![[ROS Projects] Use OpenAI_ROS with WAM-V Step-by-Step](https://www.theconstruct.ai/wp-content/uploads/2018/08/wam_v_sim-e1533553908946.gif)
What you will learn?
In this video you will learn how to use openai_ros package to make learn the WAM-V sea robot of the RobotX Challenge to pass the first Navigation Control. The only thing you need to code is the AI algorithm if you want to use a different one to the one provided Q-Learn.
You can run the ROSject containing all the ROS code and simulation of the robot and sea by clicking on the next button:
And here the different gits used:
- OpenAI_ROS package: [https://bitbucket.org/theconstructcore/openai_ros/src/master/]
- Example Code: [https://bitbucket.org/theconstructcore/openai_examples_projects/src/tutorials/]
- Simulation: [https://bitbucket.org/theconstructcore/vmrc/src/master/]
And a course on OpenAI in RobotIgniteAcademy: OpenAI Gym for ROS Based Robots 101
Link to RobotX PDF instructions for the challenge:
[https://robotx.org/images/files/RobotX_2018_Task_Summary.pdf]
[https://www.robotx.org/]
