ROS2 C++ Package Creation Guide | ROS2 Tutorial
- How to create a ROS2 package
- How to create a package with some dependencies
- How to create many packages in a ros project
- How to compile a ros2 workspace
- Use this rosject: https://app.theconstructsim.com/l/5bda8c95/
- ROS2 Courses –▸
ROS (Robot Operating System) is becoming the de facto standard “framework” for programming robots. In this post, let’s learn how to create a ROS2 package, essential for giving instruction to robots, using the ros2 command.
In order to follow this tutorial, we need to have ROS2 installed in our system, and ideally a ros2_ws (ROS2 Workspace). To make your life easier, we have already prepared a rosject for that: https://app.theconstructsim.com/l/5bda8c95/.
Creating a ros2 package
In order to create a ROS2 package, we need to have a ROS2 Workspace, and for that, we need a terminal.
Once inside the first terminal, let’s first run a command that shows the list of available options for ros2:
ros2 -h
ros2 is an extensible command-line tool for ROS 2. options: -h, --help show this help message and exit Commands: action Various action related sub-commands bag Various rosbag related sub-commands component Various component related sub-commands daemon Various daemon related sub-commands doctor Check ROS setup and other potential issues interface Show information about ROS interfaces launch Run a launch file lifecycle Various lifecycle related sub-commands multicast Various multicast related sub-commands node Various node related sub-commands param Various param related sub-commands pkg Various package related sub-commands run Run a package specific executable security Various security related sub-commands service Various service related sub-commands topic Various topic related sub-commands wtf Use `wtf` as alias to `doctor` Call `ros2 <command> -h` for more detailed usage.
ros2 pkg -h
Various package related sub-commands options: -h, --help show this help message and exit Commands: create Create a new ROS 2 package executables Output a list of package specific executables list Output a list of available packages prefix Output the prefix path of a package xml Output the XML of the package manifest or a specific tag
ros2 pkg create -h
usage: ros2 pkg create [-h] [--package-format {2,3}] [--description DESCRIPTION] [--license LICENSE] [--destination-directory DESTINATION_DIRECTORY] [--build-type {cmake,ament_cmake,ament_python}] [--dependencies DEPENDENCIES [DEPENDENCIES ...]] [--maintainer-email MAINTAINER_EMAIL] [--maintainer-name MAINTAINER_NAME] [--node-name NODE_NAME] [--library-name LIBRARY_NAME] package_name Create a new ROS 2 package positional arguments: package_name The package name options: -h, --help show this help message and exit --package-format {2,3}, --package_format {2,3} The package.xml format. --description DESCRIPTION The description given in the package.xml --license LICENSE The license attached to this package; this can be an arbitrary string, but a LICENSE file will only be generated if it is one of the supported licenses (pass '?' to get a list) --destination-directory DESTINATION_DIRECTORY Directory where to create the package directory --build-type {cmake,ament_cmake,ament_python} The build type to process the package with --dependencies DEPENDENCIES [DEPENDENCIES ...] list of dependencies --maintainer-email MAINTAINER_EMAIL email address of the maintainer of this package --maintainer-name MAINTAINER_NAME name of the maintainer of this package --node-name NODE_NAME name of the empty executable --library-name LIBRARY_NAME name of the empty library
cd ~/ros2_ws/src ros2 pkg create my_superbot
Assuming that everything went as expected, we should see something like this:
going to create a new package package name: my_superbot destination directory: /root/ros2_ws/src package format: 3 version: 0.0.0 description: TODO: Package description maintainer: ['root <root@todo.todo>'] licenses: ['TODO: License declaration'] build type: ament_cmake dependencies: [] creating folder ./my_superbot creating ./my_superbot/package.xml creating source and include folder creating folder ./my_superbot/src creating folder ./my_superbot/include/my_superbot creating ./my_superbot/CMakeLists.txt
tree .
. └── my_superbot ├── CMakeLists.txt ├── include │ └── my_superbot ├── package.xml └── src 4 directories, 2 files
sudo apt-get update sudo apt-get install -y tree
Creating a ros2 package with some dependencies
Most of the times, when we create a package, we basically want to reuse or leverage existing tools (or packages).
cd ~/ros2_ws/src rm -rfv my_superbot
... --dependencies DEPENDENCIES [DEPENDENCIES ...] list of dependencies ...
cd ~/ros2_ws/src ros2 pkg create my_superbot --dependencies rclcpp std_msgs
ls tree .
Creating many ros2 packages
There is a principle in Software Development called DRY (Don’t repeat yourself). It basically tells us that we have to reuse code, making code easier to maintain.
There is also the Separation of Concerns (SoC) design principle that manages complexity by partitioning the software system so that each partition is responsible for a separate concern, minimizing the overlap of concerns as much as possible.
In a robotics project, we should ideally have different packages for different purposes. Let’s remove again the package we just created, and rather than creating the package directly on the ros2_ws/src folder, let’s create a project folder there, and then create the packages inside that project folder. Start by removing the existing package:
cd ~/ros2_ws/src mkdir superbot_project
Inside the project folder, we can now create different packages.
cd superbot_project ros2 pkg create superbot_description ros2 pkg create superbot_detection ros2 pkg create superbot_audio
tree .
├── superbot_audio │ ├── CMakeLists.txt │ ├── include │ ├── package.xml │ └── src ├── superbot_description │ ├── CMakeLists.txt │ ├── include │ │ └── superbot_description │ ├── package.xml │ └── src └── superbot_detection ├── CMakeLists.txt ├── include │ └── superbot_detection ├── package.xml └── src 12 directories, 6 files
Building our ros2 packages
Now that we have created the packages, even though they don’t contain any meaning code, let’s learn how to compile the workspace, which contains the packages.
For that, we use the “colcon build” command on the main workspace folder:
cd ~/ros2_ws/ colcon build source install/setup.bash
Starting >>> superbot_audio Starting >>> superbot_description Starting >>> superbot_detection Finished <<< superbot_description [0.67s] Finished <<< superbot_audio [0.69s] Finished <<< superbot_detection [0.68s] Summary: 3 packages finished [0.83s]
ls # build install log src
Congratulations. Now you know how to create your own packages in ROS2, and how to compile them.
So this is the post for today. Remember that we have the live version of this post on YouTube. If you liked the content, please consider subscribing to our YouTube channel. We are publishing new content ~every day.
- Open-RMF / Fleet Management Training: https://www.theconstruct.ai/robot-fleet-management-ros2-open-rmf-training/
