIZE)
                status = status + 1
            elif key == 'a':
                target_angular_velocity =\
                    check_angular_limit_velocity(target_angular_velocity + ANG_VEL_STEP_SIZE)
                status = status + 1
            elif key == 'd':
                    check_angular_limit_velocity(target_angular_velocity - ANG_VEL_STEP_SIZE)
                status = status + 1
            elif key == ' ' or key == 's':
                if (key == '\x03'):
                    break
            if status == 20:
                print(msg)
                status = 0
            twist = Twist()
            control_linear_velocity = make_simple_profile(
                control_linear_velocity,
                (LIN_VEL_STEP_SIZE / 2.0))
            twist.linear.x = control_linear_velocity
            twist.linear.y = 0.0
            twist.linear.z = 0.0
            control_angular_velocity = make_simple_profile(
                control_angular_velocity,
                target_angular_velocity,
                (ANG_VEL_STEP_SIZE / 2.0))
            twist.angular.x = 0.0
            twist.angular.y = 0.0
            twist.angular.z = control_angular_velocity
            pub.publish(twist)
    except Exception as e:
        print(e)
    finally:
        twist = Twist()
        twist.linear.x = 0.0
        twist.angular.z = 0.0
        pub.publish(twist)
        if os.name != 'nt':
            termios.tcsetattr(sys.stdin, termios.TCSADRAIN, settings)
Success! On line 148 we can find that the executable creates a publisher to the /cmd_vel topic, so we know this is a topic used by the executable.
Are there other topics used by this executable? Find out!
Step 3: Explore the source code of an ament_cmake package
Let explore the turtlebot3_node package.
Turtlebot3_node package
We can find the main executable in the CMakeLists.txt file in the add_executable line (line 75).
turtlebot3_node/CMakeLists.txt
# Set minimum required version of cmake, project name and compile options
cmake_minimum_required(VERSION 3.5)
project(turtlebot3_node)
if(NOT CMAKE_CXX_STANDARD)
  set(CMAKE_CXX_STANDARD 14)
endif()
endif()
# Find ament packages and libraries for ament and system dependencies
find_package(dynamixel_sdk REQUIRED)
find_package(geometry_msgs REQUIRED)
find_package(message_filters REQUIRED)
find_package(nav_msgs REQUIRED)
find_package(rcutils REQUIRED)
find_package(std_srvs REQUIRED)
find_package(tf2 REQUIRED)
find_package(tf2_ros REQUIRED)
find_package(turtlebot3_msgs REQUIRED)
# Build
include_directories(
  include
add_library(${PROJECT_NAME}_lib
  "src/devices/motor_power.cpp"
  "src/devices/sound.cpp"
  "src/devices/reset.cpp"
  "src/diff_drive_controller.cpp"
  "src/dynamixel_sdk_wrapper.cpp"
  "src/odometry.cpp"
  "src/turtlebot3.cpp"
  "src/sensors/battery_state.cpp"
  "src/sensors/imu.cpp"
  "src/sensors/joint_state.cpp"
  "src/sensors/sensor_state.cpp"
set(DEPENDENCIES
  "dynamixel_sdk"
  "geometry_msgs"
  "message_filters"
  "nav_msgs"
  "rclcpp"
  "rcutils"
  "sensor_msgs"
  "std_msgs"
  "std_srvs"
  "tf2"
  "tf2_ros"
  "turtlebot3_msgs"
target_link_libraries(${PROJECT_NAME}_lib)
ament_target_dependencies(${PROJECT_NAME}_lib ${DEPENDENCIES})
set(EXECUTABLE_NAME "turtlebot3_ros")
add_executable(${EXECUTABLE_NAME} src/node_main.cpp)
target_link_libraries(${EXECUTABLE_NAME} ${PROJECT_NAME}_lib)
ament_target_dependencies(${EXECUTABLE_NAME} ${DEPENDENCIES})
# Install
install(DIRECTORY param
  DESTINATION share/${PROJECT_NAME}
install(TARGETS ${EXECUTABLE_NAME}
# Macro for ament package
ament_export_include_directories(include)
ament_package()
So we see that the main executable is src/node_main.cpp. Let’s examine it.
turtlebot3_node/src/node_main.cpp
// Copyright 2019 ROBOTIS CO., LTD.
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//     http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
// Author: Darby Lim
#include <rcutils/cmdline_parser.h>
#include <rclcpp/rclcpp.hpp>
#include <chrono>
#include <memory>
#include <string>
#include "turtlebot3_node/diff_drive_controller.hpp"
#include "turtlebot3_node/turtlebot3.hpp"
void help_print()
  printf("For turtlebot3 node : \n");
  printf("turtlebot3_node [-i usb_port] [-h]\n");
  printf("options:\n");
  printf("-h : Print this help function.\n");
  printf("-i usb_port: Connected USB port with OpenCR.");
int main(int argc, char * argv[])
  setvbuf(stdout, NULL, _IONBF, BUFSIZ);
  if (rcutils_cli_option_exist(argv, argv + argc, "-h")) {
    help_print();
  std::string usb_port = "/dev/ttyACM0";
  char * cli_options;
  cli_options = rcutils_cli_get_option(argv, argv + argc, "-i");
  if (nullptr != cli_options) {
    usb_port = std::string(cli_options);
  rclcpp::executors::SingleThreadedExecutor executor;
  auto turtlebot3 = std::make_shared<robotis::turtlebot3::TurtleBot3>(usb_port);
  auto diff_drive_controller =
    std::make_shared<robotis::turtlebot3::DiffDriveController>(
    turtlebot3->get_wheels()->separation,
    turtlebot3->get_wheels()->radius);
  executor.add_node(turtlebot3);
  executor.add_node(diff_drive_controller);
  executor.spin();
  rclcpp::shutdown();
There’s no reference to a publisher or subscriber in this file, but it references some other files. Let’s look at the turtlebot3_node/turtlebot3.cpp file referenced on line 25.
turtlebot3_node/src/turtlebot3.cpp
void TurtleBot3::cmd_vel_callback()
  auto qos = rclcpp::QoS(rclcpp::KeepLast(10));
  cmd_vel_sub_ = this->create_subscription<geometry_msgs::msg::Twist>(
    "cmd_vel",
    qos,
    [this](const geometry_msgs::msg::Twist::SharedPtr msg) -> void
      std::string sdk_msg;
      union Data {
        int32_t dword[6];
        uint8_t byte[4 * 6];
      } data;
      data.dword[0] = static_cast<int32_t>(msg->linear.x * 100);
      data.dword[1] = 0;
      data.dword[2] = 0;
      data.dword[3] = 0;
      data.dword[4] = 0;
      data.dword[5] = static_cast<int32_t>(msg->angular.z * 100);
      uint16_t start_addr = extern_control_table.cmd_velocity_linear_x.addr;
      uint16_t addr_length =
      (extern_control_table.cmd_velocity_angular_z.addr -
      extern_control_table.cmd_velocity_linear_x.addr) +
      extern_control_table.cmd_velocity_angular_z.length;
      uint8_t * p_data = &amp;data.byte[0];
      dxl_sdk_wrapper_->set_data_to_device(start_addr, addr_length, p_data, &amp;sdk_msg);
      RCLCPP_DEBUG(
        this->get_logger(),
        "lin_vel: %f ang_vel: %f msg : %s", msg->linear.x, msg->angular.z, sdk_msg.c_str());
Success! We see the /cmd_vel is also referenced on line 313. Can you find other files linked to the main file and it’s linked files, where other topics are referenced?
Step 4: Check your learning
Do you understand how to introspect ROS 2 executables? If you don’t know it yet, please go over the post again, more carefully this time.
(Extra) Step 5: Watch the video to understand how to introspect ROS 2 executables
Did you like this post? Do you have any questions about how to introspect ROS 2 executables? Please leave a comment in the comments section below, so we can interact and learn from each other.
How to create a ros2 C++ Library
In this post, you will learn how to create and use your own ros2 C++ library. I’ll show you how to create the library and then use it in a demo package.
Once logged in, click on My Rosjects, then Create a New Rosject, supply the information as shown in the video and click Create. Then RUN the rosject.
Step 2: Create a new package that contains the library’s source code (logic)
Open Code Editor
Open a web shell
cd ros2_ws/src
source /opt/ros/humble/setup.bash/
ros2 pkg create my_value_converter_library --build-type ament_cmake --license BSD-3-Clause
Now that your package is created, we need to create a header file for the library. Move inside the include/my_value_converter_library directory and create a header file named library_header.h.
cd ~/ros2_ws/src/my_value_converter_library/include/my_value_converter_library
touch library_header.h
Now head over to the Code Editor to make changes to the header file. Check the image below for how to open the Code Editor.
Locate the header file in the code editor: ros2_ws > src > my_value_converter_library > include > my_value_converter_library > library_header.h and paste in the following code.
#ifndef MAP_VALUE_H
#define MAP_VALUE_H
double map_value(double x, double in_min, double in_max, double out_min, double out_max);
#endif
Next, we create the C++ source code file for the library. In the same web shell:
cd ~/ros2_ws/src/my_value_converter_library/src
touch my_value_converter_library.cpp
Locate the my_value_converter_library.cpp file in the code editor and paste in the following code:
#include "my_value_converter_library/library_header.h"
double map_value(double x, double in_min, double in_max, double out_min, double out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Now we need to edit the CMakeLists.txt file of our package to recognize the source code we have just added. Open the file ros2_ws > src > my_value_converter_library > CMakeLists.txt and add the following lines before the ament_package() call.
# let the compiler search for headers in the include folder
# define a library target called my_value_converter_library
add_library(my_value_converter_library src/my_value_converter_library.cpp)
# this line to exports the library
ament_export_targets(my_value_converter_library HAS_LIBRARY_TARGET)
# install the include/my_cpp_library directory to the install/include/my_cpp_library
install(
  DIRECTORY include/my_value_converter_library
  DESTINATION include
install(
  TARGETS my_value_converter_library
  EXPORT my_value_converter_library
  LIBRARY DESTINATION lib
  ARCHIVE DESTINATION lib
  RUNTIME DESTINATION bin
  INCLUDES DESTINATION include
colcon build
Success! We have now created our library. Next, we are going to use it!
Step 3: Create a new package that uses the library you just created
Create the new package in the open shell. Note that my_value_converter_library is passed as a dependency during the creation of the new package. This will simplify some of the work that needs to be done when modifying the CMakeLists.txt file.
cd ros2_ws/src
ros2 pkg create my_value_converter_node --build-type ament_cmake --license BSD-3-Clause --dependencies rclcpp std_msgs my_value_converter_library
Now verify that the dependencies have been properly added. If the build runs successfully, it is so. If not, please correct the errors before you proceed.
colcon build
If you got to this point, great! Now we will create the C++ source code that will use your library.
cd ~/ros2_ws/src/my_value_converter_node/src
touch my_value_converter_node.cpp
Now locate the my_value_converter_node.cpp file in the code editor and paste in the following source code.
#include <memory>
#include <string>
#include "std_msgs/msg/float32.hpp"
class ConverterNode : public rclcpp::Node {
public:
  explicit ConverterNode() : Node("converter_node") {
    auto callback =
        [this](const std_msgs::msg::Float32::SharedPtr input_msg) -> void {
      RCLCPP_DEBUG(this->get_logger(), "I heard: [%f]", input_msg->data);
      // Use the library
      // Map an value from 0 - 1023 range to -1.0 to +1.0 range
      double new_value = map_value(input_msg->data, 0, 1023, -1.0, 1.0);
      output_msg_ = std::make_unique<std_msgs::msg::Float32>();
      output_msg_->data = new_value;
      RCLCPP_DEBUG(this->get_logger(), "Publishing: '%f'", output_msg_->data);
      pub_->publish(std::move(output_msg_));
    sub_ = create_subscription<std_msgs::msg::Float32>("output_topic", 10,
                                                       callback);
    // Create a publisher
    rclcpp::QoS qos(rclcpp::KeepLast(7));
    pub_ = this->create_publisher<std_msgs::msg::Float32>("input_topic", qos);
private:
  std::unique_ptr<std_msgs::msg::Float32> output_msg_;
  rclcpp::Publisher<std_msgs::msg::Float32>::SharedPtr pub_;
  rclcpp::Subscription<std_msgs::msg::Float32>::SharedPtr sub_;
  auto node = std::make_shared<ConverterNode>();
  RCLCPP_INFO(node->get_logger(), "My value converter node started.");
  rclcpp::spin(node);
  rclcpp::shutdown();
As you might have expected, we need to modify the CMakeLists.txt file for our new package. Locate the ros2_ws > src > my_value_converter_node > CMakeLists.txt in the code editor and paste in the following code before the ament_package() call.
# define the binary to be built and identify the source files with with which to build it
add_executable(main src/my_value_converter_node.cpp)
# tell CMake that the executable "main" depends on the library "my_value_converter_library"
ament_target_dependencies(main my_value_converter_library rclcpp std_msgs)
# install the executable in the lib folder to make it detectable through setup.bash
install(TARGETS
  main
  DESTINATION lib/${PROJECT_NAME}/
Now build and use your package!
colcon build
ros2 run my_value_converter_node main
Do you understand how to create a ros2 C++ library? If you don’t know it yet, please go over the post again, more carefully this time.
(Extra) Step 5: Watch the video to understand how to install a ros2 binary package
Did you like this post? Do you have any questions about how to create a ros2 C++ library? Please leave a comment in the comments section below, so we can interact and learn from each other.
How to install a ros2 binary package
In this post, you will learn how to install a ros2 binary package and make it available for use. This post was written in response to this question on ROS Answers.
“Hey, do you mean I have to install ros2 first?” Absolutely not! Just login to The Construct to get access to virtual machines pre-installed with ROS.
Step 2: Check the ros2 binaries currently installed
Open Code Editor
Open a web shell
Open a web shell and run the following commands. You should see a long list of many binaries!
cd /opt/ros/foxy/share/
ls -al
ROS binaries are stored in /opt/ros/{distro}/share/ If you would like to check if some binary is already installed without going through the long list, use grep. In this case we want to check binaries related to joint_state.
user:/opt/ros/foxy/share$ ls -al | grep joint_state
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_broadcaster
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_controller
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_publisher
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_publisher_gui
Heck, if you were the user in this post, you wouldn’t need to install anything. “What would I do then?!” Read on to find out!
Step 3: Install the ros2 binary package
We will demo this with the same package the user was struggling with: ros-foxy-joint-state-publisher-gui. Since the package is already installed in our case, we need to uninstall it first, just to demonstrate. Run the following on the current shell:
sudo apt update -y
sudo apt remove ros-foxy-joint-state-publisher-gui -y
Now verify that this GUI binary is no longer present.
user:/opt/ros/foxy/share$ ros2 pkg list | grep joint_state
Gone! Now we will install this package again.
sudo apt install ros-foxy-joint-state-publisher-gui -y
Before anything else, and this is probably what was missing for our friend who also installed the package successfully, SOURCE the ros2 distribution!
And that’s it! Installation complete. We are going to use the package now, but let’s check that it’s in the list of binaries.
drwxr-xr-x  2 root root 4096 Oct 11 15:10 joint_state_publisher_gui
Step 4: Use the ros2 binary package
The user got an error when they tried to launch the GUI binary. Let’s see what we get (fingers crossed).
ros2 run joint_state_publisher_gui joint_state_publisher_gui
You should get a GUI like the image below pop up, confirming that the binary is really there. Cheers!
Hello, I am Joint State GUI
Step 5: Check your learning
Do you understand how to install a ros2 binary package and make it available for use? The magic word here is source.
If you didn’t get the point above, please go over the post again, more carefully this time.
(Extra) Step 6: Watch the video to understand how to install a ros2 binary package
Did you like this post? Do you have any questions about how to install a ros2 binary package? Please leave a comment on the comments section below, so we can interact and learn from each other.
