Learn how to enable live parameter updates in ROS 2 (C++)
  1. The limitations of having a minimal ROS2 parameter implementation
  2. How to add a parameter callback method
  1. Use the rosject: https://app.theconstructsim.com/l/53e75e28/
  3. Original ROS2 Documentation: Monitoring for parameter changes (C++)
  4. ROS2 Courses –▸
ROS2 parameters are great for configurable nodes that you can adapt to your robot configuration simply by changing a configuration file or a launch file. However, if we just implemented the basics you will have to re-run your node each time you change a parameter. You can’t change the parameter on-the-fly and have it updated in the robot. But by adding a callback function that updates the variables in our code, it is possible to do a live parameter update while a program is running, removing the need for a tedious node restart. Learn how to do it in this post.
ROS Inside
ROS Inside
ROS Inside logo
In order to follow this tutorial, we need to have ROS2 installed in our system, and ideally a ros2_ws (ROS2 Workspace). To make your life easier, we have already prepared a rosject with a simulation for that: https://app.theconstructsim.com/l/53e75e28/.
Learn how to enable live parameter updates (C++) – Run rosject (example of the RUN button)
Starting the simulation
After having opened the rosject, let’s start a simulation. For that, let’s open a terminal by clicking the Open a new terminal button.
colcon build --packages-select rule_based_obstacle_avoidance
Now that our workspace is built. let’s source it so that ROS can find our packages:
After the workspace has been sourced, we can launch our simulation:
ros2 launch rule_based_obstacle_avoidance simulation.launch.py
If everything went well, you should have a simulation loaded and opened automatically in a few seconds. The simulation will open from a top view, but you can use the mouse to move the simulation to a different perspective.
 How to enable live parameter updates (C++)
Understanding the problem
Below is an example node in which we have only implemented the barebone basics of parameters in ROS2.
Let’s see it in action and see how it behaves, especially when we update its parameter values.
In a second terminal, let’s run the node for Obstacle Avoidance.
ros2 run rule_based_obstacle_avoidance obstacle_avoidance
If you watch the simulation for a while, you will see that when the robot detects the wall, it rotates and moves forward until it detects another wall, and repeats the process.
The node name is obstacle_avoidance_node (you can check it in a third terminal by running: ros2 node list)
Now, let’s list the parameters of the node in a third terminal:
ros2 param list /obstacle_avoidance_node
We should see the following output:
  angular_z_velocity
  linear_x_velocity
  qos_overrides./parameter_events.publisher.depth
  qos_overrides./parameter_events.publisher.durability
  qos_overrides./parameter_events.publisher.history
  qos_overrides./parameter_events.publisher.reliability
  safety_distance
  use_sim_time
Now, still in the third terminal, let’s check the value of the safety_distance parameter:
ros2 param get /obstacle_avoidance_node safety_distance
The output we should have got should be the following:
Double value is: 1.5
Now, let’s set the parameter to a new value:
ros2 param set /obstacle_avoidance_node safety_distance 1.0
The expected output is:
Set parameter successful
Ok, so far so good. But with the new value, we expect the robot to get closer to the wall before turning around because now the safe distance was set from 1.5 meters to 1.0. The problem is that the robot is not considering the new value that we just set.
We can follow the same idea to try to make the robot move faster. Let’s check the current velocity of the robot:
ros2 param get /obstacle_avoidance_node linear_x_velocity
Double value is: 0.2
If we increase the speed:
ros2 param set /obstacle_avoidance_node linear_x_velocity 0.5
The parameter was reported as successfully set, yet the robot does not move faster, because it still uses the value loaded when the node started.
In the current code, parameter values are fixed. As such, every time a parameter value changes, the parameter value in the code stays the same even though you may have expected it to update based on the latest value set.
In order to solve this, we must add a parameter callback function to your code so that the variable in the code gets the freshest data.
Before moving to the next section, please kill the simulation and all nodes running by pressing Ctrl+C on all terminals.
Solution: Add a parameter callback method
Alright, have you closed all programs by pressing CTRL+C on all terminals?
If so, let’s move forward, then.
We need to modify the following file:
  • ros2_ws/src/rule_based_obstacle_avoidance/src/obstacle_avoidance.cpp
Let’s open that file using the IDE (Code Editor):
Open the IDE - Code Editor
Open the IDE – Code Editor
Once the Code Editor is open, you should be able to see the ros2_ws folder (ROS2 workspace) and navigate to the file we mentioned above:
If you check around line 45 on that file, you will find the “private:” section, where we define the private variables of our class, something like the following:
private:
  rclcpp::TimerBase::SharedPtr timer_;
  double linear_x_velocity_;
  double angular_z_velocity_;
Let’s modify that part, in order to add two variables below right after the definition of “timer_”, so that our code looks like:
private:
  std::shared_ptr<rclcpp::ParameterEventHandler> param_subscriber_;
  std::shared_ptr<rclcpp::ParameterCallbackHandle> cb_handle_;
Now, above that “private:” section, around line 38, let’s add the following code to instantiate a ParameterEventHandler, providing the current ROS node to use to create the required subscriptions:
param_subscriber_ = std::make_shared<rclcpp::ParameterEventHandler>(this);
Below the param_subscriber_ we have to set a callback method, in this case, a lambda function:
// Set a callback for this node's parameter, "linear_x_velocity"
    auto callback_linear_x = [this](const rclcpp::Parameter &p) {
      RCLCPP_INFO(this->get_logger(),
                  "callback_linear_x: Received an update to parameter \"%s\" "
                  "of type %s: \"%f\"",
                  p.get_name().c_str(), p.get_type_name().c_str(),
                  p.as_double());
      linear_x_velocity_ = p.as_double();
Then we set “callback_linear_x” as the callback to invoke whenever linear_x_velocity is updated. We store the handle that is returned by “add_parameter_callback“; otherwise, the callback will not be properly registered.
cb_handle_ = param_subscriber_->add_parameter_callback("linear_x_velocity", callback_linear_x);
After those changes, the “public:” section of our class should look like this:
class ObstacleAvoidance : public rclcpp::Node {
public:
  ObstacleAvoidance() : Node("obstacle_avoidance_node") {
   auto default_qos = rclcpp::QoS(rclcpp::SystemDefaultsQoS());
    subscription_ = this->create_subscription<sensor_msgs::msg::LaserScan>(
        "scan", default_qos,
        std::bind(&ObstacleAvoidance::topic_callback, this, _1));
    vel_msg_publisher_ =
        this->create_publisher<geometry_msgs::msg::Twist>("cmd_vel", 10);
    // declare parameters and set default values
    this->declare_parameter("linear_x_velocity", 0.2);
    this->declare_parameter("angular_z_velocity", 0.2);
    this->declare_parameter("safety_distance", 1.5);
    // get parameters values
    this->get_parameter("linear_x_velocity", linear_x_velocity_);
    this->get_parameter("angular_z_velocity", angular_z_velocity_);
    this->get_parameter("safety_distance", d);
                  p.as_double());
    RCLCPP_INFO(this->get_logger(), "Obstacle avoidance running");
    timer_ = this->create_wall_timer(
        1000ms, std::bind(&ObstacleAvoidance::timerCallback, this));
  ~ObstacleAvoidance() {}
private:
Now that everything is in place, let’s build our package again and source it, using the first terminal:
cd ~/ros2_ws/
The package should have been built with no problems:
user:~/ros2_ws$ colcon build --packages-select rule_based_obstacle_avoidance
Starting >>> rule_based_obstacle_avoidance
Finished <<< rule_based_obstacle_avoidance [27.3s]
Summary: 1 package finished [27.7s]
Now that our package has been rebuilt and sourced, let’s launch the simulation again:
ros2 launch neo_simulation2 simulation.launch.py
The simulation should have been opened just like before, but now we will see the parameters affecting the simulation in “real-time”.
Before changing the parameters, let’s also launch the Obstacle Avoidance node, just like before, using the second terminal:
You should see the robot approaching the wall, and turning around when getting close to it.
Changing the x velocity using ROS 2 Parameters
Ok, now that the robot is moving, let’s retrieve again the current value of the linear x velocity using the third terminal:
Just like before, the expected output is:
Now let’s change that value:
ros2 param set /obstacle_avoidance_node  linear_x_velocity  1.0
We expect a successful output:
If you look at the simulation now, you should see that when the robot is moving forward (not turning around), it moves really faster. So, as we can see, we are now able to make ROS2 Parameters be reflected “instantly”.
This opens up really many different possibilities.
How to create ros2 XML launch files
In this post, you will learn how to create ros2 XML launch files. You’ll discover how ros2 XML launch files are similar to and different from their ros1 counterparts.
Click here to copy the project. It would be copied to your cloud account at The Construct. That done, open the project using the Run button. This might take a few moments, please be patient.
Run rosject
Step 2: Explore the source code using the IDE
Open Code Editor
The main file we will work with in this post is the one highlighted in red in the image above:
  1. ~/turtlebot3_ws/src/turtlebot3_simulations/turtlebot3_gazebo/launch/turtlebot3_world_action_server.launch.xml
Double-click on the file in the IDE to open and study the contents. We will discuss this file in the following steps.
Step 3: Understand how to create ros2 XML launch files
Wait first! I thought ros2 launch files are only written in Python! Yes, Python is one of the options when writing ros2 launch files; we can also use XML files, especially if we are writing simple launch files that do not need to leverage Python’s powerful API.
Let’s have a look at the XML file:
    <arg name="use_sim_time" default="true"/>
    <include file="$(find-pkg-share turtlebot3_gazebo)/launch/turtlebot3_world.launch.py">
        <arg name="use_sim_time" value="$(var use_sim_time)"/>
    <node pkg="patrol_action_server" exec="patrol_action_server_exe" name="patrol_action_server">
What exactly is happening in the launch file?
  • On line 2, we define an argument (variable) use_sim_time with a default value of true.
  • On line 3, we include another launch file, turtlebot3_world.launch.py for launching the TurtleBot3 world. The launch file can be found in the turtlebot3_gazebo package.
  • On line 4, we pass a required argument use_sim_time to the included launch file, assigning it the value of the use_sim_time defined on line 2.
  • On line 6, we define a node to be started by the launch file. This node can be found in the package patrol_action_server, the node executable is patrol_action_server_exe and the name of the node would appear as patrol_action_server.
In short, this launch file launches the TurtleBot3 world and starts the Patrol action server. The same launch file can be written in Python, but this XML looks simpler and easier to understand. And it does all we want it to do, and we can even include Python-based launch files!
Step 4: Understand how ros2 XML launch files are similar to/different from ros1 XML launch files
If you are familiar with ros1 launch files, you should already notice some similarities:
  • The same <launch> tag.
  • Similar <arg> tag.
  • Familiar <include> tag.
  • Similar <node> tag.
Now if we were writing the same launch file in ros1, it would be something like this (PS: we can’t include ros2 launch file in a ros1 launch file in reality):
    <include file="$(find turtlebot3_gazebo)/launch/turtlebot3_world.launch.py">
        <arg name="use_sim_time" value="$(arg use_sim_time)"/>
    <node pkg="patrol_action_server" type="patrol_action_server_exe" name="patrol_action_server">
Can you spot the differences? Compare what you find with the list of differences below:
  • In file attribute of the the <include> tag on line 3, ros2 uses find-pkg-share while ros1 uses find.
  • In the value attribute of the <arg> tag on line 4, ros2 uses var to get the value of the argument while ros1 uses arg.
  • In the <node> tag, ros2 uses the exec attribute to specify the executable file to run while ros1 uses the type attribute.
Interesting, isn’t it? Now let’s see if the ros2 XML launch file works.
Step 5: Launch the ros2 XML launch file!
It’s time to see the ros2 XML launch file in action! Open a web shell and run the following commands:
cd ~/turtlebot3_ws
ros2 launch turtlebot3_gazebo turtlebot3_world_action_server.launch.xml
You should see the following simulation come up.
TurtleBot3 simulation
TurtleBot3 Simulation
Next, run the following command in the web another web shell
user:~$ ros2 node list
You should see /patrol_action_server (the node specified in the ros2 XML launch file) listed as one of the nodes.
Finally, let’s call the action server and see what happens to the simulation. Run the following in the last web shell used:
ros2 action send_goal --feedback /patrol custom_interfaces/action/Patrol radius:\ 0.2\
And that’s it – you have your ros2 XML launch file working!
Step 6: Check your learning
  1. Do you understand how to create ros2 XML launch files?
  2. Do you remember the similarities and differences in ros1 and ros2 XML launch files?
(Extra) Step 7: Watch the video to understand how to create ros2 XML launch files
https://www.youtube.com/video/yyUwKcWQ4DU
How to read and write parameters in ros1 and ros2
In this post, you will learn how to read and write parameters in ros1 and ros2, using C++ nodes. You will see the slight differences in the ros1 and ros2 nodes and parameter files.
Run rosject
Open Code Editor
Yaml Params
The six main files we will work with in this post are highlighted in red in the image above. These files are:
ROS1:
  1. catkin_ws/src/yaml_parameters_ros1/config/params_demo_ros1.yaml
  2. catkin_ws/src/yaml_parameters_ros1/launch/ros1_params_cpp_demo.launch
  3. catkin_ws/src/yaml_parameters_ros1/src/yaml_params_ros1.cpp
ROS2:
  1. ros2_ws/src/yaml_parameters/config/params_demo_ros2.yaml
  2. ros2_ws/src/yaml_parameters/launch/yaml_parameters.launch.py
  3. ros2_ws/src/yaml_parameters/src/yaml_params_ros2.cpp
Double-click on each of the files in the IDE to open and study the contents. We will examine some of these files in the following steps.
Step 3: Understand how to read and write (load) parameters in ROS1
Now it’s time to see how to read and write parameters in ros1, working in the ros1 workspace.
Open webshell
roscore
The code block above changes to the ros1 workspace, sources it, and then starts the roscore (needed for ros1). Now let’s see a list of the current ros1 parameters available. Open another web shell and type the following:
user:~/catkin_ws$ rosparam list
Your output should be similar to the following.
/rosdistro
/roslaunch/uris/host_1_xterm__41731
/rosversion
/run_id
On the same web shell, run the following command to print out the ros parameters:
rosrun yaml_parameters_ros1 yaml_parameters_ros1_node
Your output should be the following:
[ INFO] [1657670307.494093666]: Integer parameter: 1
[ INFO] [1657670307.495689754]: Double parameter: 0.100000
[ INFO] [1657670307.495741256]: String parameter: default
[ INFO] [1657670307.495773876]: Nested integer parameter: 1
[ INFO] [1657670307.495797588]: Nested string parameter: default
[ INFO] [1657670307.495819891]: Boolean parameter: 0
The logic that produced the output above in contained in the catkin_ws/src/yaml_parameters_ros1/src/yaml_params_ros1.cpp file. Let’s see its content.
#include "ros/ros.h"
#include <string>
  ros::init(argc, argv, "my_node");
  ros::NodeHandle nh;
  int param0 = 1;
  double param1 = 0.1;
  std::string param2 = "default";
  int p3weight = 1;
  std::string p3name = "default";
  bool param4 = false;
  std::vector<bool> param5{false, false, false};
  std::vector<int> param6{1, 1, 1};
  std::vector<double> param7{0.1, 0.1, 0.1};
  std::vector<std::string> param8{"default", "default", "default"};
  nh.getParam("param0", param0);
  nh.getParam("param1", param1);
  nh.getParam("param2", param2);
  nh.getParam("param3/weight", p3weight);
  nh.getParam("param3/name", p3name);
  nh.getParam("param4", param4);
  nh.getParam("param5", param5);
  nh.getParam("param6", param6);
  nh.getParam("param7", param7);
  nh.getParam("param8", param8);
  ROS_INFO("Integer parameter: %d", param0);
  ROS_INFO("Double parameter: %f", param1);
  ROS_INFO("String parameter: %s", param2.c_str());
  ROS_INFO("Nested integer parameter: %d", p3weight);
  ROS_INFO("Nested string parameter: %s", p3name.c_str());
  ROS_INFO("Boolean parameter: %d", param4);
  ROS_INFO("Boolean vector parameter [0]: %d", static_cast<int>(param5[0]));
  ROS_INFO("Integer vector parameter [0]: %d", static_cast<int>(param6[0]));
  ROS_INFO("Double vector parameter [0]: %f", static_cast<double>(param7[0]));
  ROS_INFO("String vector parameter [0]: %s", param8[0].c_str());
But wait…are we getting the parameters in the YAML file (catkin_ws/src/yaml_parameters_ros1/config/params_demo_ros1.yaml) and their correct values? Let’s see what’s the in there!
# interger array
param0: 2
# double
param1: 0.2
# string
param2: "R2-D2"
# nested parameters
param3:
  weight: 2
# boolean
param4: true
# boolean array
param5: [true, true, true]
# interger array
param6: [5,6,7,8]
# double array
param7: [0.2, 0.3, 0.4, 0.5]
# string array
param8: ["Bedroom", "Bathroom", "Laundry room", "Kitchen", "Living room"]
Gosh, we are not getting these parameters nor their values, and you probably know why! So far we have been reading the parameters but have loaded them. Now let’s get that done: enter the launch file catkin_ws/src/yaml_parameters_ros1/launch/ros1_params_cpp_demo.launch.
    <rosparam file="$(find yaml_parameters_ros1)/config/params_demo_ros1.yaml" />
This file, when launched, loads the YAML parameter file. Let’s see that in action. Run the following command in the open web shell:
roslaunch yaml_parameters_ros1 ros1_params_cpp_demo.launch
You should get something like the following:
... logging to /home/user/.ros/log/c5f51462-023c-11ed-bb5c-0242ac180007/roslaunch-1_xterm-13868.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
started roslaunch server http://1_xterm:45437/
SUMMARY
PARAMETERS
 * /param0: 2
 * /param1: 0.2
 * /param2: R2-D2
 * /param3/name: wood
 * /param3/weight: 2
 * /param4: True
 * /param5: [True, True, True]
 * /param6: [5, 6, 7, 8]
 * /param7: [0.2, 0.3, 0.4, 0.5]
 * /param8: ['Bedroom', 'Bath...
 * /rosdistro: noetic
 * /rosversion: 1.15.11
NODES
ROS_MASTER_URI=http://1_xterm:11311
No processes to monitor
shutting down processing monitor...
... shutting down processing monitor complete
Well we have some fancy output there, but what has changed? Let’s see that by running two previous commands:
rosparam list
Your output should now look like this:
/param0
/param1
/param2
/param3/name
/param3/weight
/param4
/param5
/param6
/param7
/param8
/rosdistro
/roslaunch/uris/host_1_xterm__45437
/rosversion
/run_id
user:~/catkin_ws$ rosrun yaml_parameters_ros1 yaml_parameters_ros1_node
[ INFO] [1657671513.558912623]: Integer parameter: 2
[ INFO] [1657671513.560352415]: Double parameter: 0.200000
[ INFO] [1657671513.560386238]: String parameter: R2-D2
[ INFO] [1657671513.560404606]: Nested integer parameter: 2
[ INFO] [1657671513.560420530]: Nested string parameter: wood
[ INFO] [1657671513.560435749]: Boolean parameter: 1
[ INFO] [1657671513.560450679]: Boolean vector parameter [0]: 1
[ INFO] [1657671513.560465819]: Integer vector parameter [0]: 5
[ INFO] [1657671513.560484622]: Double vector parameter [0]: 0.200000
[ INFO] [1657671513.560497372]: String vector parameter [0]: Bedroom
Can you spot the differences between the formal and the latter outputs of these commands? Sure you can! So, well, that’s how to read and load parameter in ros1!
Step 4: Understand how to read and write (load) parameters in ROS2
Now let’s change to the ros2 workspace.
In ros2 we need to have a node running before we can check for parameters, because there is no parameter server in ros2. Let’s try running the node then. The logic behind this node is contained in the ros2_ws/src/yaml_parameters/src/yaml_params_ros2.cpp file:
#include <rclcpp/rclcpp.hpp>
class MainNode : public rclcpp::Node {
public:
  MainNode() : rclcpp::Node("node", rclcpp::NodeOptions()) {
    // example: declare parameters, default value given
    declare_parameter("param0", 1);
    declare_parameter("param1", 0.1);
    declare_parameter("param2", "default");
    declare_parameter("param3.weight", 1);
    declare_parameter("param3.name", "default");
    declare_parameter("param4", false);
    // example: declare a variable when declaring a parameter
    declare_parameter("param5", std::vector<bool>(3, false));
    declare_parameter("param6", std::vector<int64_t>(4, 1));
    declare_parameter("param7", std::vector<double>(4, 0.1));
    declare_parameter("param8", std::vector<std::string>(5, "default"));
    // Get parameter values one by one
    auto p0 = get_parameter("param0").as_int();
    auto p1 = get_parameter("param1").as_double();
    auto p2 = get_parameter("param2").as_string();
    auto p3weight = get_parameter("param3.weight").as_int();
    auto p3name = get_parameter("param3.name").as_string();
    auto p4 = get_parameter("param4").as_bool();
    auto p5 = get_parameter("param5").as_bool_array();
    auto p6 = get_parameter("param6").as_integer_array();
    auto p7 = get_parameter("param7").as_double_array();
    auto p8 = get_parameter("param8").as_string_array();
    // Print parameters
    RCLCPP_INFO(get_logger(), "Integer parameter: %ld", p0);
    RCLCPP_INFO(get_logger(), "Double parameter: %f", p1);
    RCLCPP_INFO(get_logger(), "String parameter: %s", p2.c_str());
    RCLCPP_INFO(get_logger(), "Nested integer parameter: %ld", p3weight);
    RCLCPP_INFO(get_logger(), "Nested string parameter: %s", p3name.c_str());
    RCLCPP_INFO(get_logger(), "Boolean parameter: %d", p4);
    RCLCPP_INFO(get_logger(), "Boolean vector parameter [0]: %d",
                static_cast<int>(p5[0]));
    RCLCPP_INFO(get_logger(), "Integer vector parameter [0]: %d",
                static_cast<int>(p6[0]));
    RCLCPP_INFO(get_logger(), "Double vector parameter [0]: %f",
                static_cast<double>(p7[0]));
    RCLCPP_INFO(get_logger(), "String vector parameter [0]: %s", p8[0].c_str());
  rclcpp::init(argc, argv);
  rclcpp::spin(std::make_shared<MainNode>());
  rclcpp::shutdown();
Go for it: run the node:
ros2 run yaml_parameters main_node
The output will be something like:
INFO] [1657672243.344585940] [node]: Integer parameter: 1
[INFO] [1657672243.344674910] [node]: Double parameter: 0.100000
[INFO] [1657672243.344704157] [node]: String parameter: default
[INFO] [1657672243.344720646] [node]: Nested integer parameter: 1
[INFO] [1657672243.344730700] [node]: Nested string parameter: default
[INFO] [1657672243.344745410] [node]: Boolean parameter: 0
[INFO] [1657672243.344755485] [node]: Boolean vector parameter [0]: 0
[INFO] [1657672243.344769947] [node]: Integer vector parameter [0]: 1
[INFO] [1657672243.344780509] [node]: Double vector parameter [0]: 0.100000
[INFO] [1657672243.344795534] [node]: String vector parameter [0]: default
Next, let’s get the list of ROS2 parameters:
user:~$ ros2 param list
/node:
  param0
  param1
  param2
  param3.name
  param3.weight
  param4
  param5
  param6
  param7
  param8
  use_sim_time
Buff…are we getting the values of the parameters in the YAML file ros2_ws/src/yaml_parameters/config/params_demo_ros2.yaml?
# if a namespace is specified
# ns_name:
# node name
parameter_types_example:
  ros__parameters:
    # int
    param0: 2
    # double
    param1: 0.2
    # string
    param2: "R2-D2"
    # nested parameters
    param3:
      weight: 2
    # boolean
    param4: true
    # boolean array
    # interger array
    param6: [5,6,7,8]
    # double array
    # string array
No, we are not :(. But not to worry, the launch file ros2_ws/src/yaml_parameters/launch/yaml_parameters.launch.py comes to the rescue! Let’s examine its content.
#!/usr/bin/env python3
import os
from ament_index_python.packages import get_package_share_directory
    return LaunchDescription([
        Node(
            package='yaml_parameters',
            executable='main_node',
            name='parameter_types_example',
            parameters=[os.path.join(
                get_package_share_directory('yaml_parameters'),
                'config', 'params_demo_ros2.yaml')],
            output='screen'),
Oh my, it’s a Python! Let’s set it loose and see what happens! Stop the currently running program with Ctrl + C and run the following in its place and check that your output is similar.
user:~/ros2_ws$ ros2 launch yaml_parameters yaml_parameters.launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2022-07-13-00-40-35-558545-1_xterm-18432
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [main_node-1]: process started with pid [18434]
[main_node-1] [INFO] [1657672835.736702673] [parameter_types_example]: Integer parameter: 2
[main_node-1] [INFO] [1657672835.736792219] [parameter_types_example]: Double parameter: 0.200000
[main_node-1] [INFO] [1657672835.736810397] [parameter_types_example]: String parameter: R2-D2
[main_node-1] [INFO] [1657672835.736842588] [parameter_types_example]: Nested integer parameter: 2
[main_node-1] [INFO] [1657672835.736847188] [parameter_types_example]: Nested string parameter: wood
[main_node-1] [INFO] [1657672835.736855303] [parameter_types_example]: Boolean parameter: 1
[main_node-1] [INFO] [1657672835.736863129] [parameter_types_example]: Boolean vector parameter [0]: 1
[main_node-1] [INFO] [1657672835.736870819] [parameter_types_example]: Integer vector parameter [0]: 5
[main_node-1] [INFO] [1657672835.736878422] [parameter_types_example]: Double vector parameter [0]: 0.200000
[main_node-1] [INFO] [1657672835.736887246] [parameter_types_example]: String vector parameter [0]: Bedroom
The launch file simply loads the parameters in the YAML file and also runs the node we run earlier.
Well, that’s it!
Step 5: Check your learning
  1. Do you understand how to read and write parameters in ros1 and ros2, using C++ nodes?
  2. Did you notice the slight differences in the format of the YAML files for ros1 and ros2?
  3. Did you notice that you the ros2 parameters are tied to specific nodes vs existing in a parameter server in ros1?
Extra Step: Watch the video to understand how to read and write parameters in ros1 and ros2
How to use ROS2 parameters – ROS2 Q&A #229
  1. How to check for node parameters
  2. How to load parameters from terminal and launch files
  3. How to dump parameters into a file
  1. Use the rosject: https://app.theconstructsim.com/#/l/4875b2e0/
  3. ROS2 Tutorials –▸
ROS2 Parameters key points
Before we start really using ROS2 parameters, let’s understand key points about them:
    • Parameters in ROS2 are implemented/attached to/served by each node individually, as opposed to the parameter server associated with roscore in ROS1, therefore, when the node dies, so do its parameters. This is easier to understand if you already know that in ROS2 we do not have roscore.
    • Parameters can be loaded at the node startup or while the node is running
Having this in mind, our life now understanding ROS2 params is going to become easier.
In order to learn how to load and retrieve ROS2 Parameters, we need to have ROS installed in our system, and it is also useful to have some simulations. We already prepared a rosject with a simulation for that: https://app.theconstructsim.com/#/l/4875b2e0/.
Learn ROS2 Parameters – Run rosject
Launching the turtlebot simulation with ROS2
In order to launch the simulation, let’s start by opening a new terminal:
After having the first terminal open, let’s run the following commands to launch a simulation:
source ~/simulation_ws/install/setup.bash
export TURTLEBOT3_MODEL=waffle_pi
export GAZEBO_MODEL_PATH=$GAZEBO_MODEL_PATH:~/simulation_ws/src/turtlebot3/turtlebot3_simulations/turtlebot3_gazebo/models
ros2 launch turtlebot3_gazebo empty_world.launch.py
Wait some seconds until the simulation is loaded. If for any reason the simulation does not load and you see error messages like the following:
[INFO] [1649093592.180346898] [spawn_entity]: Waiting for service /spawn_entity
[ERROR] [1649093597.566604708] [spawn_entity]: Service %s/spawn_entity unavailable. Was Gazebo started with GazeboRosFactory?
[ERROR] [1649093597.567565097] [spawn_entity]: Spawn service failed. Exiting.
[ERROR] [spawn_entity.py-4]: process has died [pid 1007, exit code 1, cmd '/opt/ros/galactic/lib/gazebo_ros/spawn_entity.py -entity waffle_pi -file /home/user/simulation_ws/install/turtlebot3_gazebo/share/turtlebot3_gazebo/models/turtlebot3_waffle_pi/model.sdf -x 0.0 -y 0.0 -z 0.01 --ros-args']
you can just abort the current command by pressing CTRL+C in the terminal, then run the last command “ros2 launch turtlebot3_gazebo empty_world.launch.py” again.
If everything loaded fine, you should have a Turtlebot Waffle PI simulation running:
Turtlebot Waffle PI - How to use ROS2 parameters
Turtlebot Waffle PI – How to use ROS2 parameters
Checking ROS2 Topics to ensure the simulation is ok
Now that our simulation is running, we can check the topics just to make sure everything loaded as expected.
For that, let’s open a second terminal and type the following command:
ros2 topic list
If you see the following list of topics, then everything has loaded fine:
user:~$ ros2 topic list
/camera/camera_info
/camera/image_raw
/clock
/cmd_vel
/imu
/joint_states
/odom
/parameter_events
/performance_metrics
/robot_description
/scan
/tf
/tf_static
If you look carefully in the list of topics, we have the topic /cmd_vel. We are going to use it to send velocity commands to the robot using ROS parameters.
Understanding the parameter_tests package
So far so good. It is now time to check the structure of our workspace. Let’s start by opening our Code Editor:
After having the IDE open, under ros2_ws/src you should find a package named parameter_tests.
Inside that package, there is also a folder named parameter_tests with a file named parameter_tests_node.py. Please click on that file to open it and analyze its code.
The code is the following:
import rclpy.node
from rcl_interfaces.msg import ParameterDescriptor
class VelParam(rclpy.node.Node):
        super().__init__('param_vel_node')
        self.timer = self.create_timer(0.1, self.timer_callback)
        self.publisher = self.create_publisher(Twist, 'cmd_vel', 10)
        self.msg = Twist()
        param_descriptor = ParameterDescriptor(
            description='Sets the velocity (in m/s) of the robot.')
        self.declare_parameter('velocity', 0.0, param_descriptor)
        # self.add_on_set_parameters_callback(self.parameter_callback)
    def timer_callback(self):
        my_param = self.get_parameter('velocity').value
        self.get_logger().info('Velocity parameter is: %f' % my_param)
        self.msg.linear.x = my_param
        self.publisher.publish(self.msg)
def main():
    rclpy.init()
    node = VelParam()
    rclpy.spin(node)
If you check the main function, we are basically starting the ROS node, instantiating an object of our VelParam class, and spinning that node.
On the VelParam, one of the most important parts is where we define the param_descriptor. That param descriptor is what we use to set a parameter called velocity and define its initial value as 0.0.
Another important part of the code is the timer:
Every certain amount of time (0.1 sec) the timer_callback method is called.
If we now check that timer_callback method, we see that it basically reads the velocity parameter and uses it to publish a velocity to the /cmd_vel.
Running the parameter_tests_node node
Now that we understand what our node does, it is time to run it.
For that, let’s open a third terminal and run the following command:
ros2 run parameter_tests param_vel
You should see constant messages like the following:
[INFO] [1649095105.555241669] [param_vel_node]: Velocity parameter is: 0.000000
[INFO] [1649095105.559028822] [param_vel_node]: Velocity parameter is: 0.000000
[INFO] [1649095105.583306104] [param_vel_node]: Velocity parameter is: 0.000000
We see that the initial value of the velocity parameter is 0 (zero).
Checking ROS Parameters using the terminal
Ok, so far we see everything is working, and we were are able to set and retrieve the ROS Param using Python.
Now let’s list the parameters to identify our velocity param. Let’s open a third terminal and type ros2 param list. The output should be similar to the following:
/camera_driver:
  qos_overrides./clock.subscription.depth
  qos_overrides./clock.subscription.durability
  qos_overrides./clock.subscription.history
  qos_overrides./clock.subscription.reliability
  update_rate
  use_sim_time
/gazebo:
  publish_rate
  use_sim_time
/param_vel_node:
  use_sim_time
  velocity
/robot_state_publisher:
  ignore_timestamp
  publish_frequency
  qos_overrides./tf.publisher.depth
  qos_overrides./tf.publisher.durability
  qos_overrides./tf.publisher.history
  qos_overrides./tf.publisher.reliability
  qos_overrides./tf_static.publisher.depth
  qos_overrides./tf_static.publisher.history
  qos_overrides./tf_static.publisher.reliability
  robot_description
  use_sim_time
  use_tf_static
/turtlebot3_diff_drive:
  use_sim_time
/turtlebot3_imu:
  use_sim_time
/turtlebot3_joint_state:
  use_sim_time
/turtlebot3_laserscan:
  use_sim_time
The node we are interested in is the param_vel_node. In the output above, we can easily identify our velocity param there:
/param_vel_node:
  use_sim_time
  velocity
the use_sim_time is a parameter that comes in every node.
Moving the robot using ROS Parameter
That that we have the param_vel_node with the velocity param, we can easily set a value to that parameter with the following command:
ros2 param set /param_vel_node velocity 0.2
After running this command, you should see that the robot started moving.
If you also check the terminal where we launched our node, it should say the current value or our parameter:
[INFO] [1649096658.093696410] [param_vel_node]: Velocity parameter is: 0.200000
[INFO] [1649096658.181101399] [param_vel_node]: Velocity parameter is: 0.200000
[INFO] [1649096658.281628131] [param_vel_node]: Velocity parameter is: 0.200000
Remember that you can easily set the parameter to 0.0 again to stop the robot:
ros2 param set /param_vel_node velocity 0.0
Dumping ROS Parameters into a YAML file (YAML format)
Now that we saw that we can easily move the robot back and forth using ROS parameters, in case you need to somehow dump the parameters, you can easily do it with:
cd ~/ros2_ws/src/parameter_tests/config
 ros2 param dump /param_vel_node
The command will generate a file named ./param_vel_node.yaml with the following content (after we have set the velocity to 0.0 again):
/param_vel_node:
  ros__parameters:
    use_sim_time: false
    velocity: 0.0
Loading ROS Parameters when running Node using YAML files
All right, so far we have learned how to set parameters using Python and using the command line directly through ros2 param set. Now the time has come to also learn how to launch a node and set the parameters from a YAML file.
Before we do that, feel free to change the velocity value in the param_vel_node.yaml file.
Please, go to the second terminal where you launched the node and press CTRL+C to kill it. The simulation should be kept running.
Now, launch the node again, but now loading the parameters from the YAML file using the following command:
ros2 run parameter_tests param_vel --ros-args --params-file /home/user/ros2_ws/src/parameter_tests/config/param_vel_node.yaml
Based on the logs that are printed on the screen, you should be able to see that the parameters were correctly loaded from the YAML file.
Loading ROS Parameters using launch files directly
Up to now, we were launching our node using ros2 run, but if you are familiar with ROS, you may know that we can also use ros2 launch to launch ROS2 nodes.
If you check carefully the rosject, you will find a launch file under the following path:
~/ros2_ws/src/parameter_tests/launch/test_parameters.launch.py
It has the following content:
        Node(
            package='parameter_tests',
            executable='param_vel',
            name='param_vel_node',
            output='screen',
            emulate_tty=True,
            parameters=[
                {'velocity': 0.2}
As you can see, we are setting here the velocity with parameters=[ {‘velocity’: 0.2}  ]
To launch that launch file, we run the following command:
ros2 launch parameter_tests test_parameters.launch.py
The robot should move again.
Congratulations, you now know all the basics about ROS Parameters in ROS2.
